9 -
Posts posted by Pascal Völz | CADVölz
Hello GRZEGORZ,
is it important for you to have a menu command? Otherwise, you can save the Marionette Object as an intelligent symbol.
Kind regards
Pascal Völz
Hello barnes2000
you take the node "objects by crit" and write the following for criteria:
sel = true
or
(sel = true)
The node gives the handles of all selected objects when you run the script.
Kind regards
Pascal Völz
2
Hello herbieherb,
what exactly do you want to do? Maybe you can program your project into a manual part with the existing paint-bücket tool and a second automated part.
Friendly greetings
Pascal Völz
Hello Michael,
for your ideas you have to rewrite the original nodes. Enclosed you will find a file in which I have done this for you.
Kind regards
Pascal Völz
1
Hello Michael,
i will check this on sunday.
Kind regards
Pascal Völz
Hi Michael,
the beam must be updated after activating the control box. The easiest way to do this is to move the object with the vector 0/0/0.
This is not the nicest method, but I have not been able to find another order so far.
Kind regards
Ing. Pascal Völz B.A.
CADVölz
www.cad-voelz.de
Hello MRoth,
in the attached file is at least a start. The script reads all activated objects and then filters them for objects that are on the active layer. If you need more help, feel free to contact me.
Kind regards
CADVölz
www.cad-voelz.de
Perforated Sheet
by Graf | Hagen | Völz
The following Python Wheels must be installed:
- Pillow
File information:
- scale in 1/1
- unit in cm
Description
The perforated sheet tool generates a perforated structure from a bitmap image. The generator creates a circle for each of the pixels, the color or black-and-white values of which giving the respective diameter. The circles have a radius of 2, 3 or 4 millimeters and are spaced at intervals of 1 cm. In order to create a higher contrast, for certain color values no circles are generated.
Thus, an image of 200*400 pixels finally has a size of 2*4 meters. Depending on the computational power, appropriate sizes should be resorted to.
Input Node for Selection
in Marionette
Posted
Hello GRZEGORZ,
i dont know the right translation. In German it´s called "Intelligentes Symbol". Attached you will find a file in wich i have done a short manual for you.
Kind regard,
Pascal Völz
Intelligent Symbol.vwx
