PMLA
    13
Everything posted by PMLA
  1. It seems I can no longer manipulate the plants tags except in the plant style editor which changes all of them. I cannot access them in the object info palette either. I used to be able to manipulate the plants in the object info palette. Now it seems I cannot. It is all grayed and inaccessible. Is there a setting I need to change? Thanks, Dave
  2. When I am using 2 monitors in extended screen mode, certain things disappear including the Resource Manager when in floating mode and every worksheet that I open. I have to go to duplicate screens to be able to see them. Anyone else have this problem?
  3. Jeff, thank you.. I was making the visualization change but having to replant them on my drawing. Your solution worked.
  4. My question about plant shadows is this. When pasting a plant on the plan, it may have a shadow from a previous setting. When I go to change it, it does not change on the plan. New plants have the correct shadow but I want to change all of the plants already in the plan. The Documents Settings are set and I have set all plant style settings to the document setting and gone in and changed the visibility setting to the plant style setting. Quite frustrating. VW2021 Landmark. I have also clicked the show shadow on plan button. Thanks.
  5. The Current View did not work but rasterizing did. Thanks.
  6. I am having the same problem with one sheet in my file. Did you find a resolution?
  7. Did you find a tutorial? I am trying to model a screen porch. Wes I could not see your example.
  8. I have tried to edit hatches, I.e. remove background, and my VW2017 crashes every time. I even make a duplicate with a new name and same problem. Any ideas?
  9. Benson, I tried your suggestion. Still cannot edit it. Here is the file with the one pasted line. It says it is a 3d polygon, so i tried converting to lines but the line segments are 8" long and do not show the dashed characteristic I want. I then tried converting to polygon, selecting wireframe rendering and could then edit and it seems to show the desired class style dash line type. I use Windows version 16. Thanks for you help.
  10. Thanks, I tried decomposing but it did not allow me to change the line type. How do I insert it not as a symbol? I merely imported the dwg and that is how it was inserted on a design layer.
  11. Thanks, I tried that but it did not allow me to change the line type.
  12. How can I change a complete survey from an AutoCad symbol into lines that I can edit? When I click the edit 3D symbol I can select the elements such as a contour line but I cannot change the attributes and it does not match the class attributes. Want to change from solid to dashed line for example.
