Marissa Farrell
Marionette Maven
  • Content Count
    1,282
File Comments posted by Marissa Farrell
  1. Halftone
       135    25
    1 hour ago, Hans-Olav said:
    I have tried to open the various files with version 2020 but always getting an error message. Anyone knows how to fix it?166432718_marionetteerror.thumb.png.2de13b1ac2d6e8a654eeba8f020f53d8.png
    I have a fix for this. Let me find the revised nodes and I'll get back to you.
    • Like 1
  2. @STERNontwerp
    I just wanted to jump in and say the move mode DOES work with groups, you just need to supply it with a 3D input. I also have a bug submitted to have this fixed in a later build.
    I do like the idea of a wiki, we just need to find the time and resources to get it going.
  3. Barn Door
       297    9
    @GatRed
    In general, planar objects in Marionette scripts will show in a Top/Plan view, and 3D objects will show in 3D views. 2D Objects created with Marionette are set to screen plane by default which allows the Marionette Object to display as a Hybrid object.
  4. Halftone
       135    25
    12 minutes ago, DomC said:
    I was not able to get a working url for Pillow with Vectorworks 2018 on Macintosh
    I also haven't found one yet, but most other libraries have been installing fine. I don't think this is a Vectorworks issue.
  5. Halftone
       135    25
    This is great and is actually identical to my first project with Image Processing! (I'll have to see if I can find a photo of my results)
    I can definitely help you out with some, if not all of your questions, if you can be patient with me! I'll have to look for my example on the averaging colors, I did some of that when I was working on my triangulation project, but I don't think I ever shared the network here because it was during the pre-release cycle.
    Give me some time and I'll get back to you on this!
  6. @Bertf
    When you click "Download this file" now you should have the option to download the 2018 version as well as the 2017 version.
    I haven't tested this version on Mac fully, but since it looks like you're running Windows it should be fine. Let me know if you run into any issues.
    • Like 1
  7. @Wouter van Boekel
    Yes, this file was created in 2018, so it has to be opened in that version or newer.
    I'm without Vectorworks until the 26th, but I can try to convert it into 2017 when I have access again and check if it works, or it's possible someone else can convert it back for you. I don't think there's anything special in this file that would prevent it from running the same in 2017.
