980 -
Everything posted by Matt Overton
Same file open in more than one Tab
Matt Overton replied to Matt Overton's question in Wishlist - Feature and Content Requests
I think I should just go ahead and call this done thanks to tease-day. -
How to convince boss i am capable with VW
Matt Overton replied to CraftyCat's topic in General Discussion
Exactly this save a minute out of someone important's day and they will see you as valuable. Save a minute out of everyone's day and you'll be invaluable. -
Well not just walls, roofs and slabs would all benefit from having components that understand they are frames not panels of solid material. Roofs have rafters, hips, valleys, barges,.... and facias that could all be made with a Framed Component. Slabs have edge and other beams that could all be made with a Framed Component(s). These two would help us get to convincing large scale sections in minutes not hours. So to me, it's not just a super wall but a superstructure inside all our building elements.
I sure hope you plan to tease early Tuesday so they happen Wednesday not Thursday around here.
Yes all the unsexy stuff that really makes the updates worth while but never makes promotional material.
Producing Gantt charts in Vectorworks
Matt Overton replied to Christiaan's topic in General Discussion
There are any number of online project management sites now that do Gnatt charts that are fairly easy to learn and use. We have been using one called smartsheet it's works ok but doesn't do resource allocation, while a friend and Ex-Vectorworker has built his own in excel so that is doable if you are OCD. Still, I'm guessing if you were to try and make one in Vectorworks. I'd start with a Marionette object to handle each line then work out how to link the lines. Then again if I was going to build a gnatt chart I'd personally be looking more at collision detection systems in gaming engines to build the chart. -
Space tool both the label and reportable dimensions need to be able to use alternative and display units not just be locked to working units.
So finally kicking in transition to 2017 with some real projects kicking off and just noticed this change to records. Thank you.
File / Project Info
Matt Overton replied to zoomer's question in Wishlist - Feature and Content Requests
I'd really like this but then it's a problem with too many variations on a theme to cover the full international code requirements. Still, a special "blessed" worksheet for this sort of information and some other improvements to worksheets to make these sorts of things possible could be very handy. -
Reorganize docked document tabs
Matt Overton replied to Bruce Kieffer's question in Wishlist - Feature and Content Requests
If they used system provided tab bars on each platform all this would work as it should. Not to mention they wouldn’t be so ugly. -
Thanks, I think I have it working now.
It would be a real time saver if rendered viewport flagged which geometry effected then and could estimate how much change will effect them. Give higher weighting to changes front and centre. Even break the dirty viewport indicator up to show which part of the viewport is effected.
Editable Floating Data Bar text
Matt Overton replied to Billy Canuck's question in Wishlist - Feature and Content Requests
They could just switch the blue and the gray over and have a better interface. -
I think the problem you highlight kills off most of its value above generic cloud service. Just think full set rendered overnight in morning check prints to realize a couple of notes on a rendered page didn't pick up a conversation you were having with the client as the "draftie" sent the file to cloud and went home. If the viewport cached no problem fix and publish. Sure you can cut the render out of the PDF paste it over the wireframe viewport.
Great Idea, Might have a look tonight at building a script to make a one click timestamped named saved view to add to right-click or key. I could always then go back rename if useful. To me it is not multi-view in the sense that the views are not on-screen at the same time. it's more like having the file open a number of times each time logged into project sharing as separate user or user with a different hat on. -
Well, they could give us a true sloping slab and fix the roof tool as well in the process.
Something different and in part driven by this. say your madly working through steel detailing coordination so you have a set of views set up like this. The phone rings it’s the builder who is doing first set out in the shed you are doing works to. The client has moved all the stuff out of the way and there are a few quirks to the existing heritage brick facade he wants to talk about and how they effect set out. If I change my view in the file a lose my place and view set up for the work I need to get back to now later in the day. the more complex the view set up is the more VW cost we have dealing with what are just natural parts of the job. -
Matt Overton posted a question in Wishlist - Feature and Content Requests
It would be good (ie Faster working) if the same file could open multiple tabs with different views. Better if certain navigation operations were configurable to do this automatically. Such as navigating into design layers from a viewport making it easier to switch back and forth. Great for leaving one task as it is, then jumping to another part of the file for builder phone calls or team coordination discussions. Then quickly get back to working view. -
More than one is time-consuming and repetitive let alone 4 min for each project. Add on top of that we move elevation line from boundary to just outside wall line between council application and construction drawings. Add in all the things we need to do to translate information the computer knows about but can't display and well yes there is an awful lot of time that could be saved from Drafting and directed to Architecture.
Google didn't turn up anything possibly due to bad search terms on my part. Is there a 3rd party python code editor that features syntax highlighting and code completion or vs.python? The function documentation is hard to find things in but I reckon I could get very close with a few keys with code completion. Certainly, works in xCode and Swift foundation to find the right function.
Surprised it's taken this long for AR to get a mention in these forums? I think there is a stack of interesting things you could do with both ARKit and Vision-ML for the cad world.
Bookmarking a post
Matt Overton replied to AlanW's question in Wishlist - Feature and Content Requests
You can also change settings so that any topic you post in is automatically followed. -
Pause Rendering
Matt Overton replied to Andy Broomell's question in Wishlist - Feature and Content Requests
I think the advice you'll get from VW here would be along the lines of using service select to send the long running render to the cloud and get on with other work. Which of cause brings up a parallel wish for subscribers to be able to push a render to the cloud then import it (or have it magically appear) back in the file so project files can stay together. Better still if from a button on Object Info. Better still if we if rendering had say a preview fast render before dispatching the longer job. Still, pausing would also be handy for overnight rendering if we could line up a bunch of renders pause them then have them un-pause one as the last one finishes instead of having them all competing for the processor and slowing all of them down with context switching. -
All of the above and maybe some stretch goals:- - Sheets should always show in the correct order by drawing number in every list. - Group sheets into packages so it's easier to add and adjust numbers in big sets. - Set a titleblock / Drawing label style that applies to all drawings the set or group.
