AlanW
3,392 -
Everything posted by AlanW
change view to layer plane on top ribbon
@Bruce Kiefferhi try hitting 0 (Zero) on num pad does it for PC or change view to layer plane
@unearthedHi found this file that i was looking for which may assist. Random Planting IProp_001v2018.vwx
Not sure exactly what you are trying to achieve. If you are trying to use cut and fill (Spoil) you need to see http://app-help.vectorworks.net/2020/eng/index.htm#t=VW2020_Guide%2FSiteModel1%2FCreating_a_spoil_pile_area.htm&rhsearch=spoil pile&rhhlterm=spoil pile&rhsyns= In the VW help file and you balance the cut with a spoil pile so no dirt has to be taken off site. You draw a pad for the cut then you use a spoil pile for the dirt to go to then you balance the cut and fill calculations. see attached.
Hi As i understand it the program reads all locations in order of workgroup folder first then user folder then program folder and and are all available to the user at same time so you don't lose any connection. Agree you can always put the empty folders over to workgroup but we only use a few, we have complete empty folders at office but not really needed.
Your workgroup folder should be rather small. You don’t copy all the folders over in the operating system, only the folder heading folders and the single folder and file you need within. HTH
@line-weight Hi i did notice that your lowest rl was a minus, put it to zero. put site modifiers on the DTM class and made section use at creation and i get this. HTH
@TessFLooks fun, If you set object to use class definitions as in the attached and make all the classes use at creation you get solid filled walls and floors. If this helps? I also used the clip cube to look inside.
@line-weightHi not sure if this is what you were after. Section style class was not use at creation, they all need to be to show fills. The site modifiers were not on the site modifer DTM class, without them being on this class they have no effect on the site model. You also need to have the model and modifiers applying to the proposed model and not the existing. HTH sitemodel_v2020_v2018.vwx
HI, Anyone know what this item is and how to get rid of it??? Comes up when using the Section-Elevation Marker VW2020. Thanks
HI is there a way to run VW2020 on Mac with OS X Yosemite operating system? I have been told it is not possible. Thanks
@Wes GardnerHi this Marionette scripts takes the windows you have on a building (as long as you have then in a folder in the resource browser and lays then out in a design layer, You then create a viewport to them and dimension and notes in annotations. (Marissa was a great help in creating this network) Maybe someone can use this. Just number your windows in the order you want them to layout. Window_Schedule_171213_v2020.vwx Window_Schedule_171213_v2020_v2018.vwx
@NoemiMHi, this wideo shows you how to use AutoHydris in real projects. HTH
@BohHi for your Marionette commands to show up in your workgroup folder you need to add the $ symbol after the file name and before the >vwx. See attached. HTH
@TessFHi, you can use the knife tool to cut it in half and you will find its hollow. Maybe now you can build a home within and put them back together?
@unearthedhi, 2018 attached. When you are happy with the layout you can explode the block of trees so you wont accidentally change the layout. Keep a copy of the object as a backup To change the polygon right click the trees and edit control geometry. Either change it or draw a new one and delete the old. Randomize trees v2018.vwx
Best Practices for Casework + Interior Components
AlanW replied to e_calabrese's topic in Architecture
@Wes GardnerThanks for that, I was also thinking of dotted under and that can be achieved by your original sending the benchtop to back and dotting the under cabinets in the viewport. Alan -
@unearthedHi, you can do this with Marionette but i notice you have 2012 and i cant export back that far. This script randomizes symbols within a polygon. You can scale and set the percentage of density of the planting also. There are 2 d symbols also so you can randomize any symbol you need. HTH Randomize trees.vwx
@khumennyHi, you can convert it to unstyled then add muntins to the top panel. Top ones need a bit of adjustment to line up otherwise build one. HTH
Hi, Has anyone else experienced the seating section tool stalling when trying to create a seating layout. 2020. Have to crash VW to get out of it?? Sorted, I didn't have any preferences set in the tool preferences.
@Wes GardnerHi,Thanks for the file. How do you deal with your benchtop in plan view so you don't see through it?? -
@e_calabreseHi if you are drawing in 3D to get the most out of a the 3D model use Auto-Hybrids. to understand how to use them have a look at one of my videos.
@MaltbyDesignHi, Its interesting if you set your site model class to a texture the whole model is coloured the same. if you select the site model and change the texture of the model only the top changes. Untitled1_v2018.vwx
