inikolova
Vectorworks, Inc Employee
    863
Posts posted by inikolova
  1. Hello Di9it8,
    I think this may be an issue with Safari 11 (prior versions are fine). Apple has updated its default protection mechanism. The browser can no longer access local files or resources located on a local drive (i.e. any file located within your /Users directory). Therefore, viewing local Web Views/Panoramas on Safari 11 will not work immediately. Luckily, there is a way to allow this to work again. However, the user needs to perform the following steps to allow this feature to work in Safari 11.
    1.     Go to Safari -> Preferences
    2.     Go to the “Advanced” and check the “Show Develop menu in menu bar.” This should initially appear unchecked.
    3.     The new “Develop” menu should now appear in the menu bar. Select “Develop,” and then select “Disable Local File Restrictions.” Viewing Web Views/Panoramas locally in Safari should now work.
    I hope this helps.
    Regards,
    Iskra Nikolova
    Quality Assurance Specialist
    Vectorworks Cloud Services
  2. 10 hours ago, willofmaine said:
    Speaking of the full-screen icon, I think its arrows may be inverted?...
    It seems like there is a bug with which icon appears after you switch back and forth a few times. We are thinking about removing the exit full screen icon (and just leave the Esc key as the only option), so this should technically solve the issue. I'll discuss the adding of the full screen option to the "bypass link" with the team, but I think ideally the link from Vectorworks and the link from the website should provide the same user experience. I believe the "bypass" option was done initially due to technical limitation that existed on the website, which in some cases would prevent the user from viewing the image as a panorama, and would show as a flat image. If this limitation has been overcome by now (I am not sure of its status), there should be no reason why getting a link to the same file from different places would deliver a different experience for the recipient.
    Thanks for posting on this issue!
    Iskra Nikolova
  3. Hi willofmaine,
    We have removed the VR icon from the desktop view, because this icon is specific for cardboard mode, which doesn't apply when you are viewing the Panorama from a desktop browser. Instead, there is a full screen icon that appears at the bottom center of the screen when you move your mouse around - see the attached image. I see that this icon is only available when you view the file on the Vectorworks Cloud Services website, but not when you use the link that Vectorworks returns. I will discuss this discrepancy with the team. I think the shareable link should provide the same experience, no matter if you access the file by using the link from Vectorworks or by using the shareable link acquired from the Vectorworks Cloud Services website. Other than being able to see the file in full screen, would there be another reason why you would want to bypass the Vectorworks Cloud Services website?
    Yes, there are still a few unresolved cases which may cause you to not get a shareable link in Vectorworks. I would be curious to find out more details about your specific workflow, since from my quick test, I was able to get a shareable link for a brand new image, which never existed before. Do you have Auto-upload disabled in the Vectorworks Cloud Services Desktop app by any chance? If you can send me specific steps that you are performing and a screenshot of the settings that you are using, I would be glad to look into the issue further and try to determine the exact reason why you may not be getting the links in Vectorworks. You can post them here, or email me directly at inikolova@vectorworks.net.
    Regards,
    Iskra Nikolova
    Quality Assurance
  4. Hi everyone,
    We just released a fix for the Desktop app startup issue on Windows 10 version 1709. Before running the app, you have to delete the following folder: C:\Users\USERNAME\Roaming\Nemetschek\Vectorworks Cloud Services\
    Please let us know if you continue to experience problems.
    Regards,
    Iskra Nikolova
    • Like 2
  5. Hi Michael,
    Can you please delete the entire Vectorworks Cloud Services folder located at: C:\Users\<your username>\AppData\Roaming\Nemetschek and try running the Vectorworks Cloud Services desktop app again?
    If that doesn't help, my next guess would be to try uninstalling that specific Windows update and see if that helps. You can do that from Control Panel > Programs > Programs and Features > Installed updates.
    Regards,
    Iskra Nikolova
  6. 2 hours ago, echobing said:
    Hi. I've been super excited about this feature but can't seem to receive the cloud link. I'm an active VSS subscriber using VW18 Designer. I process and save in the cloud, check the send link but never receive one. Also the jpg renders aren't using the custom render settings I have applied. Am I missing something in the workflow ?
    Hello,
    Thanks for trying this new feature of Vectorworks 2018. There are a few cases that we were aware of, which can cause the shareable link dialog to not appear. We will be looking into fixing them soon. In the meantime, if you don't receive the shareable link in Vectorworks, you can go to https://cloud.vectorworks.net, click on the panorama image and click on the Share link icon in the top right corner, or from the file's context menu. You may or may not have the link already created, but either way you can copy the link from there. Regarding the .jpg not having the custom render setting you selected: We first upload a preview image set to OpenGL rendering to the cloud, so you can get a quick preview of the panorama, and also to be able to get the link in Vectorworks at the time of the job submission. This preview image is replaced by the final panorama image when the rendering job is completed on the cloud. If, for some reason the rendering fails, then you will be left only with the preview image. Currently we see panorama renderings fail more often that we would expect, so we are looking into fixing this with a high priority. If you would like us to take a look and determine the exact reason why you are seeing these two problems, please email me your VSS username at inikolova@vectorworks.net and I would be happy to assist you further.
