Patrick Winkler
    225
Files posted by Patrick Winkler
  1. Points along Object
    This script converts the provided object into a NURBS and puts X points alog it.
    240 downloads
       (0 reviews)
    0 comments
    Updated
  2. 3D_Polys_to_2D
    This little script flattens all the 3D Polys in the drawing to 0 and converts them into 2D polys without removing the attached database.
    3D_Polys_to_2D_VW2017.vwx
    94 downloads
       (0 reviews)
    0 comments
    Submitted
  3. Hexagon Grid / Honeycombs
    Here is a wrapper for creating honeycombs.
    99 downloads
       (0 reviews)
    0 comments
    Updated
  4. Print Node
    This Node makes debugging more comfortable especially inside wrappers.
    You can select weather if the incoming values will be printed into a text object right under the node or into the python console.
    Time of the execution and type of the items can be printed optionally. I integradet the object type list from the appendix site to translate the type id into a string ( 5 = Polygon... )
    You can also define filter conditions as Python statement in the oip of the node. Variable X is replaced by the  values. Check out the example in the VWX.
    156 downloads
       (2 reviews)
    0 comments
    Updated
  5. Natural color spectrum
    In this example you can find a node that returns a spectrum of colors and a Wrapper for creating random 3d Points.
    Saturation and Brightness can be changed in the OIP.
    Color_Range_Video.mov
    36 downloads
       (0 reviews)
    0 comments
    Updated
  6. Simple Customizable Shelf
    This network creates a simple but highly customizable shelf.
    448 downloads
       (0 reviews)
    2 comments
    Updated
  7. Hedge Along Path
    This Marionette Script creates a simple Hedge along a path.
    new Wrapper:
    'Print Point Order' - helps you to orchestrate streams of points.
    133 downloads
       (0 reviews)
    0 comments
    Submitted
  8. Vertical Blinds
    This Marionette Network generates vertical blinds.
    Nearly every part of the blinds can be modified by the parameters.
    Usage comments:
    - Put the Symbol 'Vertical Blind' into your drawing.
    - Now costumize it to your needs with the parameters in the object info palette:
    Total Length, Slat Height, Slat Width, Slat Angle and more
    (A Video will follow)
    - Finally you can define textures for parts of the slat by the generated classes:
    VerticalBlind-Slat
    VerticalBlind-Slat_Backing
    VerticalBlind-Rope
    VerticalBlind-Fixture
    VerticalBlind-String
    VerticalBlind-Beads
    Thanks to Dom for the PutByRefNode which made it a lot more easy.
    165 downloads
       (0 reviews)
    0 comments
    Submitted
  9. Labyrinth
    This script generates labyrinths. Just for fun.
    78 downloads
       (0 reviews)
    0 comments
    Updated
