Ross Harris
    482
Posts posted by Ross Harris
  1. 6 hours ago, E|FA said:
    Most of my wall styles have interior GWB.  If needed, I can model interior finishes over the top
    Pretty much what I do - my finishes are usually rectangles drawn over the wall (extruded 1mm if it needs a texture) or part of the wall in automatic plan mode and classed for visibility (on/off) and scheduling if need be.
  2. @JRA-Vectorworks-CAD the new AMD Ryzen 3950x 16 core cpu dropping in November looks to be a beast of a cpu - faster and cheaper than anything Intel can stump up. Pair that with a rtx2080 or rtx280ti it should chomp through anything thrown at it. I’ve currently got a 12 core AMD threadripper and a gtx1080ti and it blasts through VW renders and Twinmotion considerably faster than my 2019 MBP with an egpu.
    • Like 2
  3. 3 hours ago, Diamond said:
    I have seen this recently on a large Revit based project where the (AutoCAD based) 2D plans, sections and elevations are a month behind the model.
    Jeepers - why on earth would the 2d stuff be done in AutoCAD? At the Revit practice I worked at, everything including the details was done in Revit. Its 2d drafting capability is slightly above rudimentary, but still totally usable and hatches can be imported .pat files from AutoCAD. Seems a bit disjointed..
  4. @Nikolay Zhelyazkov is it possible in the 'project revision history' worksheet to show all the revisions and equivalent issue number or add a column to the 'sheet revision log' worksheet to show the issue at the time of revision?
    At present the 'project revision history' worksheet only shows a new entry when a new issue is generated and the revisions at that point (completely excludes issue 2 in the attached example) - it seems odd that a revision history worksheet doesn't chart all the revisions. To correlate the missing revisions you need the sheet revision log worksheet issue and revisions requires cross referencing both worksheets - would be great to have this info in one place. Some clients will argue that they shouldn't have to pay for revisions they can't see... 😣 like in the attached when there are 3 revisions but only two logged in the project revision history. Also makes things less cluttered not having worksheets everywhere.
    Awesome work on title blocks v3 btw 😀
    Thanks!
    • Like 1
  5. On 5/31/2019 at 4:51 AM, Tom Klaber said:
    I love it - my partner thinks it is annoying
    Lol like JJ Abrams films... some hate but I love a good ol’ flare - it’s kinda become his thing!
    Awesome renders - will have to get the demo... the Twinmotion integration (if it happens) could be a while... 😕
  6. Is there a tag function that can report the length of a line? Bracing in NZ is represented on a plan view by a dashed line along a wall (between other walls and windows/doors) and the length of each line equates a a figure representing bracing units. I've made a tag that will pick up the line name and sequentially number the braces, but I need it to pick up the line length... is this possible?
    I have a worksheet schedule that can report the line (via class), brace type (via attached record) and length  - but I can't get it to automatically sequentially number the line entries...
  7. Piece of cake!
    In the site file, go to View>Create Viewport - when the 'create viewport' dialog opens, go to the layer drop down and select your site layer.
    The 'select viewport source' dialog box will open - select the 'external document' radio button, then click 'choose' and browse to your building file.
    Once selected, Click OK and that should be it 😀
    It will help immensely if the building ground floor has been modeled at a z height of 0 upward - you'll need to lift the building model once imported to the site model file up to the correct level relating to the site mesh - the finished floor level will be in the OIP whenthe referenced model is selected.
    • Like 2
  8. What would be awesome is if you could select the scale manually - so you could have an A1 scale bar and an A3 scale bar on the same page and be able to place it on the sheet layer rather than inside the annotation layer, so you don't have to keep adjusting its position if you move the viewport...
    • Like 3
  9. I've been building my machines since I bought my first machine from a shop in 1999 for writing and recording music... when my friend (and my band's bass player) ripped the side off it it was completely de-mystified.. this big case had hardly anything in it...
    I few years back I worked for a small structural engineering firm (the PC's were built by an IT company) who wanted to roll out Revit; my machine crashed every 1-2 hours (they blamed the software (cos it ran AutoCAD OK). I'd had a guts full of this after a week and informed the boss I was looking inside (he freaked out) - as I expected all budget parts, but the company assured him it was up to spec. To his credit he let me build a machine for Revit and it never crashed again... so I ended up building a few more and we never had any major PC problem while I was there (the network and appalling server install is another story... 😲)
    I guess my point is if you can find a company that will build a machine to your spec so that you know exactly whats in them will enable upgrading with better CPU's (socket/chipset allowing), more RAM, new video cards etc - it'll absolutely cushion the massive cost in doing a full system upgrades if they have upgrade tweaks. I've used nothing but Corsair (PSU, Ram), ASUS & Gigabyte (mainboard), either ASUS, EVGA or Sapphire (graphics) & Dell monitors for around 10 years now and the builds have been rock solid. With more stuff directly on the mainboard (wifi and bluetooth etc) driver issues are virtually non existent now and I can pack it into smaller cases. This is where vendors like Dell etc will change things based on profit margins - they might sell a grunty machine, but it might have a budget motherboard chipset bottlenecking the GPU... these specs are really hard to get out of these companies and why I'd totally avoid them.
    Apologies for the spiel - hopefully there's something useful in it 😁
    • Like 1