    Regards,
    Iskra Nikolova
    • Like 3
  7. Quote
    The Vectorworks Cloud Services website needs some tweaking. In the image below you can see that the in process files across the top display poorly and the file name is unreadable.
    On 9/23/2016 at 3:31 PM, Kevin McAllister said:
    Brilliant! I never would have found that on my own since I'm not uploading files from the website.
    KM
    Hi Kevin,
    We have just released a newly designed Vectorworks Cloud Services website, which now has a better way of displaying job status and the names are not truncated. Opening of the status bar is now at a more obvious place, not hidden behind a file upload button. Now, you can open the status by clicking more... on the progress bar in the lower left corner of the page, but it will say Status... with the next release, for even better clarity. Your feedback was really appreciated. This release has numerous other improvements, which were requested by other users as well. The release notes can be found here: https://cloud.vectorworks.net/portal/releasenotes/
    I hope you will enjoy using this new version of Vectorworks Cloud Services!
    Regards,
    Iskra Nikolova
  8. @gnkarch
    Hello,
    Sorry if I am responding too late to this question. I am not typically monitoring this forum on a regular basis. The missing font should not be a reason for rendering problems. If the Vectorworks document is using a font, which is not available on the server, which does the rendering, or in the user storage, and if there are no font mappings set by the user, Arial is used.
    You could use the Vectorworks Cloud Services Portal web page https://cloud.vectorworks.net/portal/files/ and send a feedback to us using the Feedback button in the top right corner of the page.
    If you see your viewports rendered in wireframe, this probably means that there is no Vectorworks serial number uploaded to your Cloud Services account. Once we know your user account info, we should be able to assist you further.
    Best regards,
    Iskra Nikolova
    QUALITY ASSURANCE
    VECTORWORKS CLOUD SERVICES
  9. On September 23, 2016 at 6:04 PM, Kevin McAllister said:
    One thing that would be immensely helpful for Mac cloud users is a list of the actual fonts (manufacturer or Font Foundry) use by the Cloud. I've looked at the font list on this page - https://cloud.vectorworks.net/portal/fonts/ but its not that specific. When I installed a Mac version of Century Gothic for example, generate a file containing it and send it to the cloud for processing, the font doesn't work with the one installed on the cloud. I'm guessing the version of Century Gothic that's being used is a specific Windows version.
    Century Gothic is a font that is available on Windows by default, so I am guessing that the Mac version that you have installed is slighlty different.
    Since the cloud server is Windows based, all Windows system fonts naturally work with Vectorworks. However, in order to add the Mac system fonts, we had to do font file conversion and install those Mac fonts on the cloud. Over time, we are finding that some of these fonts are not working properly, even though we would be expecting them to work. We could try making the font list more specific per your suggestion - we could probably just identify if we are listing a Windows system font or a converted Mac font. Do you think that would help?
    If you convert your version of the Century Gothic font into a Windows version, and send that along with your file to the cloud, does it work?
    You could try using this free online font converter: https://onlinefontconverter.com
  10. On September 21, 2016 at 8:24 PM, Kevin McAllister said:
    And I have no trouble with my fonts when processing regular jobs using the Dropbox based folder, but my fonts don't work with the regular Vectorworks Cloud Service folder...
    On September 22, 2016 at 5:15 PM, Kevin McAllister said:
    Is there an order to which Cloud Services looks for fonts with respect to these separate folders? Or does it always look for the required fonts in the same folder as the Vectorworks Document?
    In general, we recommend keeping the fonts on the same storage type as your vectorworks files. They don't have to be in the same folder, though. You could have a dedicated folder that only contains fonts as long as this folder is within a Dropbox folder that Vectorworks Cloud Services has access to. For example: If you have a Dropbox "full access" integration, and your .vwx file is in Dropbox, put your font files in any Dropbox folder as well. If you have Dropbox "limited access" integration, the .vwx files as well as the font files have to be inside the Dropbox > Apps > Vectorworks Cloud Services folder or its subfolder.
  11. On September 22, 2016 at 6:02 PM, Kevin McAllister said:
    I wondered if there might be a bug in there somewhere. I think the length of the line may be linked to the "Update any plugins that need updating before Publishing" and whether it is checked or not.
    It seems like the Cloud has issues when things are made "bold" in Vectorworks and a "bold" version of a font doesn't exist originally (eg. Vectorworks or the system is faking a bold font). The cloud seems to look for a font that doesn't exist. This may just be because the Cloud is PC based and I am Mac based.... not sure.
