236 -
Everything posted by jblock
@bjoerka can you contact Technical Support directly and upload a copy of the PF with the large metadata so we can investigate? https://customers.vectorworks.net/support
Hi @Hanna N are the layers all at the same scale? What are your Class Options and Layer Options set to? Can you send me a copy of the file so I can determine what is happening? Thanks!
- 1 reply
- 1
@MatharchiI usually recommend using Shaded render with colors and textures turned off and Draw Edges on. That will give you a similar look to Hidden Line, but with Shadows. You can also use an Artistic or Custom Renderworks style in the background with Hidden Line applied to the foreground.
License manager running on a virtual machine
jblock replied to AndrewRC's question in Troubleshooting
@AndrewRCDepending on your license type and configuration, we may need to make a change to allow it to run on a virtual machine. Can you submit a support request using the form on the Customer Portal so you can work directly with our technical support team?- 1 reply
- 1
@ShortnortMy best guess would be a graphics card problem. Is there an updated driver for your graphics card on your system? Were you able to edit textures before on this machine?
@Daniel OKaneHave you tried opening the PDF in any other viewer, like Acrobat? Can you send me an example PDF so I can investigate?
Hi @JacquiBCan you send me a copy of the file so I can investigate? Thanks
https://release.vectorworks.net/nnapub/updaters/29/NNA/eng/meta/releasenotes/Update1.html
Silent Install for Vectorworks 2023 pointing to license server.
jblock replied to UniStuff's topic in General Discussion
@UniStuff You will need to customize the logindialog.xml and distribute that file onto the client machines. There is no way to specify this during install. Here is an article that should be helpful: -
@swcreativehere is some additional info on Update 1:
@techdefThis would typically be seen due to unsupported hardware or bad GPU drivers. I sent you a DM asking for more info. Thanks!
@Dan borg this issue has been submitted to our engineering team so they can evaluate and fix. Thank you for reporting it here.
- 1 reply
- 1
While troubleshooting, Vectorworks Technical Support may require you to send in your Updater log files. Those logs contain information about the update process, as well as hardware and OS information from the machine Vectorworks is installed on. Listed below are the steps on how to find these files so they can be provided to Vectorworks Technical Support for further troubleshooting. Windows: 1) Open File Explorer and click "This PC" on the left column. 2) On your main hard drive (Normally your C:\ drive) C:\Program Files or C:\Program Files(x86) you will see your "Vectorworks 20XX" folder, where the XX may differ depending on what version of Vectorworks you are attempting to install. 3) Open the Vectorworks 20XX folder and find the "UpdaterLog.txt" file. If the installation did not complete successfully, there may not be an installer log present, and in this case, the Technical Support team would need an installer.log file like the ones in the example below. These files can be found in: C:\Users\Username\AppData\Local\Temp NOTE: The AppData folder may be hidden, so you will need to click on the View menu in the File Explorer window and enable "Show hidden Files" in the View Ribbon. ----------------------------- macOS: 1) Click the Finder icon on your dock, then select Applications from the list on the left. 2) Inside the Applications folder, you will see your Vectorworks 20XX folder, where the XX may differ depending on what version of Vectorworks you are attempting to install. 3) The “UpdaterLog.txt” will be inside that folder (Vectorworks 20XX). If the installation did not complete successfully, there may not be an updater log present, and in this case, the Technical Support team would need an installer.log file like the ones in the example below. These files can be found in: Macintosh HD\Users\Username\Library\Logs NOTE: On current versions of macOS, the Library folder for your User account is hidden by default. The easiest way to display it is to open Finder, then hold down the alt/option key on your keyboard while clicking "Go" from the menu bar, then selecting "Library"
While troubleshooting, Vectorworks Technical Support may require you to send in your Installer log files. Those logs contain information about the installation process, as well as hardware and OS information from the machine Vectorworks is installed on. Listed below are the steps to retrieve these logs so they can be provided to Vectorworks Technical Support for further troubleshooting. Windows: 1) Open File Explorer and on the left side column, click on "This PC". 2) On your main hard drive (Normally your C:\ drive) C:\Program Files or C:\Program Files(x86) you will see your "Vectorworks 20XX" folder, where the XX may differ depending on what version of Vectorworks you are attempting to install. 3) Open the Vectorworks 20XX folder and look for the "InstallerLog.txt" file. If the installation did not complete successfully, there may not be an installer log present, and in this case, the Technical Support team would need the log file called “installbuilder_installer.txt” which can be found in: C:\Users\Username\AppData\Local\Temp NOTE: The AppData folder may be hidden, so you will need to click on the View menu in the File Explorer window and enable "Show hidden Files" in the View Ribbon. ----------------------------- macOS: 1) Click the Finder icon on your dock, then select Applications from the list on the left. 2) Inside the Applications folder, you will see your Vectorworks 20XX folder, where the XX may differ depending on what version of Vectorworks you are attempting to install. 3) The “InstallerLog.txt” will be inside that folder (Vectorworks 20XX). If the installation did not complete successfully, there may not be an installer log present, and in this case, the Technical Support team would need an installer.log file like the ones in the example below. These files can be found in: Macintosh HD\Users\Username\Library\Logs NOTE: On current versions of macOS, the Library folder for your User account is hidden by default. The easiest way to display it is to open Finder, then hold down the alt/option key on your keyboard while clicking "Go" from the menu bar, then selecting "Library"
@Benson ShawThis is an internal system that our development team uses to track bugs and enhancement requests.
