AlanW
    3,435
Everything posted by AlanW
  1. @shyamsundar Hi you need to use photohp to adjust the light and dark sides to be the same. I often use the Clone Stamp tool to copy one side to the other. HTH
  2. Dont worry found the problem. Was me:) Can you delete a post once its up???
  3. Hi again, In the 2026 Fencing tool you used to be able to right click and allocate a class now you cant, I had to cut and paste the class name in. Am i missing anything again? 🙂
  4. Hi Thanks, If i show in low mode which works you dont see the windows in detail. All workeds well in 2025.
  5. Hi Second problem, my wall opening is solid red in 2d Wall Problem_02.vwx
  6. Hi Me again, My wall is on Wall new calss and i have wall components withing the wall new. Before i could turn off the components anthe wall new calss would show. But not now. Any ideas again.Wall Problem.vwx Thanks from a real 2026 NOOB
  7. Hi must be missing something again. When you put = in spreadsheed cell then right click you should be able to insert function then criteria. I cant seem to do this now by right clicking. Can you point me to the correct way to do this in 2026. Thanks in advance.
  8. @michaelk I can see it now, not set by class.
  9. @michaelk Well that was simple!! Thanks How Dumb am i, LOL Alan
  10. Roof Framing not showing in hidden line viewport 2025 but does show in 2026? All design layers and classes showing. Shows with shaded viewport in 2025. Any ideas. Thanks in advance Roof Rafters.vwx
  11. A person with a keen eye in our office has just pick up what appears to be a spelling mistake in the Title Block Border Settings under drawing stamp. Display Drawing Stamp, 'For Developement Application Only" Should it be Development ???? Over to you
  12. @Tom W. Well that was easy!! thanks Alan
  13. Hi Is there a way to change all the stair tread components at once rather than one at a time? Thanks
  14. Hi Have an issue with text in a symbol. Rotate it 90 deg and shows sideways. Rotate it 180Deg and shows ok. Rotate 270Deg and shows sideways. Anyway any way to make it horizontal. Regards Alan Text Rotation.vwx
  15. @twk Hi i know this tool but it selects the complete face of the wall. Was sure there was one that did the wall within a room like second pic. Thanks
  16. I seem to recall a tool that would extract a section of a wall surface within a room rather than the whole wall. Am i dreaming or does it exist? Thanks
  17. @Tom W.Hi Thanks Tom cant play file it requires a HEVC Extension which i have to pay a few dollars for. But I added the file to the Defaults Standards folder as you said and this time restarted VW and all is good. Thanks for your patience, much appreciated. 🙂 Alan
  18. Hi Thanks I must be a real NOOB. I can see the drawing but to bring in say 10 selected classes into a new file from my template file i cant see how to do that. Back to my original question click on new class and you see all the standard templated from which you can choose a number of classes. Navigate to my template file and while VW is open i can continually choose classes from template. Close vw and restart template doesn't show, so i have to renavigate to template. Would like it to stay. Aim is to choose multiple classes at a time and import. Thanks
  19. @Tom W. Thanks Tom, I have put a .VWX file and a .sta drawing in this location. i can access it continually while i keep Vectorworks open, but when i close VW i have to browse to it. Would be nic to have it viible all the time. Thanks
  20. Hi all. I know how to import new classes into a drawing but i have to continually navigate to the template drawing, the reference location stays while i have VW open. Open a new drawing i need to navigate to it again. How do i place the template file so it is always visible in this dialogue box. I have tried placing it in the server workgroup folder but with no success Thanks
  21. Hi All and again Thanks to Vectorworks Australia for working out my issue . My graphics driver was way out of date. well if other have the same problem this should be the solution.
  22. Hi Anyone have issues with update 4 when you try to render an elevation viewport it crashed the program everytime. Have tried it on Update 1-3 and all works fine. How can i roll back to a workable version. Thanks
  23. Hi When you import to Twin Motion make sure you have double sided ticked. see attached