    Kevin
    I did some testing and it seems like the lenghth of the line is not affected by the "Update any plugins that need updating before Publishing" setting. The issue occurs when original font is replaced by another font, which is exactly what happens on the cloud. If the cloud cannot find the original font, it maps it to Arial. At this point the plug-in reset is not happening, so the new font might be longer or shorter than the original. The cloud server is not trying to do any other "faking" as you call it. And yes, since the cloud is Windows based, and you are Mac based, there is apossibility that some of the fonts do not work for that reason. Most of the time this can be fixed with proper font format conversion, but I have seen cases in the past where I convert a font to the proper required format and I am still unable to make it work. If you could send me the specific fonts that you are having issues with, I can try this on my end and see if I could make it work somehow. Otherwise, I would send it to a Vectorworks engineer to see if they can do anything to make this specific font work on the cloud.
  12. I'll be posting a response for the font issues as well. I did not miss it, just need some more time to respond.
    21 hours ago, Kevin McAllister said:
    Is there a way to get back the job status areas on the Vectorworks Cloud Services home page once you click to another part of the site (Resources for example). By clicking Home I get back to my stuff but the job status area is gone even though there are jobs still in process
    Yes, you need to click on the New button for the status bar to open.
  13. 18 hours ago, Kevin McAllister said:
    I think the issue is that you need to physically move the changed file for the Cloud Services timestamp to change. If you save over the file, the timestamp does not change because its not linked to the Modified time (Mac). Perhaps this is a limitation of Cloud Services.
    Can you provide me with detailed steps of what you are doing? From my testing, it seems to work as designed. Here is what I do:
    1. Create a new file in Vectorworks - > Save to my Vectorworks Cloud Services folder
    2. The file appears as upload pending in the Vectorworks Cloud Services Desktop app Status dialog, because the file is still open in Vectorworks.
    3. I click Sync Files button on the Status dialog and the file gets uploaded.
    4. I refresh the VCS Portal page, I see the new timestamp of when the file was last uploaded.
    Is this the workflow that you are referring to?
    The Portal timestamp represents the time when the file was uploaded. The desktop app does not upload files every time the file modification date/time changes on your computer (i.e. you save the file in Vectorworks) to prevent too much data from being sent over the network. It uploads automatically when you close the file in Vectorworks, but you still have the option to upload it while it is still open by clicking the Sync Files in the Status dialog.
  14. 22 hours ago, Kevin McAllister said:
    It seems that "Cloud Publish" doesn't work with files in a Dropbox based folder. As part of the Cloud Publish workflow it asks to Save the file and when you do, Dropbox needs to sync. This causes a situation where the Publish job fails.
    I don't thing the job trully fails in this case. It uses the latest available version in Dropbox, unless this is the first time you are saving this file in Dropbox? I realize this might be an issue with bigger files, which take some time to sync.
    When you are submitting the Publish job for a file, which don't yet exist on Dropbox, the Publish dialog will highlight the items selected for publishing in red to raise a flag for you - see the attached image. In this case, you would be allowed to submit the publish request, but you will obviously not get the result you would expect. :-)
    There are a few Dropbox Publish workflows that can be improved. We will keep those in mind as we plan for our next releases.
  15. On September 14, 2016 at 10:46 PM, Kevin McAllister said:
    I also had issues with residual geometry remaining in a couple of viewports after processing. The solution was to re-upload the file with Save Viewport Cache turned off.
    Can you find the pdf file and the corresponding .vwx file version where this happened and send them to me at inikolova@vectorworks.net? File version history is available on the web portal by clicking on the file. You will see the file history as displayed in the attached image. I'd like to investigate this further. This could potentially be a rendering bug.
  16. Regarding your question number 5:
    Vectorworks Cloud Services always uses the latest version of Vectorworks, which is available to the public. We also keep the servers up to date with Vectorworks Service Packs. For example, in September we put Vectorworks 2017 on the cloud. When Vectorworks 2017 SP1 gets officially released, we update the cloud servers to use the Vectorworks 2017 SP1.
    Vectorworks Cloud Services also works with older .vwx version files, so you do not have to save all your Vectorworks files in the latest format. However, to ensure you have the best experience, we recommend that your files be saved in the latest officially released version of Vectorworks. For example, workgroup referencing: When you open a 2016 file, containing references, in 2017, the reference breaks until you save the referenced file into 2017 file format. It works the same way on the cloud.
  17. Regarding your question number 4:
    I did some testing, and it seems like when you have a drawing label using a custom font, and you open the file on another machine, which doesn't have this font, the custom font gets mapped to Arial by default. The same thing happens on the Cloud when the original font is not found. I can reproduce the issue with the text extending beyond the line when the font mapping occurs, so I believe this is bug specific to Vectorworks, not Cloud specific. I filed a bug for that to the Vectorworks team.
