fabrica
    325
Posts posted by fabrica
  1. the new handles for setting image size in 2021 are even worse than previous versions , my mouse pointer needs to be a good 20mm from the actual line for it to work, + the scale line is smaller than ever, handles at each end of line smaller and only right seems to be selectable,   its way to hit and miss at moment.
  2. @Jonnoxx i didn't know about blender BIM, this on their wiki made me laugh =: "A small commercial building project was first designed in Blender. We were then faced with the task of remodeling it in Autodesk Revit. We figured it would be easier to build an entire BIM application and construction documentation tool from scratch rather than face the pain of remodeling it in Revit. It turned out that it was."
    as for vectorworks 2021... due to the last couple of releases I'm resigned to having low hopes , seems too many of the tools are reliant on third parties or abandoned after first release.
    The marketing version will be good though!!
    • Like 4
  3. I normally use the dissolve or melt option to try and get a single polygon - but its generally a mess of triangles by vectorworks, anything curved or circular is worse!
    I gave up on arnold because it was too complicated for my needs,   How do you find it? Do you have any images you could post?
    • Like 1
  4. I cannot figure out how to get the size of a steel (wide flange 3D) into a new data tag , looking to make a simple tag with steel size and length ?
    Can get the length ok but not the size (ie. the 203 x 203 x 46 part)
  5. @TomWhiteLight you have to say that !   😀
    but there's no way renderworks will ever have the ability or features of vray or corona etc , and all the associated plugins with those. (and nor should it as thats not its function)
    I like renderworks btw but its not for the high end arch viz renders some clients want.
    you just can't do in renderworks the examples from here:  https://corona-renderer.com/forum/index.php?board=3.0
