iswope
34 -
I'm looking to purchase a VR headset to visualize my Models. There are different options. I'm looking at the Quest 3S. How much memory do I need? I'm looking at the Quest because it sounds like they have the most integration with Vectorworks. Are they the best option?
I've noticed this since 2024 (Maybe more recent) When I navigate to a symbol through the symbol Browser and i am currently in Wireframe mode, or in a Sheet layer, I cannot view the symbol in shaded mode. In order to do so, I have to get out of the symbol, go to a shaded view on a design layer and then navigate back to the symbol. Seems like a bug
Multiple Resource Browser Windows.
iswope posted a question in Wishlist - Feature and Content Requests
I'd like to have access to two different folders at once without having to navigate back through the resource Manager. For instance, sometimes would like to have access to a folder of Textures and a set of symbols. so I don't have to go back and forth between the two. Other times, I am tagging items in viewports and I find I need to access a symbol, I navigate to the symbol and fix it. To continue my tagging exercise I need to navigate back to where my tags are. It would be nice if I could open two windows one with the Tags and one with the symbols. -
Thank you. That was one I should have figured out on my own, but I didn't. So, thanks! I should use this function more often, I'll have to add it to my Workflow.
after update, solid objects not obscuring lines anymore
iswope replied to iswope's question in Troubleshooting
In trying to troubleshoot this, I've found that this is a combination of this file and 2024. when I try to recreate this in a smaller file it isn't a problem. I would still call it a bug. -
OK, I'm running into this problem (or one very similar) all classes are on, I have pulled these cases out of the original file where I discovered this issue. While Editing the Group (notice machine screws.) After exiting the group. GONE! I've attached the file. Intro Cases.vwx
It's a 2024 issue. If I export to and open in 2023, it appears to work. Too bad, because I liked quite a few 2024 features. -
Just a heads up, The file is a bit over 700 Mb. The Elevation should look like the Top Image, but It looks like the bottom image. When I pull out pieces of the file and try to replicate the problem, it seems to do what it is supposed to. When I go to "Edit Section in Place" it looks correct. it also looks correct in Shaded. I admit I'm not great at keeping my working planes under control, but none of the problem Items here are screen plane. They are drawn on surfaces to represent Graphics. In the past they have been hidden by solid elements, they now show through. MT Model Copy.vwx -
I use dot dashed crossed lines to designate graphics in my models. At the last update suddenly they all appeared even if they are blocked by solid objects. this is obviously a major problem for me. Is this a setting I can undo?
Active Camera View - Walkthrough to adjust Keyframe
iswope replied to Elite Exhibits's question in Troubleshooting
I'm having this issue 2 years later. Has there been any explanation / Solution. It was working last Friday, but now it's Monday. I cannot adjust my walkthrough views. Restarting Vectorworks worked temporarily. -
VW Viewer needs to allow textures
iswope replied to Andy Broomell's question in Wishlist - Feature and Content Requests
I just had a client use a Viewer for the first time. I was surprised that they couldn't see the textures. If the viewer's main function is to show your work to the client, who often can't visualize very well, it seems that enabling textures is a pretty important feature to omit. -
awsome, that is a feature of Nurbs curves that I didn't know about!
BINGO! that sounds like the answer!. Thanks! Now, hopefully I will remember this the next time I need it!
