fabrica
309 -
Posts posted by fabrica
ah, understood, I normally wouldn't go from C4D back to vectorworks for renders.
My preferred method is to use a basic color in vectorworks for each material so I can isolate it quickly in C4D, ie <select texture tags of object> and change all materials at once to C4D one - I can't recommend Corona for C4d enough - really simple to use and good results, currently a free beta...
this would be a great integration , https://www.allegorithmic.com/architecture , seems to be taking off in all render engines and I use it in C4D
- 2
why?! Why?! WHY !!!!!!!!
what benefit (purpose) do you get in going from C4D > Vectorworks with materials?
that Archicad video is depressing to watch... !
While the yearly C4D ports to Vectorworks are nice , the bread and butter also needs constant attention - the first thing you use on each job .....windows, doors and stairs...
- 1
23 minutes ago, JimW said:
It would be good for experimentation sure!
Feature abuse is always a fun pastime, haha. I'm currently in the process of making christmas lights with the Foliage tool to see if that works, might turn out badly but I never know until I break the rules.why isn't foliage available in vectorworks architect?
good source for Materials = https://www.poliigon.com/home , also I really would recommend substance https://www.allegorithmic.com/products/substance-source , these can be plugged directly into C4D.
quick tips = https://www.youtube.com/watch?v=-CyUjCQAWw8&list=PLg8gGXlcb1Dq0xiJz9tfG49XwgKKpJZ-v
there are a number of 3rd party render plugins for C4D - for arch viz I recommend Corona - currently a free beta - really easy to use , https://corona-renderer.com ,
- 2
had a go at importing the following sink : https://bimobject.com/en/ceramica-catalano/product/catalano_basin_zero_100x50_cod_110ze00 in revit form.
A mess, 2018 was really slow and unresponsive after importing + very , very slow to import also.
Nice ! ...........just the new window and door tools to tease next week so!
agreed, C4D integration with vectorworks works very well, once you get a system that works for you.
GPU rendering coming to C4D in next release (September I think)
http://www.amd.com/en-us/innovations/software-technologies/radeon-pro-technologies/radeon-prorender
Another option is the framing member tool, you can use custom profiles , is parametric so you don't get all those 'extrude along path' lines in plan view, does a mitred joint neatly. Bit more work involved than EAP but can be quicker for later alterations.
they really need to update door tool with custom architrave profile option.
18 hours ago, sbarrett said:
Hello @NikF
I just tried inputting "Vienna" into the Temperature Chart and it seems to work. The address locator is similar to Google maps - it takes a lot of different input formats.
The precipitation one doesn't seem to work with European Cities /Countries , all the others do? i.e., typing Rome in Temperature object works but not in precipitation....
the bim object app is in the furniture/fixtures menu - you need to add it first with the customise tool.
the sketch import was not worth it on the small test I did - the model came in as a messy wireframe symbol (uneditable), stayed wireframe in 3d also.
probably just works on the few vectorworks models that were already on the bim object website.
would be great if these could be saved as objects to the resource manager, not sure if they can be made into symbols and then 'unboxed' as needed?
does the elevation of your layers effect web view? I am only getting the blue screening web browser with nothing in it?
2017, it seems to be the 1 file only, attached window from file that causes the crash, I also got this message when trying to save it.
I can't seem to use the custom window tool settings without an instant crash, can select custom then once I click to edit .... a full quit crash.
Ah! I was right clicking in the left hand column not the next one over.
thanks!
- 1
Is it possible to delete folders from resource manager for projects ? i.e.. I can delete individual symbols fine but can't delete empty folders?
WinDoor (or similar) for all
- 1
can this be used in conjunction with stair tool? i.e. I see I can set a custom handrail for the railings but there is no similar option in the stair tool or is there a work around?
looks very good Alan, great for workflow, well done.
I've no marionette knowledge but is it possible to add a fill to the extrude so in plan view it reduces the amount of lines visible? (a problem with all EAP objects) If that was possible it would be brilliant and also great for skirtings and cornices !
Vectorworks 2018 - Service Pack 1
in General Discussion
Posted
when I click the dmg file , I get the Dropbox Installer window above with nothing in it.
If i close this and check in finder , I see Vectorworks 2018 Installer mounted but nothing happens when i click icon.
