2,959 -
Posts posted by Bruce Kieffer
Yikes. Time to increase the Prevagen!
So obviously there is no interactive setting to do this. That is sad since that is where we can go to modify the colors for many settings. Wish list here I come. @Pat Stanford, I'll see what I can do about getting your daughters that pony they want.
1
Thanks @Tom W. and @Pat Stanford I found it.
I can hide objects in a viewport using the hide object mode of the visibility tool. How do I get all of the hidden objects in the viewport to show again? I tried double clicking the tool icon and I tried the Unhide Objects command, but they don't work.
I have added a few new devices and updated the record to include the brand. Here's the file:
4
Thanks @Pat Stanford for trying to help figure this out. I'm going to walk away from this now since it appears the info Vectorworks is trying to convey is not info I need, but I do still wonder if maybe they use this info for VoiceOver. For my use, I would find it more beneficial to enlarge the hierarchy so I see that better.
1
I see "C"s too. The mystery continues!
Thanks @propstuff and @markdd. Both of those methods work. I knew there had to be a Vectorworks way!
1
Nope, can't remove the command. Oh well, I will just ignore it then.
21 minutes ago, rDesign said:
It’s meant for editing Interior Elevation Section Viewports. From the Vw2025 help file page on Editing Design Layers From a Section or Elevation View
Thanks @rDesign. Since I will never use it, I will remove it from my context menu. That is my plan.
I see this command when I'm in a Viewport and I right click on the VP. I can't tell any difference from Edit Design Layer.
Yep, patience is the key. I see it now.
1
2 hours ago, Josh Loy said:
What does that mean? Do you want the objects to move with it?
Just like redefining a saved view. No, I don't want objects to move. Say I created an object and set a working plane to the top, and save that WP as "Top." Then for some reason I rotate the object, set a working plane for the new orientation of the top, and save it as "Top". Then I want Vectorworks to ask me if I want to overwrite the exist WP named Top. As it is now, all I can do is cancel because Vectorworks says that name is already in use.
1
It sure would be nice if we could redefine a working plane.
1
46 minutes ago, Tom W. said:
Only I think by right-clicking on it in the 'Working Planes' palette + selecting Edit... but that requires you to enter XYZ + rotation values manually which isn't really the same thing. If you edit a Working Plane in the drawing then go to resave it with the same name it doesn't let you overwrite it. So no, you can't redefine a Working Plane as far as I know. It would be useful to be able to though.
Wish list item!
Storm Door Drawing?
in General Discussion
Posted · Edited by Bruce Kieffer
Does anyone have a storm door drawing to share? I need one for a 36 x 80 Andersen 4000 storm door. Anything close I can modify. I did contact Andersen and they said they don't share their storm door drawings. That seems strange since they share all their window and door drawings.