@Kevin McAllister @E|FA I appreciate your feedback. As always, I am working to improve our communication and to make the process more transparent. I hope to have a better solution for both the bug submit form and the support request form in the near future.
To clarify, the bug submit form has not been abandoned. Please continue to use this form to report bugs. We are working on re-tooling this form so that it can be easier and clearer to use, while also being adaptable to changes (like OS versions) on the fly. It is typical of bug submissions not to receive any reply unless further information is needed to replicate/investigate the bug.
Vectorworks 2021 license server adress for all users ?
jblock replied to CedricJ's topic in General Discussion
@IcKxSyS yes, this would still apply for Vectorworks 2023. Please contact Technical Support by submitting a Support Request on the Customer Portal so we can help. -
When using a Site Protection Server license of Vectorworks (Series G), the client machines will present the user with a Login Settings Dialog upon launch. This dialog will determine how the clients look for the Site Protection Server machine on the network, and what product(s) the user wishes to use. By default, the connection is set to "Automatically find servers", which can be useful to automatically connect if the clients and server exist on the same subnet. If not, you can specify the IP and Port. The login dialog can be pre-populated, and even hidden, to require minimal input from the users. After launching on one of the client machines and connecting to the server, a “LoginDialog.xml” file will be created in the following location: macOS: /Users/YOURUSERNAME/Library/Application Support/Vectorworks/20XX/Settings/SeriesG/ Windows: C:\Users\YOURUSERNAME\AppData\Roaming\Nemetschek\Vectorworks\20XX\Settings\Series G Copy this file and move it to the following location (you may need to create this SeriesG Folder): macOS: /Applications/Vectorworks 20XX/Settings/SeriesG/LoginDialog.xml Windows: C:\Program Files\Vectorworks 20XX\Settings\SeriesG\LoginDialog.xml The login dialog settings should now be read by all user accounts. You can configure the .XML file first to pre-populate the IP and port values and even hide the login dialog on launch. (To disable the login dialog from showing during startup, set the DontShowAtStartup value to 1.)
@zoomerVectorworks will not prevent you from saving your work before shutting down, in the event that the license is running on multiple machines at the same time.
@salukitdWhen Vectorworks prompts you with this alert, it gives you the opportunity to save your work before shutting down. Additionally, you will only be prompted on the machine that had Vectorworks open first. For example, if you have Vectorworks open on your office machine and forget to close, then go home and open Vectorworks on your home machine, you will be able to work on the laptop without problem. Upon returning to the office, you will see that Vectorworks has prompted you to save your work and shut down. This is built specifically to allow you to continue working in the event that Vectorworks is accidentally left open, you will not be out of luck.
@domer1322you can right click on the folders in the Resource Manager and choose to Download and Install. Additionally, you can right click on the "Vectorworks Libraries" header and install them all at once there. You can also choose to download the packages by clicking Help>Download Content. If you cancel your Service Select subscription, you would lose access to any of the Premium Libraries that have not been stored locally, among other benefits.
Layer stacking order not exporting correctly - VW2023
jblock replied to sab's question in Troubleshooting
@sab Yes, this is a known issue that we are investigating. We hope to have this fixed in the next Service Pack.- 1 reply
- 1
Vectorworks Site Protection Server has stopped working now
jblock replied to brian.harry@cssd.ac.uk's question in Troubleshooting
@brian.harry@cssd.ac.ukI will have someone reach out to you shortly to resolve. Thanks! -
Hi @brian.harry@cssd.ac.ukI see multiple .lic files listed, which will cause problems. In this scenario, there should only be one (license.lic) that is generated when you enter the activation key. Can you revoke the other license files and see if that helps? If not, please reach out directly to uktech@vectorworks.net so we can troubleshoot. Thanks!
