n2lights
    6
Reputation
0 Neutral
Personal Information
  • Occupation
    Lighting Designer
  1. I am aligning all layer views. How do I turn on stack layers? I can go to top plan and select all and it affects all layers. I select render artistic with the set layer active and it renders the set layer only. I select align layer views and nothing changes. I select the lighting hang layer and select artistic render and the hang renders but the other layers disappear.
  2. I am still using Vectorworks 12.5 but this just started happening. I have both layers and classes selected to modify all, however, when I try to select anything in a layer I am currently not in I am not able to. Also when I try to render only the current layer renders. Any ideas?
  3. Where are the online exercises that supposedly accompany the training CD's through a link to your website. The link turns up an error message and all of my fruitless searches turn up nothing on the website. [ 05-13-2004, 02:13 PM: Message edited by: Katie ]
  4. quote: Originally posted by n2lights: quote:Originally posted by Katie: It's an OS counting thing. It counts by the leading number, not by place value. If you have files called 1, 2, 3, 11, 12, 13, 21, 22, 23, they will be listed as 1, 11, 12, 13, 2, 21, 22, 23, 3, etc. The only way to change this is to add the leading 0's when appropriate. If this is an OS problem why does it occur only in the editable worksheet and not in any other noneditable worksheet?
  5. In the editable worksheet I try to edit the color of several instruments in a row. On other spreadsheet programs I simply hold down the mouse and drag down to select all the cells that I wish to enter this new info into. In Vectorworks this method does not work,even though a multiple of cells is selected only the top most cell displays and retains the information.I have a Mac OS 8.6 running VWS 9.
  6. I like to work with channel assignments rather than unit numbers. I have VW Spotlight 9 and wish to be able to manually channel the instruments. Is there a way to do this without having to create an editable worksheet and enter each channel individually? Also I created a 6 light parbar as a multicircuit unit and I want to twofer the pars together. Do I need to do this when I create and convert this instrument so that the characteristic is used globally throughout the plot or is their a way to specify that unit 1 and 4 will always be on the same dimmer?
