648 -
Posts posted by inikolova
Hi @elepp,
I am sorry to hear you are having troubles. Please send me a message with the link to the .vwx file and I will investigate.
Best regards,
Iskra Nikolova
Hi Tom W,
Both of these improvements (ability to change the background and clip cube rotation) are currently planned for release in September 2022.
Best regards,
Iskra Nikolova
3
1
20 hours ago, E|FA said:
1. Better UI for Settings sliders (e.g. Ambient brightness). They are too short/sensitive, making it hard to fine tune the settings.
Noted! Thanks!
1
10 hours ago, Christiaan said:
2. Don't apply dark overlay on entire screen for setting slide out.
This was a known problem before the release and we already have a partial solution for it. For the next release, the panel will hide when you start moving the slider. For a final solution, we are planning to have all the panels be adjustable size.
3
- Popular Post
14 hours ago, zeno said:- I had some problems with safari. No problem with chrome
Seems that Safari is just slower on all stages - downloading the viewer, downloading and unzipping the scene, loading the scene. This might also be happening because of unpacking compressed textures on the CPU in Safari which could be incredibly slow. Not sure if we can do much for this, seems that Chrome is just optimized better than Safari. Potential future improvements in model file size and viewer size might help remedy the problem a bit.
14 hours ago, zeno said:I had some problems using the clip cube
Would you please specify the problems you had, so we can investigate further?
14 hours ago, zeno said:- The possibility of inserting borders must be added immediately.
Draw edges is on our list. Added your vote/comment to it.
14 hours ago, zeno said:- I believe that implementing visibility of classes and saved views is something that does not require a lot of work, but that would also radically change the experience here!
Saved views and classes are being considered, but they are not trivial. Some discussion about classes and saved views here:
14 hours ago, zeno said:- It would be very useful to be able to add the visibility of 2D objects.
This is on our list. I added your vote and comment to it.
14 hours ago, zeno said:I hope you will continue from this point of view, because what you have done is really beautiful, but in my opinion, as a user and designer and teacher, some very important elements are still missing.
This was just the first release for the Unity-based viewer. We are continuing development of new features and improvements with full steam. Thank you so much for your constructive feedback, we are glad to hear you are satisfied to some extent :-). And thank you for the good words about the work that has been done so far!
5
34 minutes ago, zoomer said:
But I was wondering a bit why I could not rotate the model on screen.
Usually when you reach the "north or south pole" of a Panorama (or standard view ?),
it will stop, but you only need to slightly rotate around the pole to re-rotate for Z
about X or Y axis. That did not work at all in this case.
I am not sure I understand the problem. Are you saying you tried to adjust the view while you were upside down, and that did not work? I think that is expected as the current restriction is that you can only view the panorama in a landscape orientation (rotated to the right).
Yes, when you reach the North and South poles, the motion and orientation sensors stop there to prevent you from rolling over. You could drag the image to adjust the view up and down relative to the position of the device.
Does this help?
1
On 3/16/2022 at 3:09 PM, zoomer said:
Panorama Demo (was upside down for me)
Panoramas have a fixed orientation due to numerous technical issues associated with handling device orientation changes. Try rotating your device to display the panorama in the correct orientation.
On 3/16/2022 at 3:09 PM, zoomer said:it would be nice to run Nomad also on the Desktop, when no iPad available.
If VW allows Nomad Desktop usage, I could control or test what I want
to publish - before I give it away .....
We have plans to have Unity-based desktop 3D model viewer that you can use to view .vgx file on the desktop. I think this will satisfy your need.
1
5 hours ago, Christiaan said:
Syncing Saved Views between Vectorworks and Nomad seems like low-hanging fruit for this kind of thing. Is that not such an easy task?
Thank you for the continued discussion on saved views and the different cases where they may be useful. As far as I know from speaking to the developers, dealing with saved views and their class/layer visibilities, is not trivial. That is the reason why they were not included in the initial release. We will be having team discussions, considering your input, and we will see what's feasible for the short-term, and what would be more of a long-term goal.
2
1 minute ago, E|FA said:
Once the Nomad app is installed on the iPad, I can use the Nomad folder in the iOS Files app as a way to access my VW Cloud Services files & folders. Correct?
