zeno
    921
Everything posted by zeno
  1. By the way.. MBP is connected with usb c cable to a LG 27’ 4k. Absolutely fine. If the MBP is open and it is connected with the 4k monitor, navigation experience throug heavy vw files in Open GL are better on my imac 2017 with 8 gb gpu, but using only the 4k monitor it looks the same, for now. If you switch to M1, absolutely ABSOLUTELY do not trasfer directly data from intel mac or using time machine. It’s a disaster: 8 hour on phone with apple and dropbox support, finally resolved ONLY with a new clean installation. But yes, i think M1 is the way, quicker than we can imagine.. have a cadmouse and spacenavigator, both from 3d connexion, no issue for now
  2. Viewport, same situation render time MBP 13 M1 9 min 18 sec (with a 4k monitor and an iPad Pro via sidecar connected), 9 min 0 sec alone iMac 2017 5k quadcore 4,2 Ghz 64 gb ram 11 min 38 sec, alone
  3. Garden designer using Autocad? OMG welcome to the new life!
  4. Here is it The main class is Bridle Main. Then are also: Rigging-Bridle-Connection= connections Rigging-Bridle-Geometry= what I need in gray Rigging-Bridle-Label= label if exist You can hide the last 3. If you hide the first one the entire object disappear. If you set the first class to show, you alway see lines, even if the planar object on viewport is set to off Bridle lines.vwx
  5. Yes, i know the process. But lines are connected to the main class object. If you turn off the main class, 3d geometry and lines are turned off -even if classe are visibile-. You can turn off the 3d geometry but you can’t turn off the lines. So in this way i need to hide the entire object but i need to hide only lines.. that’s my issue..
  6. Own class seems to show those lines.. as I understand..
  7. Yes, but the lines are controlled by the main class. If you set it to invisible, you can't see the 3d geometry. If you turn off the geometry, you see only the main class with lines.
  8. Hello, there is a rendered viewport with some elements. How can I delete the bridle lines? Planar project Is set to OFF
  9. Hi VW allows user to put several color codes for lights directly into OIP. Where can I find a list? Thanks
  10. Good morning. I would like to ask if this procedure is correct: I want to connect some lights to a sloped truss. In top / plan view they seems connected correctly, but in 3d it is not verified. Does this mean that you have to redo the connections twice? If you redistribute the lights from top view the connections are not easily controllable. How should you proceed correctly? Thanks Connecting lights on angled truss_L.mp4
  11. Yes, but I'm not sure that users can see directly multiple object's area (sum of..) on OIP, like on STR's example.
  12. Could you please tell us your MBP specs? Maybe we have the same machine
  13. 3d connexion solved all problems with space navigator, vectorworks, and big sur https://forum.3dconnexion.com/viewtopic.php?f=23&t=39825
  14. It is a 1080p but you can see that only mode bar has the problem
  15. Using a second monitor (Dell 1080 P) the mode bar icons appears in low quality No problem on main monitor
  16. Hello everyone. Will VW have 2 installer, one for intel Mac basics and one for M1? Off course I don't mean using Rosetta 2, but natively for M1. In my opinion, if i were to buy a new mac i would choose a mac mini with M1 and wait patiently for the first iMac with M1. Sometimes I think of those in the world who bought a mac pro to discover Silicon a few months later and I don't know whether to laugh or feel sorry for him. No doubt for the CPU, but many for the GPU, especially for the developments planned for Redshift integration etc. I'm afraid that the goal for 2022 will become to move VW to M1 and not carry out integrations on GPU-based rendering, which is essential. Of course this will also depend on Maxon. But we all saw what was the only professional software shown during the M1 presentation ...
  17. On one of first 2021 new features launch videos, some images about wall detail and roads appeared, but there is no news about this. Will they be implemented in 2022?
  18. I'd like to now, for HBIM (historical BIM) workflow, if we will have variable thickness wall to manage correctly existing and historical buildings in Europe.
  19. Very interesting. Thank you!
