AlanW
3,392 -
Posts posted by AlanW
@ShortnortHi not sure if there is another option but i usually duplicate a viewport and crop on without the bubbles and the other with just the bubbles and move them together.
HTH
Did a hidden line render in design layer and sheet layer and still no issues.
- 3
@Benson ShawHi opened in 2023 and was ok immediately.
Alan
- 1
Hi, Evertime i open 2023 it tells me that the Library Catalog is out of date. Even if i close and it and reopen it askes the same question, Can this be overridden and not asking everytime i open a file.
- 4
Hi If you export a .kml file and give it the easting, northing and height then click on the file it will open in Google Eath and fly to your site with the building on it.
HTH
- 1
@@BJRobinsonHi, I had do do this in sections marked in red, one on left, one on right then top right had to draw new nurbs where i marked yellow in attached. yo have to compose each of the side lines also.
@BJRobinsonHi many ways to do this but here is one i use a lot. Lofting.
HTH See attached
- 1
@Rdesign2000hi i have provide an issue to VW with a similar to this where wall breaks were causing a problem. if you delete the wall vent that has a wall break attached the windows fit to walls.
@techdefHi Have all you exrefs been updated to 2023? and brought upto date?? in the main file.
@burgcjAnother simple way to create a site model is ask the Surveyor for a .csv file for the terrain which has the the Eastings and Northing and relative level as an excel spreadsheet.
See attached, this makes life easy and surveyor has this data and shouldn't cost any more to get.
HTH
@burgcjHi if you select the locus they are 3d and then go AEC / Terrain / Site model from Source data and you will get a 3d model. see attached.
Not sure if this is what you were after??
@db535Hi you can always save the view so you can come back to the set angle. not sure of any other way. will look.
@SLDHi I used xrefs for the actual autocad file so i could move the xref viewport and as changes occurred in the CAD file i could just substitute it on the design layer. Don't move the original on the xref only move the viewport on your design layer .
HTH
@Anelisai i find this sometimes, if you double click on the window in 3D and then close the dialogue the window corrects itself.
It regenerates the script as i understand.
If you set the selection tool to object type and select all the windows and doors then in settings set open in 3d and all the windows should go into the walls. then set to closed in 3d again and all should be good. HTH
Also i notice the wall becomes one and not all sections.
- 1
@twkHi seems to work now. i didn't have the tick on the design layer for the site modifier.
Saved as 2021 cant check. will put a 2023 one down also.
2041461386_SiteModifiers.vwx 1589402315_SiteModifiersv2021.vwx
@twk Yes so i changed it to set by visible layers only it works must be a Bug dare i say
- 1
@twk Hi yea i just set one up and cant get the side modifiers on the other design layer to affect the model on the other design layer
@twkHave you tried taking the site modifiers and putting them in the same design layer as the model rather than a different design layer. i have never done that always in the same design layer
Ya sorry didnt click on it and just now saw the video
Can you send me a file private if you want.
@twkcheck the site modifiers you can set them to be to existing or proposed,
Wall lineweights in isometric
in Architecture
Posted · Edited by AlanW
@SuuellaHi Not sure if this is what you are after.
Change the class through the viewport. Same wall copy viewport.
