Alan Woodwell
  • Content Count
    3,090
Everything posted by Alan Woodwell
  1. Alan Woodwell
    2020 GIS Location
    Hi, Starting 2020 and trying to set location to Sydney Australia. After clicking set my location i get this question and hit switch to and up comes my apps with no indication as to which one to turn off and the only way to progress is to crash the program. you only get options to retry or switch to? any assistance gratefully accepted.
  2. Alan Woodwell
    2020 GIS Location
    Yes connected to net and PC. I can get to other locations, just this had no option to stop it.
  3. Alan Woodwell
    2020 Dark Mode
    When will this be available for PC users?? Other software have had this feature for years. Bit pathetic that this option has not been carried to PC users.
  4. Alan Woodwell
    2020 Dark Mode
    Hi, is dark mode only available for Mac users and not PC users????
  5. Alan Woodwell
    2020 Dark Mode
    Seriously???????
  6. Alan Woodwell
    Importing a PDF while using a black background setup
    Not sure but inverse the PDF in photoshop and see how it goes
  7. Alan Woodwell
    Changing Fill Color for Stairs
    @rlbHi in in the stair tool go to settings go to stair attributes and change the classes here for each component of the stair. HTH
  8. Alan Woodwell
    Modelling Challenge
    So all you do is convert to a mesh then to a generic solid. It was just a suggestion that may assist some users.
  9. Alan Woodwell
    Modelling Challenge
    Hi, i use revolve with rail for these type of shapes.
  10. Alan Woodwell
    SKYLIGHT IN ROOF FACE
    @bchi this video may assist
  11. Alan Woodwell
    Green Border appears around Viewports
    Hi, that’s because the green line went on a class that is turned off. click the visibility tool / visible mode and hold the v keyboard button down and all classes will be turned on temporarily, Mouse over the green line to se what class it’s on.
  12. Alan Woodwell
    Just delete the lines
  13. Alan Woodwell
    Extrude from DTM
    hi this is a Marionette file for putting a fence to surface. will modify and should be able to be used for hedge also. right click fence and edit control geometry to change line of fence. Send to surface_004Cv2018.vwx Send to surface_004Cv2018 v2019.vwx
  14. Alan Woodwell
    SKIRTING BOARDS
    @Boh, Have a look at this video which may assist. I set up a command, someone may have a better way to do it now. Look at my videos as i have a lot on marionette. Copy and paste this link. https://www.youtube.com/channel/UC-2YxfK2gWwIbsX2ChlzDtA
  15. Alan Woodwell
    SKIRTING BOARDS
    @VinceCastanonHi, attached is update file. to change the line (geometry) simply right click on the object and edit control geometry. either move the line or draw another and delete the old one, 2d or 3d. Textures still appear to change when move or redo the script so i would ungroup the final product and then it becomes a simple extrude along path object and change textures in the OIP. HTH. Alan EAP+Texture v2019 v2016.vwx EAP+Texture v2019.vwx
  16. If you are thinking about what to add to VW2018 then I am sure you will get a few votes for this option.
  17. Alan Woodwell
    Extrude Along Path Control
    @Niels Timmerhi, have a look at this old video one of my early plays with marionette. HTH https://m.youtube.com/watch?v=co-bdctpWkQ
  18. Alan Woodwell
    How to draft a 3D swimming pool
    Hi, if you just need a pool for effect you can use this Marionette network.
  19. Alan Woodwell
    Swimming Pools
    Version 1.0.0
    19 downloads
    Adjust dimensions as needed. Right click and edit the control geometry to change the shape of the pool. Draw a new polygon and delete the old one will also work.
  20. Alan Woodwell
    Cupds
    Version 1.0.0
    46 downloads
  21. Alan Woodwell
    Downpipes
    Version 1.0.0
    45 downloads
  22. Alan Woodwell
    @Pvz11Hi I have a lot of marionette objects from when i was learning. This one may assist also. Kitchen Cupds.Overall_V002_v2017_v2019.vwx Overall_V002_v2017_v2019.zip
  23. Alan Woodwell
    Weird behaviour of a pad site modifier
    @amcdonell hi this another way that a may help
  24. Alan Woodwell
    @Pvz11Hi, this may assist. This was originally done in 2017 so you may want to update some of the nodes. This is a cupd door with an extruded handle. HTH Extrude_along_path cup'd handle v2017 v2019.vwx
  25. Alan Woodwell
    Exporting "OBJ 3D only" files
    MMmmm, found it in customise, Menus. Just had to drag it over. Seniors moment. LOL
