32 -
Everything posted by JoshP
Project Sharing Server Setup - Docker Container
JoshP replied to JoshP's topic in General Discussion
@matteoluigi In order to help narrow down the issue, I think it's a good idea connect directly to the machine and run the docker command manually as I mentioned above, just to see if it will work. If it works then there is likely a configuration issue with portainer. A side note, I have not tried running project sharing myself on a Rpi, but I would imagine you will end up with far less than an optimal experience. -
After looking into the symbolized crash report I see a few things that jump out to me. First is that we appear to be using Project Sharing server. If this is the case, is this running each time you see the crash? It also appears one of the last actions taken was to click on a notification, do you interact with the Notification Center at all? Perhaps the development team could make use of this.
Setting up and Understanding Project Sharing - Docker What is Docker? When it comes to understanding docker, think of a shipping container, and it's cargo. The shipping container represents your main operating system (The host), and the cargo are containers (operating systems within the host) This means you can have a number of different operating systems running within another operating system, and the two can communicate using specified means set by docker but are otherwise oblivious to one another. An example of this is you can have Windows 10 running as a Docker Host and have an Ubuntu Linux system running as a container. However will not need to worry to much about the inner workings of what docker is and how it works. So let's jump into setting up Project Sharing With your installer media you will have a zip file for the project sharing server. Within that zip you will find installation instructions. The point of this post is to expand on those instructions. In order to follow these instructions you will: Have access to the host you plan on deploying this software to (should be an always on machine) Have Docker installed and running Have some working knowledge of a command line, however nothing in here should be difficult to grasp The Project Sharing Server Setup Make sure you are connected to the host and have the project-sharing-server.tar copied to your host Loading our Docker Image: docker load -i ./project-sharing-server.tar Breaking this down we are telling `docker` to `load` the `-i` input of `./project-sharing-server.tar` file Confirm load is successful: docker image ls -a You should now se something like: REPOSITORY TAG IMAGE ID CREATED SIZE project-sharing-server latest 657e01b1dc11 2 months ago 85.2MB Running our container: I will be running you through two variants of this command, one will be the command line and the other will be using a helpful tool called docker compose. However in order to get up and running, only one method is required. Via Command Line: docker run -d --env L=1 --name ps-server -v /your/local/storage/location:/usr/psserverd/Projects -v /you/local/storage/for/logs:/usr/psserverd/log -p 22001:22001 project-sharing-server:latest Let's reformat this into something easier to understand docker run -d --env L=1 --name ps-server -v /your/local/storage/location:/usr/psserverd/Projects -v /you/local/storage/for/logs:/usr/psserverd/log -p 22001:22001 project-sharing-server:latest From the top down here is what we are doing: We are telling `docker` to `run` a new container that is `-d` detached from our command window with the `env l=1` environment variable L equaling 1 for dockers logging of the container Then we tell our container that we are attaching two volumes to our host noted by the `-v` followed by the location of the folder on the host FS then a colon to tell docker everything after that is the file system within our container an example of this could be -v C:\Storage\Projects:/usr/psserverd/Projects So here we are storing all the files and folder that get created in /usr/psserverd/Projects on our C drive in Storage\Projects The /usr/psserverd/Projects directory is the directory that usually contains your existing PFs, VWX, PDFs, PNGs, etc. Next in order to connect to our new server we need to expose it to the outside world using the ports signified by the -p. Now when we want to use this we connect to our host on port 22001 and it will pass the traffic to our container Like our volumes, we have two parts, our host port and our container port. Where the container port cannot change, we can change the host port. so wee could say if we want to connect to our server on port 21035 we would type -p 21035:22001 then any time you want to connect to the project sharing server you would use your host IP with the port 21035 Last up in the image we are using, this is the image we loaded previously and all we do here is call it to be loaded Via Docker Compose: This is the method I personally prefer as it will mean that all your settings are saved to a file so you don't have to remember everything This method uses a file called docker-compose.yaml, this will be a new blank file in your host that you will fill out with all the right information A special note, the use of the YAML format means that spacing has meaning, so be sure to use the same spacing everywhere, I personally just press tab as you will see. #docker-compose.yaml version: "3.9" services: ps-server: image: project-sharing-server:latest container_name: ps-server ports: - 22001:22001 environment: l: 1 volumes: - /path/to/host/project/storage:/usr/psserverd/Projects - /path/to/host/log/storage:/usr/psserverd/log Now all we need to do is in the same directory as this new docker-compose.yaml file we type in docker-compose up After you have your container up and running you can check the status of it by running docker container ls -a Please note that these are not official instructions and is intended as a jumping off point with the most basic setup. There's a vast amount of tutorials and documentation surrounding docker and how it operates.
Hello Carl, You can achieve this by creating changing the color of the texture to black, setting the reflective option to plastic with the following options: - Color: ~ 80% (dark grey) to black - Brightness: ~40% - Roughness: ~10% - Reflective: ~ 10% Then play with the bump map, but keep the strength between 3-10% and the scale to about 300%... I have attached two variants to show you the types of end results. Please note that you need to have renderworks active in order to gain reflections
- 1 reply
- 1
I have attached my own approach to lighting along with the renders, explanations, and project file. There are many different ways to get lighting just the way you want. My example only illustrates my own method. Archive.zip
Before adding more lights, see what happens if you go into your render style and in the lighting tab change the ambient color to black while using 16 bounces. This will darken the scene but still give you smooth results. In the mean time I too will be looking into using 8 bounces.
As for the HDRI you are mainly looking for any HDRI image with from within VW or on the web that does not have a strong spot in the sky. If there is a haze around the sun, that will soften the shadows it casts.
- 15 replies
- heliodon tool
- interiror
(and 1 more)
Tagged with:
Another thing to keep in mind is that you have shadows coming from multiple exterior sources. The Heliodon and the HDRI image. If the HDRI has a sun spot in it, it will cause highlights and shadows like you are seeing. Be careful which HDRI you choose as to not overlap, try something that either has a hidden sun, or overcast.
- 15 replies
- heliodon tool
- interiror
(and 1 more)
Tagged with:
One method to change the scale of a texture on sub division is to apply the texture. Once applied, go to the resource manager and right click > edit on the texture you applied. You will then see a size option in the lower left corner. Downside: This will affect all objects with this texture.
Another good source of textures that I have used in the past is from https://www.textures.com/
As promised, here is a different scene that was set up to be a lighting example. I have included an image of the end results of each steps with a description of each. I have also included the Vectorworks file itself VW 2017 so you can poke around and look at the settings I used. When looking at this, pay close attention to the render times. These render times were based on a workstation laptop I'm using, so desktop results should overall be better. Render: https://www.dropbox.com/s/1l12onl9846o0qi/Bedroom.png?dl=0 (Too large to paste in here) Bedroom.zip
I have used a multitude of different rendering application including VW (C4D) Mentalray, and Render man. My advice to you is that it is less about the software and more about your abilities. It does take time to render photo-realistic, or even close to it in any application you choose. This render was made from start (new scene) to finish in about 3 hours. This was made using only Vectorworks 2017 and getting textures online to fit my needs. I will post a follow up commend that outlines my lighting technique that may help you in the future.
