Klaus Koch
34 -
Reputation
1 NeutralPersonal Information
Occupation
freelance planner
Homepage
cadplanung-freiburg.com
Location
Germany
Recent Profile Visitors
1,653 profile views
Thanks, this is my first try with AI Visualizer today. I'll test it again later.
All my efforts to create an AI-generated image end up in an endless queue. Can someone tell me what I have to change?
... oh, I only noticed after the post that Jonathan had already described the same solution.
Thanks for the help! I discovered the following: If, after placing the camera in the Object Info palette, I first select "activate Camera View" and then select "Link the camera", I get the desired view immediately.
Hello Bart, Sorry, I'm using that version 2024 Update 1 Klaus
When I want to create a viewport in vwx2014 from the camera, it creates an absurd top view perspective.
Ok Tom, you helpt me alot. Many thanks! Klaus
Editing the values in the worksheet wiil affect the Symbols in the drawing. Thats good so far! The original Symbol in the resource manager will be not affectetet.
I am talking about changing the values for multiple instances of those symbols.
I assigned a Record Format to a symbol and used the symbol multiple times. Is there a way to change the record format values in such a way that the change is automatically changed in all the same symbols? I can change the values in two ways, but it never changes all symbols!
face texture in workspace not available
Klaus Koch replied to Klaus Koch's question in Troubleshooting
I solved the problem and now I don't need support. -
Although an object is marked with different textures, in the object info palette the face texture is in my workspace not available. How can i fix this?
Dimension associations with 3d shapes and loci?
Klaus Koch replied to LarryO's question in Wishlist - Feature and Content Requests
Yes! This would be a great progress in terms of modelling and drawing efficiency! It is a recurring source of error after making changes in large models to update all dimensions in all sheet layers. Please answer the question from LarryO!!! -
For me changing the shortcut with the Workspace Editor solved the problem in the best way. Thanks
The shortcut does not work in a new blank document. I just tried your suggested solution, unfortunately it didn't change anything. I had previously changed the shortcut, which was also unsuccessful. I am working with a user workspace, but the command does not work in the preset workspaces either. I also had doubts about my keyboard, but it's not because of that either.
