Henrique Lauer
19 -
Reputation
1 NeutralPersonal Information
Occupation
Arquiteto e Urbanista
Location
Brazil
Recent Profile Visitors
Hi everyone Juan and Tom, I believe there are bugs with wall wrapping components. I can't say what exactly did it, although it seems the walls have an "own will behavior" about wrappings. Sometimes works fine and sometimes it is bizarre behavior.
Tested today, If I try to create a Wall Frame in the 2024 version the Vectorworks crash 😕
2024 stacked on committing changes...
Henrique Lauer replied to drelARCH's question in Troubleshooting
Hello, Yesterday I had the same problem as you described, the committing changes could not be completed. Now, i already started a new commited change then vectorworks are stopped at 55%. Seems the 2024 version was not completely tested before the launch. 😕 -
@JuanP bellow there is one print of the bug and attached you can find the vwx file. SER-BLU-0723-BASE__lauer Copy.vwxSER-BLU-0723-BASE__lauer Copy.vwx SER-BLU-0723-BASE__lauer Copy.rar
Hi Tom, I have tested in 4 different project files and I find the same problem.
Hi everyone, my first experiences using the vw2024 if you add slabs modifies the slabs does not shows the correct plan view - if you add many slabs modiffies the view plan could be bizarre! Bellow you could see it with one simple modifier! general low performance! my setup : rtx 4090 / Ryzen 9 5950x16 core (32threads) 64gb + ssds and nvme doors and windows low performance bellow with one simple modiffier bellow without modifiers
my first experiences using the vw2024 if you add slabs modifies the slabs does not shows the correct plan view - if you add many slabs modiffies the view plan could be bizarre! Bellow you could see with one simple modifier! bellow with one simple modiffier bellow without modifiers general low performance! my setup : rtx 4090 / Ryzen 9 5950x16 core (32threads) 64gb + ssds and nvme doors and windows low performance
Hi JuanCarlos, thanks I used to attach IFC data by Resource Manager. After this, i used to put those symbols on my model. So, i have been realized wich when i create customs data, some symbols doesn´t appear in this customs property. I believe wich this is a bug, isn´t?
Hi, I´m having some problems exporting custom symbols by IFC. First of all, when i create datasheet custom fields, they don´t appear when a try to use it with a custom symbol. Second, all my custom symbols don't appear in my model at Solibri. Have anyone trouble with custom symbols and IFC data? It´s driving me crazy 😬
Bug Report - Layer stack order crash
Henrique Lauer replied to Sittingducks's question in Troubleshooting
i´ve been problems when i try export pdf. The vectorworks 2020 crash! In my opnion, it´s as if the software ins´t ready yeat. -
Weather Analysis Tools
Henrique Lauer replied to SBarrettWalker's topic in Resource Share - Marionette
Thanks!! i will try! -
Love This! I loved it! But I only managed to use the path of the sun. The others, all attempts the vectorworks stops responding. -
student version vs educational version
Henrique Lauer replied to dwbtd's topic in General Discussion
Thank you all for the above help. Now I got the student version and I'm not able to open my old 2016 version files that are also student. Has anyone had a similar problem? -
Can I have access to a non-distributor version? In Brazil the version always takes time. thank you,
- 7 replies
- batch print
- plugin
- (and 4 more)
