elepp
253 -
Everything posted by elepp
My interest is also peaked. 🙂 But I have no doubt about its efficiency. I have seen some of your work and I also had the good fortune talking to you once on the phone about it. A mutual friend here in Hamburg set it up 😉
The length to which a bigger office has to go, can be quiet nicely seen in one of the webinars from this year. The office showed their file and referncing strategy . The complexity shown was something else. Very sophisticated. And one person only busy with the maintenance of all these references. That was not necessarly a presentation in Vectorworks favor. I do admire though their dedication. If I find the video and will link it.
Seeing though some of their released features now to what is in the pipe line at VW, I get the feeling we are just trying to get feature parity. And even that will take some time. 😒
Shapr3D is showing the way in my opinion. The advantage it has compared to other tools is, that it started on an iPad. The restrictions of the smaller screen real estate leads to fewer obstrusive menu bars and dialogs. Developers for macOS/ windows can learn a thing or two there.
Very much that. Compared to the majority of competitors we spend to much time in some clunky dialog instead of drawing our plans. (Adding a door to walls should not depend on me knowing already how big the door is. Windows are the same.)
Vectorworks Revit Export is better than Revit's IFC import!
elepp replied to shorter's topic in General Discussion
Yeah, I think as long as the term "BIM" is not trademarked it always defined in a way that suits you. Archicad trademarked the whole OpenBIM thing and now in Germany everyone thinks Archicad and OpenBIM are synonymus. 🤷♂️ -
The advantage though for them is that there is a huge industry of BIM Consultants, that can help you in your BIM Journey. There is hardly anyone in Germany. And the few who are doing it, are not enough to compete. So if you try to find someone to help you along they will all be "selling" you Revit. -
Yeah. His series about BIM explained with Lego Bricks is a good starting point for newbies in this field. Here in Germany Architects seem to be all over the place in terms of BIM software. The very big ones mostly use Revit. But they also rely heavily on third party plugins to make it complient with german standards. Which adds additional cost to the already high price of Revit. -
I agree. We also had a project once where the consultant to our client demanded Revit-files, because their whole system was setup that way. Very annoying. I also only heard bad things about their ifc capabilities. Though I have found some useful informationen about ifc on a blog of revit users of all places: https://bimblog.bondbryan.co.uk/ifc-industry-foundation-classes-layers-and-classification-in-autodesk-revit/ -
Yeah. That's the problem for now. The psets in ifc are usually called something like pset_WallCommon or pset_SlabCommon. The whole entry usually looks like IfcWall.Pset_WallCommon.FireRating. That's why a signifier like * would be helpful.
That sounds like an interesting idea. Is it possible to extract the fire rating of slab, walls and roofs at the same time? They all have a pset for this. Or extracting the name at once, because they all have this as a set. Maybe with a wildcard similar to worksheets: *.firerating. 🤔
I might be mistaken, but I thought the international Version also has the option to import mtextur ressources. It's a swiss website that provides quite a lot of textures. It should be part of the many import options.
Create IFC files in service select
elepp posted a question in Wishlist - Feature and Content Requests
Hi, since a while we can push our files into the cloud to have our pdfs published automatically. Or we can use it as a render farm. My wish is to have the possibility in a future update to do the same with our ifc files. after some time our files can get large and the ifc export might take some time. Being able to push a file into the cloud to have this process handled in the background would be a time saver. Thanks!- 1 reply
- 2
Parasolid seems to work already since a while with Apple SoC. The shapr3D app for iPads is based on Parasolid and is now available for Big Sur. There was a podcast with Architosh, where they discussed that. https://www.trxl.co/podcast/023
Thanks for the quick reply @GioPet. I'll send it to you via the support mail. Regards, elepp
Hi @GioPet, I downloaded the trial version. Installing it in my german version of Vectorworks is causing an error. The Workspace is broken afterwards. I can though manually add the commands in the workspace editor. If helpful I could send you a private message with a video file of my installation procedure. Regards, elepp
As far as I remember Revit is "serverless" and works like Vectorworks. One Projectfile on the server and everyone creates a workfile, that is saved locally. Edit: Sorry. Just saw that Revit now supports both. File based and server based.
@Nikolay Zhelyazkov I would like to send you a file with some of the broken data tags plus a video.
@Nikolay Zhelyazkov Project sharing was not used. We had them referenced from a template file in another projetc, so i assumed it was related to that. But in this project it's only a single user and no reference and it happens.
For me a live dialog box underneath it would be nice, so you see the whole formula at once and you could make your adjustments there as well. One of our biggest issues is, when you have lots of criteria and you would like to remove one from the middle. So far you always had to delete it from the bottom up. The other issue was if you edited the dialog in the formula bar and you went back to this dialog and just pressed ok, the formula was overwritten and a | was replaced with a &, or viceversa. Frustrating. I think the way it's handled in the data manager could be a way to go. Especially because the interfaces would be similar and people would be used to the way it works in both situations.
VW Architect 2020 SP5 (German version) We place the data tag and type in the value. It's not a smart tag, that automatically pulls the data That's the point where I am also a bit at a loss. I can't reproduce it either. My colleagues are not regularly checking on the tags, but after a while they notice this behaviour. But they can't tell me all the steps they did before. It happens often enough though that at least 10 colleagues noticed it seperatly from each other.
Hi, We are experiencing an issue with our data tags. Maybe @Nikolay Zhelyazkov could help us here. We have a data tags for displaying the height of objects in our plans. The tag is setup that it displays a standard value of +1.00m and upon insertion my colleagues change the value manually. Now it happnes regularly that it reverts back to +1.00m. I can not pinpoint what is causing it. But it happens very often and everyone is very frustrated with it. They started to explode them now into groups for a lack of better options. I've attached a .vwx with our tags. Best regards! Data Tag.vwx
Hi DomC, great node. I even managed to attach an ifc-record to the object. We encounter though one problem. We tried to use a symbol instead of group as control geometry. It worked for rescaling it but interestingly enough it looses its graphic attributes. In the screenshots you can see the marionette object in white and inside the control geometry you can see the original colors. Any idea why that is or how to solve it? Thanks in advance!
More than incremental updates to windows, doors and stairs
elepp replied to Christiaan's question in Wishlist - Feature and Content Requests
Hi, thanks for the update. Very much appreciated. I can imagine that it can be a bit frustrating also for you guys at VW Inc. with us complaining in the forum. But at least for myself I can say that it comes from a place of appreciation for the work you all put in. Sometimes I have the feeling we are in a relationship with VW Inc. and we are considering if we should head for couple counseling.- 21 replies
- 1
- window tool
- door tool
(and 1 more)
Tagged with:
