djobbins
60 -
Posts posted by djobbins
Hey, I'll have to check, I think I am using symbol mode. But, even with detailed geometry I don't think it explains the level of sluggishness I get when I try to populate an array. The whole drawing bogs down to crawl even for non-speaker related actions. Not to mention if I move the array it will often repopulate with the speakers in the wrong place etc. This has been since at least v2020.
I don't have size issues with any of the other dialogues that I used on a daily basis, it seems specific to the audio array tool
Hey all! I'm pretty sure it's nothing I'm doing in particular but it seems like the speaker array tool is jus doesn't work. As soon as I create an array in a drawing it bogs down like crazy if I have to make even the smallest adjustment to it (nudging it, rotating etc). Even the array configuration window opens up with some elements beyond the edge of the screen so I can't click on them. What gives?
Hey all,
I've been a theatrical/event lighting designer for a while now, but I've been transitioning into more architecture and landscape lighting lately. I'm trying to wrap my head around the photometric grid and photometer tools in spotlight. I was wondering if there was a way to export the information from them into a report? I'd like to be able to show min/max footcandles, average, etc for a given area. I assume if I pull the data into a spread sheet I can just build some formulas to do the mathematics, but I'm not sure how to get the data for each point into a report.
Hey guys,
I was wondering if anyone had tips/tricks for using VW for lanscape lighting. I'm crossing over from Spotlight (posting in that forum as well). I've been using VW for years, but am pretty new to the outdoor lighting portions.
Hey gang,
My version of 2020 seems to crash semi-consistently when I am in an RW camera and want to switch back to a top/plan view. Anyone else noticed this?
Hey guys,
I'm trying to use the Duplicate Along Path tool to add some lights to a circle truss. I'm working in the schematic view, and I swear this has worked before. When I use the Preview tool from the Duplicate Along Path it looks correct, but when I click "ok" the final product looks more like the "duplicate array" tool.
Screen shots below of how I have it set-up, how it looks in preview, and the final product:
Hey Pat,
Right now I have it set as: =('Lighting Device'.'Inst Type'), which I just copy and pasted from the SL Inventory Worksheet (where it works fine). Am I missing something else?
Dan
Hey guys,
Returning to this topic from a while back. I have my symbol counting worksheets up and running, but it can't seem to handle lighting instruments in. If I drop a light in as just a symbol it will come up fine in the worksheet, but if I drop in a lighting instrument it doesn't. It works fine if I use the inventory spreadsheet that the "create reports" tool makes, but I can't get it to work within mine. Any thoughts?
Dan
Hey,
I have not tried these. Are they only available as a purchase through your site?
Dan
Hey guys,
Any advice on how to create a scrim object that really behaves like a scrim? I.e. Opaque when lit directly from the front, but see through w/ light sources behind it? The "scrim" setting for softgood seems to just create a semi-transparent object, which isn't really the same effect.
Thanks!
Hey gang,
I'm struggling with this one. All was going smoothly in my drawing until I tried to add a set of L&E Mini Strips. No matter what I did the instance just would not physicaly show up in the drawing, the symbol would load into the resource browser, but nothing in the drawing itself. I thought it was an issue w/ the symbol, so I switched to an Altman mini-strip - same problem. I started clicking around, taking random fixtures from other manufacturers and noticed a strange trend. The only symbols that show up and behave normally are LEDs or Moving Lightings, no conventional fixtures are showing up. Altman Scoops = No. Altman Phoenix = yes. Source 4 zoom = No. Colorsource = yes. Random Martin Conventional Strip Light = No. Mac Auras = yes, and so on.
I do have a base file that I have favorited, and instruments I pull over from that one are no issues. Non-lighting symbols like tables and chairs seem to come in just fine, but if I put an instrument in as a plain symbol it doesn't show. If I try to edit the 2d or 3d components of any of these it shows nothing. All my classes, layers, etc, are turned on, and my layers are the same scale.
Any ideas?
Hey folks,
Does anyone have a suggestion about where to find 2D rigging hardware symbols? Stuff that's climbing/rescue related would be even better. Shackles, carabineers, rigging plates etc?
Awesome thanks!
Hey, would one of you guys mind re-uploading your mirror ball file? I could have sworn I had it somewhere but now I can't seem to track it down.
Hey,
Sam is correct, I was looking to be able to specify a different connector type. I did a little googling after I posted and found the solution in an old post on the boards here from a couple years ago.
Thanks
Hey,
Is there a way to add types of cable to cable tool? I'd like to be able to draw in things like NL8, video cable runs, etc.
Thanks!
Thanks that fixed it! No idea how that would have gotten changed. Oh well...
Hey all,
Kind of a weird issue I am having. For some reason when I try to publish a sheet layer to PDF the final product comes out like a screen shot. E.g. If I am zoomed all the way in on my sheet layer when I click the "publish" the resulting PDF is zoomed all the way in, not framed up to page borders like usual. I can't think of any settings or anything i have changed lately that would cause this to happen...
Thanks
Hey,
I suspect this has been covered before, but is there a way to add speaker types to the drop down menu for the Speaker Array tool? I feel like I did it in a previous version but can't for the life of me figure it out in 2018.
Thanks!
Hey
I'm having an issue w/ my VW2018 spotlight. I had VW lock up on me and did a force quit. When I opened it again a bunch of my lighting instruments seem to be disappearing. They will reappear when I toggle classes (any classes) on an off, but will disappear when I try to zoom in or go into a 3d view. I have 3d viewports that still display the instruments correctly, but when I try to edit the design layer via the the viewport the instruments disappear again.
I thought it was something wrong with the symbol geometry, so i tried to re-import the symbols into the file, but I didn't even get the usual "this symbol already exists..." message when I reimported.
Any thoughts?
Hey guys,
My team is all heavy into the g-suite applications and have been using them without issue for a while now. But now after the latest google drive update I have been having tons of issues. I can't place an exact set of reoccurring circumstances but the symptoms are the same. Basically I'll be working locally on a file that is synced to the drive. If something happens where I have to force quit, I guess before the file has sync'ed fully (??) when I go to open it again the file will come up damaged. In today's occurrence both my original file and my auto-save come up as damaged and just crash VW without opening anything. Has anyone else had this experience? I haven't had this issue at all prior to this GDrive upgrade.
Hey,
Going back to this. i had it working great right after I posted this question, but in VW2018 it doesn't seem to work the same way. Is there something I'm missing?
Thanks!
Hey guys,
This could totally be something I am doing wrong. I recently installed lightwright 6 on my laptop, planning to use it w/ spotlight. I have no problem opening up a new LW file, and connecting it to the existing VW file. However, when it opens in LW it only imports the fixtures, and doesn't bring along any of the addressing, or universe information. Which is frustrating enough, but then inevitably when I click back to VW it will autoupdate from the (blank) info in LW and clear out all of my information in the VW! What am I doing wrong?
Thanks!
Hey guys,
I'm in VW2018 SP2. I'm having a problem with the blended screen tool. When I click on it in my spotlight tool bar, the icon greys out, I see the options come up at the top of my window and then it just seems to deselect itself and nothing happens. Any ideas?
3d viewport views on design layer
in General Discussion
Posted
Hey folks,
I'm trying to do something that I thought I knew how to do but I guess not. I have a 3d model on a design layer. I'd like to create a viewport of it in front view so I can draw over top of it to add 2d symbols, text etc. Almost like I would in the annotations section of sheet layer viewport.
Whenever I create the viewport on my design layer my viewport view options are greyed out and the viewport just matches the view of the drawing
