Issue with line rendering when exporting/publishing to a PDF. Lines (curves/arcs mostly, but really anything not in the X/Y plane) only render/publish at one resolution and are not vectored when viewing as a PDF (i.e. display on screen is choppy at full page or even 100% view and zooming in only makes it much worse).
Is there a way to avoid this so a PDF will recognize the lines as vectors and not as raster/bitmap (like how a design layer keeps updating when zooming in/out)? Upping sheet DPI helps a little, but even at a very high level (say, 1000 DPI) curves/arcs are still very choppy and uneven (appears like there are different line thicknesses, etc.)
I've received PDF's from others published via VW and when viewing them on a computer screen, they remain vectors, sharp and detailed at just about any level of zoom/page layout.
Lines are all at .05, and trying to use only wireframe only (no other background or foreground render). For reference, sheets/publishing are 11x17 and below (down to 8.5x11) for printable/scaling/collaborating needs.
Thanks.
