145 -
Posts posted by Rishie
Also the Vectorworks university is so impressive and helpful for designers like me.
But why there is no content related to lights?
I tried to use emitter option in Vectorworks and set lumens as 1500. Place 4 lights in the living room and rendered but the light is not rendering when i switch off emitter it works. i can see the lights in the viewport
Is there any issue with the emitter option?
Where can i learn about light object settings in Vectorworks Architect 2022.
Thank you,
Rishie -
We use 15w dimmable lights in living, dining and kitchen and Heliodon for sun light.
Below you can find the light settings that we use for the 15W dimmable lights.
While rendering i can't find the intensity of dimmable lights that use in living, kitchen, etc., the sun light covers a lot of portion and the dimmable lights that we use it almost not visible. Do we make any mistake in the settings? Do we need to improve the light or renderings settings?
Please suggest.
Thank you,
Hi Everyone,
Do you know if there's any iPad or Android app we can build a 3D and allowing client to apply their own texture?
Thank you in advance!
Rishie
What is the easiest way to cut building into the 3d topo slope?
What is the difference between the following 2 - a. Directly reference in dwg file b. Import dwg file into vw, then, reference vw file to the new
How to import 3D Civil with site contours into Vectorworks?
How to adjust fascia thickness?
How to adjust cut plane height for floor plan?
Still the problem is same. Installed few service pack but the bug is not fixed yet
On 12/18/2021 at 7:17 PM, nikihoops said:
o what Ian above suggested that works. I’ve not had to do it every time I open VW22 but a few times. It’s not a long term fix but it does resolve it for you to carry on and use VW22 in the meantime
Hi Niki,
I tried Lan's trick but i need to do it all the time whenever I opening the application. Even if i restart the application after a break i need to change the text size which is not very friendly and makes me to stick with VW 2021.
The problem is i've also upgraded my MacOS to the lasted one which VW 2021 do-not have official support yet. I've not yet experienced something that stops me to work from 2021 luckily
Hope VW finds the solution for this menu bar very soon
Hi,
We are a team of 6 designers. we all are upgrading to VW 2022 and opt for 30 days trail to check the quality.
we're also experiencing the same issue. "VW 2022 SP2 Menu Bar not working"
For the two designers who work with a single monitor have never experienced this issue, i work with dual monitor and i'm experiencing this issue all the time and can't do my job with VW 2022.
Please let us know if this issue is solved.
Thanks!
Hi, I'm interested in buying if it's available.
Much appreciated Tom for the quick solution.
It worked!
My walls are connected with each other with "L or T" joint but when i try to push or pull it's not moving the connected walls, i can move the wall by clicking and dragging but the walls that's connected with it stays in the same place and does not moves along parametrically.
I'm experiencing this recently this was working well all the days. Did i made some changes to my setting?
Can anyone guide me with it?
It's in one VW file. Thank you!
When I publish my sheet layers in DWG file format, I get one DWG file for a sheet layer.
Is there an option where I can export all my sheet layers in a single DWG file?
That's a good news! Thank you Chris
We can add two panels for folding door ...I need 3 to have panels
What's the best practice to have it?
Should i create a 3D symbol with insert in wall option for it?
Let me know if there is better way to do it
Thank you,
Rishie
Thank you Nikolay it worked well 🙂
Appreciate you!
- 1
Hello, Any suggestion for us to resolve it?
Thanks you so much Shorter for the help. Appreciate your effort!
We tried it but the paper size is still bigger.
Attached the working file and the screenshots for your review. Page size error.vwx
Wow! Yes it's working! I'm using this tool for the first time. Thank you so much Tom :)
- 1
Hi,
Even i've encountered this problem, the page size that i've defined in the page setup dialogue box is different from the actually page size the title block size is cropping with the page size (defined as the page setup) but when we export i get this extra space in the pdf away from the tile block.
Anyone here can help us to fix this?
Does use emitter option in Vectorworks light works?
in Architecture
Posted
Thanks I'll look into it
