Steve Riddle
77 -
Everything posted by Steve Riddle
3d Objects 'Clipping/Disappearing' When Zooming In
Steve Riddle replied to milezee's topic in General Discussion
I'm having the same problem when i create a landscape area with some new plant image props, Am guessing its something to do with the new plants that messing up the perspective. -
I am using the file as a base model for rendering a new subdivision in Twinmotion. The source file was put together in Civil 3d by the roading Engineers, I see the TIN file (Surf_CB) is too much for VW to process, so have used the contours only at 0.2m (Landmark,Create Site Model, Simplfy 3d polys). The best result would be if the software could process the tin as designed by the engineer. The resulting model is good enough to work with for now, but as a work around I will get 3d polygons of the kerbs, channels, road centrelines etc to clean up the edges where VW is triangulating between the contours. The Road surface, footpaths etc I have placed texture beds with a simplification tolerance of 0.1m, this has worked out well, its great to have the option to reduce the number of vertices for these. The texture beds via C4D export work well in Twinmotion. Thanks for your help 🙂 Untitled.pdf
Just an update, Through trial and error I was able to return the correct number of posts through assigning a unique class to the 2d post attribute. No luck with the frames/panels though.
Does anyone know how to simplify this into site model I can work with? I have tried to simplify the polygons (without success) 1022-2D.vwx
I thought that might be the case, I tried adding specific materials and classes via the fence attributes palette to report a count of elements by material/ class, it returned numbers, but these didn't equate to the panels and posts in the fence. Thanks for looking into it.
Hi, See attached v2020 Cheers, Steve 326-1A v2020.vwx
Has anybody had a look at this? I really need to get back to the client with a plan and schedule of frames and posts for tender. Perhaps I should forget about using the fence tool and use symbols?
Thanks, See attached file. 326-1A.vwx
I am trying to prepare a schedule of posts and panels for a school fence, but the report does not seem to allow these attributes to be counted? I also want them summarised by panel length.
I am having trouble with plant paths in a file using create object from shape command (plant from polyline in this instance). I am using polyline polyline to create a curved hedge row. Is there a way to edit the hedge row with a bezier path? This would be much easier than having to edit the polyline and re-convert to a plant.
Pickup putdown attributes for fence/rail tool
Steve Riddle replied to Steve Riddle's question in Wishlist - Feature and Content Requests
I created a series of vehicle barriers around a carpark with timber posts and wire cables, We then decided we needed to have timber rails instead of cables for some of the barriers. So I created a barrier with a timber rail and other attributes I wanted. I then used the eyedropper tool to pick up the parameters of the new timber rail to place on some of the existing cable barriers. I expected the post spacing, rail height and type to change, but it doesn't. Another thing I found that could be useful, is the offset tool to move/duplicate fences. I had originally placed the barriers next to the kerb and found I needed to set them back 1m to allow for vehicle overhang, I had to re-draw these barriers as the offset tool did not seem to work for this plugin. I hope this explains a bit more clearly, Cheers, Steve -
Hi, With plug-in parameters on, when I try to change the top rail to the same style as the bottom rail using the eyedropper tool it doesn't seem to work. Thanks, Steve -
I use the landscape area tags, perhaps I now need to use the data tags going forward? Will the data tags display and behave the same data as the landscape area tags? (ie. list of plants and quantities) and I assume they update automatically with any changes to the landscape area? Thanks, Steve
Hi Katarina, Thanks for the help on this, Slighty off topic, but this raises another issue I have with the landscape areas (and I guess other items with tags) When I use the eyedropper tool with plugin parmeters selected, the tags I have painstakingly placed, move location. So any time I need to make a change that involves multiple landscape areas, I also need to reposition the tags. It would be good if the eyedropper tool had a check box where the plugin parameters could change but not the tag positions.
I have changed the name of a plant in the plant style dialog and it dissapears from all the associated landcape areas and the schedules! Is there a way to fix this?
I am trying to prepare a location plan for a job at a scale of 1:250,000 using a Geoimage base with the topographic layer. When I set the resolution to 500 the text in the Map is the correct size to read but too pixellated, when I increase the resolution to 5000 the text is no longer pixellated but too small to read, is there a way to have the text at a readable scale and not pixellated?
While updating from SP4 to SP 5.2 the installer stops midway through the process, it says and unknown error has occurred and contact technical support. How do I get this to update as having bugs with SP4 in Catalina ?
OK Thanks, I will give that a try also. In the end, I used a point cloud version of the file, It had 60 million points but was still quite workable. I found I was able to cut a hole in the cloud and place the site model with a reasonable level of realism in the output. I now need to match the tone of the lighting to what appears in the point cloud, the heliodon lighting is too green/yellow for some reason, so I think will need a custom light to correct this.
- 2 replies
- landmark
- site model
(and 3 more)
Tagged with:
I am trying to show the visual effects of a proposed carpark and visitor facility. I have imported a textured .obj survey file in the form of a mesh (see attached file) and I need to insert the site model for the new carpark into this while keeping the terrain and textures of the surrounding area intact. I find when I try to edit/cut a hole in the mesh to create a space for the new carpark, the texture disappears. Is there a way to 'bake' the texture onto the 3d polygons within the mesh? or can the mesh be converted into another form that allows me to do this? Thanks, Steve
- 2 replies
- landmark
- site model
(and 3 more)
Tagged with:
Cannot use the eyedropper tool to pick up and put down fence attributes.
- 1 reply
- 1
Hi Nikolay, I have 50 sheets in the file and 50 title blocks in this particular file, the two most recent sheets I created didn't update with the issue manager in their respective title blocks, In my workflow, I usually copy and paste a sheet border/title block from a preceding sheet and update any relevant information I need to change. In the end, I just deleted the 2 sheet borders that did not update and repeated the process of copying and pasting final 2 sheets from a sheet border that had the latest issues showing in the issue manager, this seemed to fix the problem I was having. Thanks, Steve
OK Thanks, I will try deleting. Many Thanks, Steve
