KBallantyne
  • Content Count
    16
Community Reputation
0 Neutral
About KBallantyne
  • Rank
    Greenhorn
Personal Information
  • Location
    United States
Recent Profile Visitors
  1. @Alex Sagatov How terribly exciting to know that my not knowing what I'm doing has resulted in finding a bug. My guess is that had I been working as I probably should have been, this would have quietly just continued to exist without any concern. At any rate, thanks for the help.
  2. Got it. Thanks. Appreciate getting me over the hump. K
  3. @Alex Sagatov Much appreciated. At this point I'm more concerned about being able to just make the thing print - it seems to have worked on my end. Just an aside, I don't see how you were able to get to find that the texture was on the None layer. When I click on it it shows being on a Dtl 2 layer (I know my layer control sucks, but hey). Would this be checked in the Resource Manager?
  4. @Alex Sagatov I'm impressed that I can mess simple things up that much. So, I'm simply going to make 'None' visible in the viewport and hope for the best for the time being. You'll let me know if there's anything more that I need in future, yes? Cheers K
  5. Alex - I thought it was uploading but it appears not to be. It's a 94MB file, does that matter? It seems to get only so far then just jams up. The progress bar on my browser has it stopped between the 'r' and 'w' on vectorworks in your address line (if that makes sense), and hasn't budged.
  6. I can do if you promise not to tear me apart for my incompetence.
  7. I've done all that. It's a texture for metal roofing that I have put a color screen over. I've got it on some sections I've done as well and they view just fine. It's rendered in OpenGL
  8. I have one sheet in a set that does not plot the texture map I added to an elevation. It shows on the screen but when it opens as PDF, it's not there. I have done the same procedure to my sections and they're fine... I don't get it. Any help is appreciated.
  9. I'll give it a go. Thanks. I would chase that for another week and still not think of it. Sometimes it's the easiest solutions and all it takes is to know what box to tick... Cheers
  10. I tried to upload it and it came pretty quickly to an error.
  11. If it didn't have a height it wouldn't show in 3D, which it does. Do you want the whole file to look at? I'm sure you'll consider it a mighty mess.
  12. First time using the curtain wall tool. I have modeled it in place and it appears correct in 3D but doesn't appear in the plan views. I've put it on its own class and have it on for the viewport - nothing. I've checked to make sure no components classes are shut off and I still have no idea how to get it to work.
