875 -
Everything posted by Markvl
@Matt Panzerthanks for responding. The problem appears to be only with "base" cabinets. All the others are fine. But have a look. I"ve attached a File. Fixtures-Cabinets.vwx
So I'm working now in VW2021 sp1 and I'm going to use some cabinets to put together a kitchen layout for a 3D render and I notice that I'm missing a couple of buttons to add door and drawer hardware. I went back to VW2020 and they are there but not in VW2021. What happened there? Would someone from VW take a look into this? @JuanP I've attached a couple of screen shots. First shot is from VW2021. The second shot is from VW2020.
Bring Back the Unique Release Colors
Markvl replied to Tom Klaber's question in Wishlist - Feature and Content Requests
Hey @fabrica I took the liberty of taking your *.png image file and making an *.ico of it to share so others don't need to convert it. I love the colour you chose. Thanks for sharing. This is a PC file folks. Use @Tom Klaber method above to change your versions icon. Having to much fun now. Here is one more. GET BACK TO WORK YOU SLUGS! VW-Logo_Minty.ico VW-Logo_Bluey.ico -
Transom Settings in One Place
Yes please. -
2021 - Teaser Tuesday: Collaboration Improvements Make Us Better Together
Markvl replied to JuanP's topic in News You Need
THEN DEATH YOU SHALL HAVE. (Add in your own evil laugh in the background) -
Garage slabs below Main floor and Garage doors for 3d models
Markvl replied to Patrick Davis's topic in Architecture
I reshape walls all the time. But using a wall recess to make the cut at the top of a wall for a door is something I've never thought of. Will give it a try. -
Any improvements to stairs, windows and doors is a plus for me. Ya I'm still waiting for a stacked wall solution. Stacked walls was my first wish here on the forums. 5 years ago. -
I gotta say I'm still waiting, slightly holding my breathe that something architectural will be shown. The last two versions have been very abysmal when it comes to something I can use. So far only the new 3D modeling tools is anything praise worthy from my end. -
The VW Help was no help. It's like the software installed on my machine is missing something. This a screen pic of what I get when I click on "Create Animation" under Model.
Is anyone else having trouble creating a basic animation. I just want to do an orbital animation around a model and I get nothing. Zip, zero, nadda.
Fantastic. Figured there would be a way. Thanks @Boh
Is there a way to make a revision act like Project Data so that I only need to type out Issued for permit once with a date and similar other items?
Heliodon: sun brightness setting very unreliable
Markvl replied to line-weight's question in Troubleshooting
Well you're not alone. Hope that makes you feel a little better. It certainly is inconsistent and less so at least for me with vw2020. I've had to do all the things you posted and that would usually fix it. Just a shame that one has to go thru all that to make it work when it's not working. -
Problem with Window Trim using Jamb Extension
Markvl replied to Markvl's topic in General Discussion
Yes this is the exact problem. I suppose you could submit this as a bug from your end. Thanks for having a look @Wes Gardner -
Will do. -
@Wes Gardner A quick update. I adjusted my jamb width to 1/2". Essentially matching my jamb extension and look what it does, it fixes the issue. But this is not the result I want. When I set my Jamb width to about 4.5" I actually create a more realistic effect of how a replacement window looks. The jamb extension in many ways should be called a drywall return. -
@Wes Gardner Hmmm...well I tried another window. I set my jamb depth to 4.5" and my extension to 1/2". Again the side trim works out fine but not the bottom or upper trim. See pic attached. You'll see in the pic that the bottom trim creates a kind of 3D pocket. -
No thoughts from VW staff? No thoughts from anyone? I suppose that the plan view by far is the most important but the correction to be made to the sill and header would make interior shots far better. -
Was just looking thru the latest libraries offered on Service Select. As a suggestion, perhaps some residential outdoor lighting, some new cars, another fire truck or even new door leaves. I know I can make my own but a good update would be easier.
This is for the tech guys at VW. Perhaps we could see a fix in upcoming service packs? I've been toying with 3D window details such as using "Jamb Extensions" but I've noticed a glitch in how Interior trim interacts or positions itself in relation to the Jamb Extension. I've attached a couple of screen picks to illustrate the problem. I've never noticed this before as I've never used jamb extensions in earlier versions. I used clip cube to show this issue from a right side position. This is not an issue in top/plan view as seen in the second pic. It also does not matter what type of window one illustrates; Casement, single hung etc.
I'd like to recall data from a column in a worksheet primarily for volume of concrete. Can't seem to find the info for this.
It has been on my wish list for the past 5 years. I try not to get to excited around release time. Last few years have been slim pickings for the Architectural side of things.
Fantastic gentlemen. Thanks!
Is there a way to reduce the steepness of the contours created by a pad? I'm a newby at using site objects. I just can't seem to find anything to do this. I've tried looking at the Site Model Surface tool but that is tedious when there are many tessellations.
