AlanW
    3,435
Files posted by AlanW
  1. Various old nodes
    Hi, These are all the nodes i collected or made myself. HTH
    They are listed under the users i collected them from.
    If tiy put these in your workgroup folder in a folder called Marionette and restart VW and update library they will be available in the dropdown menu.
    Vwctorworks/(your workgroup folder)/Libraries/Defaults. if these folders fon't exist jut create empty folders so vw can follow to the files.
    Some will be out of date so see how they go.
    142 downloads
       (0 reviews)
    0 comments
    Updated
  2. Cubbies
    File that you can adjust for cubbies and learn marionette.
    103 downloads
       (0 reviews)
    0 comments
    Submitted
  3. Extrude & Array
    Hi just a file that may assist in the learning of Marionette.
    I have a lot of files that i feel should be out there that may assist. Hope this is the right location to place them.
    Alan
    141 downloads
       (0 reviews)
    1 comment
    Submitted
  4. Swimming Pools
    Adjust dimensions as needed.
    Right click and edit the control geometry to change the shape of the pool.
    Draw a new polygon and delete the old one will also work.
    137 downloads
       (0 reviews)
    0 comments
    Updated
  5. Cupds
    254 downloads
       (0 reviews)
    0 comments
    Submitted
  6. Downpipes
    231 downloads
       (0 reviews)
    0 comments
    Submitted
  7. Image Processing
    This is based on Marissa's nodes. (The Wizard of Marionette)
    117 downloads
       (0 reviews)
    0 comments
    Submitted
  8. Light Mesh Rame
    Hi, been playing with old networks and noticed that this can create a mesh frame for lights. Adjust the number of rings, verticals and the sizes of all.
    You could also leave the surface and make it a transparent material.
    145 downloads
       (0 reviews)
    0 comments
    Submitted
  9. ImgProcessing-03
    Following on from Marissa's network I made a few adjustments to provide optimise the process to get reasonable results relatively quickly.
    60 downloads
       (0 reviews)
    0 comments
    Submitted
  10. Projector
    Hi, render in fast renderworks. Projects an image onto the wall.
    The network creates a spotlight inside a box and places an image on a poly screen and projects the image to the wall beyond.
    146 downloads
       (0 reviews)
    0 comments
    Submitted
  11. Fibonacci Sphere
    Hi found this node going through my library and had a bit of random fun with it.
    Dale Fugier created the node back in Dec 2014
    105 downloads
       (0 reviews)
    0 comments
    Submitted
  12. Swimming Pool by Marionette
    Hi attached are a few different ways to do pools. The last 2 are freeform in plan. One has a shape and the other control geometry. With the control geometry its on a separate class, if its on it shows upside down. will need to fix. But gives you ideas how to create these. If you lose the textures just reset them. Also adjusted the oval node similar to the Rectangle so you can select the centre easily.
    105 downloads
       (0 reviews)
    0 comments
    Submitted
  13. Galloping Horse
    Just a bit of fun with one of Marissa's wonderful nodes. Just run the network.
    30 downloads
       (0 reviews)
    0 comments
    Submitted
  14. Quick House Models
    In the attached file there is a network that creates a domestic house with the roofs, walls, slab and gutters all from one polygon.
    Could be good for roughing up concept models for a village.
    Play with the polygons and make your own shapes. You can alter the roof pitch, overhangs and wall and slab styles.
    Import a wall or slab style into your resource browser and copy to the appropriate name node.
    Enjoy.
    260 downloads
       (0 reviews)
    0 comments
    Updated
  15. Amazing Curtain Walls
    Have posted a video about the office building concept created by just 5 polygons and described how the network works.
    So simple, this is where Marionette comes into its own for me anyways.
    182 downloads
       (0 reviews)
    0 comments
    Submitted
  16. Simple Steps
    These are nothing special but can be used in your landscape drawing or site drawing and they may help persons starting out to understand more about Marionette.
    Change the No of steps in plan mode.
    109 downloads
       (0 reviews)
    0 comments
    Submitted
  17. Simple House
    Attached is a simple house showing how to use a few marionette objects that have sped up my workflow, Work in progress so hope to create more things to help me.
    With baseboards etc you don't have to worry about the end cap so much so it can stay as anything. Just remember if the object disappears its probably that you just spelt the symbol name wrong so just retype the name in the OIP and it should appear.
    Hope it helps you.
    147 downloads
       (1 review)
    0 comments
    Submitted
  18. Offset and Scale
    This allows you to offset and scale an object.
    With a bit of an explanation that I hope is right. (Well its my understanding to date)
    Thanks to @Luis M Ruiz Example WT-31-How_to_sequence_volumes.
    43 downloads
       (0 reviews)
    0 comments
    Submitted
  19. Grab Rails - Starting out with Marionette
    Thought is was time to start a few videos for those starting out.
    The first one hopefully helps you understand vertex's and manipulating then and finally creating an adjustable handrail.
    Apologies for the unprofessional dialogue but hopefully will get better.
    38 downloads
       (0 reviews)
    0 comments
    Updated
  20. Parametric Spindles
    Attached is a file which shows you how simply you can create a Spindle:
    46 downloads
       (0 reviews)
    0 comments
    Submitted
  21. Using the Sweep Node
    Attached is a file showing how to use the sweep node.
    The second file shows how to push the node to create a spring.
    59 downloads
       (0 reviews)
    0 comments
    Updated
  22. Items on Shelves
    Hi, This simple network places items from a selection of symbols onto shelving. You can decide on the shelf width and depth and the item numbers will adjust to suit. The idea is to move the objects to suit your shelving then select different items from the dropdown to get you desired effect. Currently to get a more random looking front when you are happy with the look just explode a few and delete a few items to make it look more real.  Looking at ways to make the random placement automatic, will see how it goes.
    You can make your own folders, but you will need to change the script at the beginning to get it to work.
    Any questions just ask.
    Work in Progress.
    Thinking so far in relation to different categories of stock you could create duplicates with symbol folders and Marionette Objects of different stock and use whichever is appropriate.
    145 downloads
       (0 reviews)
    1 comment
    Updated
