SGSF 42
30 -
Everything posted by SGSF 42
Hello Has there been any developments on this please? I'm still experiencing the issue... Thx, Scott
I can no longer get a pocket door to appear correctly on a Sheet Layer at Low detail level. Attached shows Design layer, Sheet layer at MED detail level, and the offending Sheet layer at Low detail level...
114 New Church Road EXISTING.vwxThanks Matt. Please see attached. Best, Scott
I can't get a cased opening window to display in plan. Also, there appears to be an additional wall panel as part of the window...?
Is there any update on a workaround for this? I can't send out drawings showing this!
Yes - restarted VW this morning and its functioning normally now. Thank you 👍
In 2024, I can't insert a symbol into a roof as a skylight. It inserts as a dormer (as per 2023), but there's no node to click on to change it to a skylight...
Does anyone know what the Vectorworks Web Helpers are which are running on my Mac? (see screenshot attached)
I’m looking to replace my 2019 iMac (3.2 GHz i7, 16 GB ram), as its getting a bit slow (I bought it refurbished from Apple 2 years ago as an emergency stop-gap!) Looking at the current range of new iMac’s they appear limited in terms of RAM and power, compared to the Vectorworks min recommended spec (Mid level User). Any suggestions for what to buy?
Here you are Matt The Whitehouse OPTION 5 rev A.vwx
Hi - this is still occurring when I open 2022 files. The 'move' 0.0 doesn't overcome the problem now either... 😕 The Whitehouse OPTION 7.vwx
Yes - just opened the file again this morning and its working!
Ah - Full break 'without' Caps - that's that part sorted - thank you
Thanks Tom - Curious they not test that before publishing? Seems like a pretty fundamental operation.
And does anyone know why when I insert a door into a wall, the wall junctions on said wall become mitered? (See screen shots before and after)
Hello I can't seem to control the appearance of my window in wall in VW 2023 The attached screenshot shows the window with details on (above) and off. With details on, the jamb lines are missing. With details off, the jamb lines are missing and the window looks nothing like a window... Any ideas?
2 Dyke Road PROPOSED.vwxHere you go Matt Thanks
Yes - the file was created in VW22. My concern was that this workaround needs to be carried out every time I open a previous VW22 file...
Yes - that workaround works. Thank you! Will this bug be sorted at next service pack?
Hi Matt No its definitely a wall issue. See the below 3 screen grabs showing shaded, hidden and wireframe...
I'm having same problem - very frustrating! Have to go back to VW2022 til this is sorted I'm afraid. 2 Dyke Road PROPOSED v2.vwx
I've a problem where VW 2022 (sp3) will not load on my mac (HS) laptop: I get a message as attached; I hit 'Close'; VW loads momentarily; then crashes. Any ideas?
I'm having trouble getting my elevation & section viewports to display wall edges and jambs in black since upgrading to 2022. The attached shows 2021 vs 2022. I've normally changed all pen line colours to be black in the section viewport class properties, but this has no effect now in 2022 - ie the wall edges and jambs etc show the class pen line colour (pink & red in the attached) and I don't seem to be able to override... Is there something I need to do to change this?
