Bruno Sá
22 -
Reputation
0 NeutralPersonal Information
Location
Portugal
Recent Profile Visitors
Hi MH2R! Did you found a way to solve this? I'm having the same issue! @Stephan Moenninghoff can you help with this isue? Great regards, Bruno.
Interiocad 2023 section viewport issue.
Bruno Sá replied to Bruno Sá's topic in 3rd Party Services, Products and Events
Hi Everybody, here goes an update... We finally have the permanent license, so everything is updated now. The issue is gone! Section viewport works fine now! By the way, as we now have a Service Select Subscription, I'm using company e-mail! Thanks everyone for the attention, and as we're beginners using Interiorcad we'll probably be here many times! Great regards! Bruno. -
Hi @Kevin K! Thanks for your attention, and sorry to bother you in vacation! Wasn't having this Issue in 2022... I'm not in my computer at the moment, but will upload the file later. Thanks again! Regards, Bruno. -
Hy everyone, I'm running Vectorworks 2023 and Interiocad trial license and had some issues using section viewport for cabinets. The parts appear out of place in the viewport, as in the images below: Left Image - Design layer, Left clip cube view, wireframe. Plinth is in the right place. Right Image - Sheet layer, 2 section viewports from the same cabinet (done through clip cube), hidden line. In the first one, Plinth and doors out of place. In the last one, door is ok but front plinth is out of place Any Idea? @Stephan Moenninghoff @Kevin K @salukitd Thanks! .
help developing production drawings for counter.
Bruno Sá replied to Bruno Sá's topic in Solids Modeling
@Stephan Moenninghoff I already create the solid peace...using NURBs and loft surface...and then shell, as you can see in the first image. What I need now is to have this peace in 2D to send to CNC. Thanks again! -
@Stephan Moenninghoff Thanks for the tip! -
Hi Everybody! I received some 2D drawings to produce a customer service counter in a mall and need some help with an issue... I'm modeling the counter to set the construction documents and CNC files, but don't know how to plan one of the pieces direct from the 3D. Attached some images to illustrate the issue...the yellow piece in the model is the one I want to create a plan for a CNC file. Any idea? Thanks!
Great Pat! I'll check it out and give you feedback later! Thanks again!
@Pat Stanford You're right! What I need is to show the path to the file location at the title block. Do you know how to do it? Thank's a lot! Bruno.
I'll check it out! Give you feedback later! Thanks again!
yes, but wich library contain this symbol?
Hi Mark! I did it, but don't know why it didn't work! I'll try again... Thanks
Hi everybody! Does anyone know if there's possible to link a text in the title block with the file location? Thanks! Bruno.
It's an alternative Alan! Thank you! B.
