Henrique Lauer
    19
Everything posted by Henrique Lauer
  1. Hi everyone Juan and Tom, I believe there are bugs with wall wrapping components. I can't say what exactly did it, although it seems the walls have an "own will behavior" about wrappings. Sometimes works fine and sometimes it is bizarre behavior.
  2. Tested today, If I try to create a Wall Frame in the 2024 version the Vectorworks crash 😕
  3. Hello, Yesterday I had the same problem as you described, the committing changes could not be completed. Now, i already started a new commited change then vectorworks are stopped at 55%. Seems the 2024 version was not completely tested before the launch. 😕
  4. @JuanP bellow there is one print of the bug and attached you can find the vwx file. SER-BLU-0723-BASE__lauer Copy.vwxSER-BLU-0723-BASE__lauer Copy.vwx SER-BLU-0723-BASE__lauer Copy.rar
  5. Hi Tom, I have tested in 4 different project files and I find the same problem.
  6. Hi everyone, my first experiences using the vw2024 if you add slabs modifies the slabs does not shows the correct plan view - if you add many slabs modiffies the view plan could be bizarre! Bellow you could see it with one simple modifier! general low performance! my setup : rtx 4090 / Ryzen 9 5950x16 core (32threads) 64gb + ssds and nvme doors and windows low performance bellow with one simple modiffier bellow without modifiers
  7. my first experiences using the vw2024 if you add slabs modifies the slabs does not shows the correct plan view - if you add many slabs modiffies the view plan could be bizarre! Bellow you could see with one simple modifier! bellow with one simple modiffier bellow without modifiers general low performance! my setup : rtx 4090 / Ryzen 9 5950x16 core (32threads) 64gb + ssds and nvme doors and windows low performance
  8. Hi JuanCarlos, thanks I used to attach IFC data by Resource Manager. After this, i used to put those symbols on my model. So, i have been realized wich when i create customs data, some symbols doesn´t appear in this customs property. I believe wich this is a bug, isn´t?
  9. Hi, I´m having some problems exporting custom symbols by IFC. First of all, when i create datasheet custom fields, they don´t appear when a try to use it with a custom symbol. Second, all my custom symbols don't appear in my model at Solibri. Have anyone trouble with custom symbols and IFC data? It´s driving me crazy 😬
  10. i´ve been problems when i try export pdf. The vectorworks 2020 crash! In my opnion, it´s as if the software ins´t ready yeat.
  11. i´ve been problems when i try export pdf. The vectorworks 2020 crash! In my opnion, it´s as if the software ins´t ready yeat.
  12. Love This! I loved it! But I only managed to use the path of the sun. The others, all attempts the vectorworks stops responding.
  13. Thank you all for the above help. Now I got the student version and I'm not able to open my old 2016 version files that are also student. Has anyone had a similar problem?
  14. Can I have access to a non-distributor version? In Brazil the version always takes time. thank you,
  15. On my page does not appear yet. I come in every day to check, I'm anxious to test this version
  16. The student version 2017 of vectorworks is already available for download?
  17. i vote: more speed in viewport update vray or iray would be amazing more speed with 3D complex objects more speed with autohybrid objetc more speed with complex objetc ( mesh, 3d polys ) creating walls through 3D objects ( convert a 3d objetc in wall ) some 3D tools C4D would be a dream in Vectorworks
  18. i´m architect and urban planner i live in Brazil. I teach vectoworks in cadtechnology. i´m user vectorworks since 2006, and love software. I new in community, and my vectorworks 2016 crash random to. My version is 2016 sp1, my currently OS version is: sorry about my english. 64 bits windows 7 16 ram i7 4790 64bits