Exactly!
1
1
29 minutes ago, E|FA said:
I'm not sure I understand why Nomad is needed in this process.
If you are using iCloud, and don't want to use Nomad, that is totally fine. You need to use Nomad only if you want your file to be saved on the Vectorworks Cloud Services storage. For example, if all your other project files are stored there and you want to store the Morpholio files at the same place. If you prefer iCloud, it is an equivalent alternative. No Nomad is needed in this case.
13 minutes ago, E|FA said:
At first I had trouble, with an error message saying that I had to manually type in my password (instead of using iOS keychain), but once I did that it worked. Strange behavior. It's working now.
This is not an error exactly. It happens when we can't redirect you to the app after you sign in. Using face ID or other auto-fill mechanisms may result in this page. We implemented this page as part of the login workflow, to catch these scenarios. There is a button that takes you back to Nomad for your convenience since we were not able to do this automatically. You don't have to type in your credentials manually, you just have to tap the Go to Nomad button when you see this page. This should not be a reason for concern.
2 hours ago, Christiaan said:
At the moment I think we rely on the active view in the file, right?
You are referring to the ability to define the initial view upon loading in the viewer, right?
The old web view export was using the current position of the camera upon export for the initial view, but that hasn't been re-implemented for the new export and viewer. This is one of those things that we will work on for subsequent releases. I think there may be different ways to go about this. This might get connected to the wish for saved views, as the initial view is a flavor of a saved view the way I see it.
Yep, I already have your other wishes on our list.
Thanks!
Iskra Nikolova
1
14 hours ago, line-weight said:
- it seems it's still not possible to display with edges drawn - or am I missing a setting somewhere?
- Edges are under consideration alongisde with many other visual improvements, such as ambient occlusion, for example.
14 hours ago, line-weight said:flyover navigation - it's sort-of usable, but I think it can only ever rotate around the centre of the model, is that right?
In the old viewer, the center of rotation was fixed and was based on the origin of the .vwx file.
The center of rotation in the new viewer is determined dynamically, aiming to never be outside the current view. If the tap is over the model, the center of rotation is determined by a ray cast to the nearest object surface. If the click is on an empty region of the scene, the center of rotation is set to the center of the screen at the depth of the last rotation.
14 hours ago, line-weight said:The main thing is that moving the "joystick" to the side translates sideways - but I think most people would expect that moving the joystick to the right would rotate the view to the right.
We can add an setting to rotate the view with the joystick.
9 hours ago, thecadman said:Can we get back the navigation by pointing the camera?
This is on our list of features to carry over from the old viewer to the new.
Thanks for the discussion about saved view. This is also on our list of future improvements. We think that saving a view within the viewer could also be helpful, and also a way to "play" these views, like an animation, would allow you to just hand over the model to your customer. They would be able to see exactly what you define for them and they wouldn't need to learn how to navigate.
Please keep your suggestions coming!
Best regards,
Iskra Nikolova
2
1 hour ago, E|FA said:
Congratulations & thanks to the VW Nomad development team.
I passed your praise on to the team who worked on this. This was a long project and we are so happy to finally deliver it to you! We hope you enjoy it. This is just version 1 of the new viewer. We will continue to improve it and add more features to it going forward. Please let us know what you wish to see in it next.
1
9 minutes ago, bcd said:
Many of the sample files are quite old
We are in a process of updating the sample files. They should be there in a day or two.
2
On 2/21/2022 at 8:13 AM, elepp said:
At the moment it's running very buggy for us. The pins are jumping around and resetting themselves. I have to reload the browser regularly 😔
It's costing us a lot of time to make changes.
On 2/21/2022 at 3:08 PM, elepp said:Today this tool was beyond usable. The pins were jumping around, changing their colors randomly, changing their sizes.
I didn't realize it was so bad. Would you be able to capture a screen recording when this happens so we understand the issue better? We won't know how to fix it if we don't know how to reproduce :-).
On 2/21/2022 at 8:13 AM, elepp said:The line break of our texts happen in weird places.
I logged an issue in our bug tracker. I think the text just gets cut off when it reaches the end of the row, which length is determined by the size of the thumbnail preview. I asked if this limit can be increased, so longer words can fit in it. What do you think would be a good character limit?
