42 -
Everything posted by Janvin Lowe
Thanks for the insight - sure sounds like a mult-thread optimization issue - haven't looked too far into that but I'm sure they've got some verbiage about it, albeit probably just for the buzz though. As for Windows, I'm half torn on the performance of VW and the other half on my 2016 i7 MacBook Pro which wasn't cheap but at the price and at the time I got it for, could've netted me a PC book with a signficant spec-bump.
Thinking of investing in a Windows gaming machine (laptop for mobility) (as much as I really don't wish i had to) and to get VW on there to see if it's a MacOS vs Windows issue - I know Sketchup runs sigificantly smoother on PC's than it does on Macs (at least in my experience) so it might/can be the same for VW?... can only try to find out.
Are these instances of slowness witnessed on both Macs and Windows PCs? I'm on a Macbook Pro 2016 and have really been acknowledging the bang-for-the-buck price points that are out there for the Windows OS machines. What kind of hardware are you guys running?
Just a small potato design firm that has decided to unsubscribe from Service Select and have yet to install VW 2019 - with my 2016 i7/16GB/500GB MacBook Pro, I've come to the realization that it's not just my MBP that may be the hindrance but with the amount of similar complaints of the lag and slowness of the app, that it's got to do a lot with the software itself - sadly I don't even utilize the Architectural license to its fullest as I was put off by its 3D workflow so with just a 2D workflow in tow using multiple files (Plans + Sections/Elevs) to keep things lighter, I'm slowly winding down VW as the go-to app and migrating to the Sketchup/Layout workflow, not because it's any better, but just because things just seem to go a lot smoother without the migrane-inducing lags experienced in VW and for a lot less $.
Hi, Just wondering if anyone is experiencing why the heliodon 2D graphic is not showing up in my design layer (one created just for it). It just appears as a VW node (ie. blue dot) and still editable via the OIP. If there's something I've got disabled, please let me know - thanks! Janvin VW2018 SP3 2016 Macbook Pro
3D lines are a real struggle for me
Janvin Lowe replied to Gert Sanner's topic in General Discussion
@markdd is there a quick way to toggle on/off that pink square that indicates current working plane? -
Arrowhead with polyline tool created in tangent mode is not aligned
Janvin Lowe replied to Janvin Lowe's question in Known Issues
That was weird as it happened right before my eyes as one moment it was done properly then the next line it went buggy. Hope its in VW's bug database and thanks Kevin for the workaround. -
Janvin Lowe posted a question in Known Issues
Hi guys, I think I accidentally toggled a mode on/off for the endpoint line type because now when I give a polyline a leader arrowhead, it's not behaving as it should. Attached are images of what it should be like and the other is what is currently happening. Restarted VW but haven restarted the comp yet. Any clues? Thanks in advance! -
Andy! Thank you for that quick tip - I'm curious why that isn't set by default. And that last checkbox (Merge Structural Objects with Same Fill) sounds pretty handy! Thank you once again Andy!
Boy, I'm new to this section viewport business so I have to apologize for this question - it's so frustrating not knowing how to enable the components in my walls to simply show in my section viewports - it's currently displaying my section's walls and slabs as single entities. I know it's something simple but then again, transitioning to this bim workflow seems to be nothing but an uphill fight. "help me VW community, you're my only hope!" thanks!
@Kevin McAllister Thanks Kevin - I'm guessing it's just something which VW assumes either users will just get use to using as-is or just call up the command 'full-time' with Shift-C combo - I'm coming from a Sketchup background and their Shift + middle mouse button is the perfect combination. It's a stretch but here's, hoping they add that bit of code to VW 2019...
- 10 replies
@markdd thanks again Mark - that's too bad, it's a really handy keyboard shortcut to have but the 'control' key is definitely awkwardly placed on the keyboard - first world problem. @Christiaan thanks for the reply Christiaan - the keyboard shortcut to the actual flyover tool is not what i was looking to change - thanks tho!
- 10 replies
Hi Mark, thanks for the prompt reply. Perhaps, I can clarify my question: yes, I know control + middle mouse button initiates the flyover tool (temporarily) but I'm asking is there a setting in VW that allows me to use/assign another key other than the 'control' key for this function.
- 10 replies
Does anyone know if there's another key I can use other than the default "control" key + middle mouse button to initiate the flyover tool "on the fly" (ie. without formally clicking on the flyover tool (Shift-C)). Thanks!
- 10 replies
VW 2015 - Disk drive or file is marked read-only
Janvin Lowe replied to jonathan.etchells's topic in General Discussion
bjoreka, Have had this issue for quite some time but just have recently come across your comment to the issue, particularly, connecting via SMB vs AFP - you're probably migrated over to your new storage solution, but can you recall if SMB connection was the fix at the time? I've just started connecting via SMB (was AFP in past), so just curious - will definitely post my results if I stop getting those "drive mared read-only" messages. Thanks bjoerka! -
Vectorworks Fundamentals 2016 - also goes for VW 2015 - appears that the keypress shortcut for the Classes and Layers dialog boxes fail to work no matter what I set them up to be in my workspace... currently and I believe by default it is option+command+C for Classes and option+command+L for Layers. Anyone else?
Hi all, Just installed VW2016 Fundamentals on my 2012 Mac Pro (very exciting) and here are a few initial issues on the UI that hopefully can be addressed in a service pack down the road: 1. Docked windows to toolbars - alarming when noticed, by default, I couldn't view 2 or more separate VW drawings (on a 2nd monitor) simultaneously - does anyone know why anyone would want this option? - there's got to be a reason. See the following link for how to resolve this: https://techboard.vectorworks.net/ubbthreads.php?ubb=showflat&Number=218993&Searchpage=1&Main=43650&Words=undock+palette&Search=true#Post218993 2. This is what I consider one of OSX's great non-advertised features that suddenly stopped working in VW 2016 - guessing it might be due to their tinkering of #1 above... this feature: when you have a drawing file open, typically you can place your mouse over the filename in titlebar of the window, hold down the command key (⌘) + click on the filename, and a menu-like drop down will appear showing the path of where the file is saved; releasing the ⌘key and mousing over any of the folders listed and clicking on any of the highlighted folders will open a Finder window of that selected folder. 3. This last one so far, is a carry-over from VW2015, whereby (especially when you have 2 monitors), when your app focus is on another app other than VW2016, then you accidentally pan (using the middle mouse scroll button or other) your VW drawing without gaining app focus first, locks you into the panning of your drawing even if you've let go your pan button - if you proceed to gain app focus back onto VW, and press the X key to cancel the function, you essentially surrender your session of VW as all keyboard shortcuts and drop down menus fail to work making you shutdown/restarting VW the only resolution. Now, I understand these are simply UI things that may appear minute in the whole scheme of the newly rebranded VW2016 but I think UI / UX are keys to the success of any app out there...
