Hi guys,
I'm trying to dive into the BIM modeling to create a file for a house for the first time. I would like some help to well address some construction connections in-between some elements.
For instance, I have a slab that is normally composed by a structural element with 17cm, then a screed with 10 cm for filling purposes and also underfloor heating and then the finishing that can varies in between 2 and 3 cm. Until now, no worries.
I have managed to create the desired connection in between the exterior wall exterior component and the slab with the offset values so that the isolation could descend to the total thickness of the slab.
Nonetheless I've encountered two problems.
1# If I have a different finish in between two rooms, how do I resolve this? For instance, in one room the finish layer as 3 cm made with 2cm of screed and 1cm for some tile, and the other room is simple 1cm of cork and 2 of wood pavement. Do I need to create two different slabs? One for each area?
2# Normally the wall that divide this two spaces in my case is made of brick and it's supposed to be constructed directly over the structural slab, so it means that in my case this wall should descend 13 cm to connect with the structural core of the slab.
Can any of you guys tell me if you know how to resolve some of this issues?
Thanks in advance,
Bruno