On 2/21/2022 at 8:13 AM, elepp said:This seems to be a safari issue. It works in Firefox.
Thanks, I saw the issue and reported it to the team. It happens on Safari, and only for Board slides.
On 2/21/2022 at 8:13 AM, elepp said:We can change the names of the pins but the names of the files stay the same in the presentation.
I added this to our list of improvement requests to address this year.
On 2/21/2022 at 10:44 AM, elepp said:How does the 3D Panorama defines it's starting point.
A pin in a Tour slide can have two saved camera positions, to allow you to fine-tune its view depending on how the viewer accesses it.
- Pin opened from a panorama view: Set the camera position when you create the pin; you can modify it later by using the pin edit controls. You may have more than one pin that opens a particular panorama image.
- Pin opened from the Tour map or the side navigation pane: Set the camera position from the image’s context menu n the Resource panel of the Tour editor or Tour map editor, or from the Tour map pin edit controls.
Note that the tour will start with the camera position set for the first image in the Resource panel that has the home icon.
I believe the camera's default initial loading position was determined by the view set on export as well. I am checking with an engineer for more information.
Best regards,
Iskra Nikolova
1
8 hours ago, elepp said:
- The starting camera position should always be adjusable, also in Panoramas that are not part of a tour. I dropped a panorama on a floorplan and can't adjust the view. Now people have to rotate the view first to see where they are.
I like the idea. I submitted it to our list of improvements to consider.
8 hours ago, elepp said:The layout is very limited. We would like to have more freedom in layouting our presentations.
We have received a lot of feedback about this. We are planning to tackle this soon (definitely this year, but we don't have an exact timeline set)
8 hours ago, elepp said:- Occasionaly the pins I create are jumping around when I am trying to adjust them.
I am aware of this issue. With the flexible layout implementation, I am sure the way pins are implemented will have to be changed.
8 hours ago, elepp said:Changing lots of pins is very tedious. We like to indicate different types of images with color codes, but if we change the colors it becomes a very tedious job changing 20 pins.
This is another improvement we are planing to start working on soon.
8 hours ago, elepp said:Scaling issues like these happen.
I am not seeing this issue currently. It would be appreciated if you could provide more details around the circumstances under which this is happening.
8 hours ago, elepp said:If I type this text in the editor I don't see it in the presentation. Somehow the <> lead to the software ignoring the text.
Nice finding. I filed a bug to the team to look into it.
9 hours ago, elepp said:Pins that are very low on the presentation become very painful because the settings are disappearing.
I am aware of this as well. Since there is a workaround, we have not considered as a high priority item, so it still unresolved. I informed the team about your report, to raise awareness of the issue. I hope it can be fixed soon.
Thanks for the time you took to share these items with us!
3
Hi @joestewart4669,
Non VSS users can upload panoramic images to the Vectorworks Cloud Services and a shareable link can be generated from there. Right-click and select Share link.
Create the link and configure it from the SHARE LINK dialog.
Here is one link for a panorama that I have to see what the experience will be for you recipient.
https://cloud.vectorworks.net/links/11ec85d5323ddf3eb18912a65244b947/
Would this work for you?
Best regards,
Iskra Nikolova
Hi @elepp,
I am glad to hear you are using the presentations. I am not aware of the problem you describe. If you could send me a link to a presentation that you had this problem with, and let me know what changes you have made, but didn't get saved, I would be able to pass that info to the engineers to investigate further.
You can email me at inikolova@vectorworks.net.
I look forward to helping you further.
Thanks,
Iskra
Hi @_James,
That's correct about Google Drive and delta sync. Project Sharing would still work with Google Drive, but your experience with Dropbox would be better because it syncs changes to the Project file much faster, so the time periods in which others are blocked from working with the project file are smaller. I asked if you have tried it, because there is still a chance that it might work satisfactory for your needs, if you are mindful of this limitation. I suggest you give it a try before giving up on that option, because that would be the only way for you to keep all of your files on Google Drive and use Vectorworks Project Sharing. All other options would require you to store your project files elsewhere.
I hope this helps.
Best regards,
Iskra Nikolova
Hi Eduard,
Thank you for your feedback! I already had these wishes recorded in our tracking tool, so I went ahead and added your votes for them. We have a long list of wishes for nice usability improvements for the Presentations. I am happy to see that more and more users are trying to use them. I hope we would be able to tackle these improvements soon. I don't have a set target date right now, but these are definitely on our radar, along with many others.
Please keep your wishes coming. We want to hear what you think is working great and what needs improvement, so we can make the Presentations tool better.
Best regards,
Iskra Nikolova
2
Hi All,
I have some good news for you! We are currently developing support for Shared Drives on Google Drive. I don't have an exact estimate of completion. Unless we run into any major issue, it could be released before the end of this year.
On 9/2/2021 at 8:46 AM, _James said:Is there a way for VCS to access GoogleDrive Shared Drives and then administer the project sharing?
Even if you integrate Vectorworks Cloud Services with Google Drive Shared Drives, those will not sync to your desktop via the Vectorworks Cloud Services desktop app. So, you wouldn't be able to do project sharing this way. The SharedDrives would only be accessible via the Vectorworks Cloud Services web portal, so you could use the cloud processing, as well as the viewing capabilities of Vectorworks Cloud Services web portal. Have you tried doing Project sharing with the files stored directly on the Shared Google Drives?
Best regards,
Iskra Nikolova
Hi Peter,
Thanks for sharing your results! Yes, it is possible to add more styles and we are planning to do that, but I don't have an exact date right now.
Best regards,
Iskra
1
Hi @Sky,
Thank you so much for your feedback! We are actively working to improve Nomad's viewing capabilities - currently in the 3D viewing space, but the 2D is on our radar as well.
1. Measuring and snapping were one of the first features we added to Nomad. At that time we only had Generate PDF. Later, when we implemented Cloud Publish, the measuring and snapping was not added.
2. Generally, we do not recommend placing the local Vectorworks Cloud Services folder within a folder of another cloud storage provider. Our engineers looked at the logs and did not find any signs of conflict file created by Vectorworks Cloud Services. We believe the conflict was generated by another cloud storage provider. I am sorry that you have to use a workaround instead of your preferred way to setting up your file structure. I don't think you should be uncomfortable saving the master copies of your Vectorworks files on Vectorworks Cloud Services though. We have protection mechanisms in place in the event the file gets unintentionally modified or deleted. Each file has version history from where you can restore prior versions. We also have Cloud Trash where all deleted files go. They can be restored to their original location from there.
3. Supporting Dropbox and Google Drive integrations were features we had to implement. It is absolutely possible to add other storage providers to this list. We have had many other requests to expand in this area. Currently, we are working on providing support for Shared Drives with Google Drive. iCloud is on our list for other storage providers to add as well. If we had the integration, you would't have tried to add your Vectorworks Cloud Services folder within your iCloud Drive. I hope we can have that in the near future, but I can't offer any solid plans at the moment.
4. Yes, if you rename the file, you are breaking the connection between the generated pdf and the metadata file where the snap and measure info is stored, because they are associated by name. That is the main reason why we don't have move/rename feature on our web portal yet. We had efforts to add this feature in the past, but it hasn't materialized yet due to issues that were found during testing.
With the re-engineering effort for the 3D model viewer, we may be able to re-imagine how we do measuring on the mobile devices. At the end, the implementation may look totally different and all of the existing issues could become obsolete. So, at this point we are holding off on improving these areas, until we know what the full possibilities are with the newer technologies.
I hope this information is helpful.
Best regards,
Iskra Nikolova
Is the 'Nomad' app still alive and does anyone use it?
in General Discussion
Posted
@line-weight,
The Export VGX command is available in Vectorworks 2022 SP3 or later. I will make sure to include this in the Help. Thanks for pointing that out! I am glad you managed to export the model via the Vectorworks Cloud Services desktop app.
Yes, transparent objects cast shadows currently. We are looking forward to fixing this it as we implement a "white model" functionality. It will require marking which objects are transparent so we don't make them white, so we can use that to also disable shadows.
Reagrding your glass texture that appears opaque, please send me a message with a test file so we can evaluate this specific case further. We are aware of some issues with displaying transparency.
Draw edges is coming soon, along with white model. 😉
Best regards,
Iskra Nikolova
