875 -
Everything posted by Markvl
@Chris Fleming that seems to be doing the trick. Thanks.
Hey forum how do I best keep vertical items vertical in perspective to keep the image more realistic and avoid a fish eye kind of result.
Associative Dimensioning on 3d models
Markvl replied to Bas Vellekoop's question in Wishlist - Feature and Content Requests
This would be so fantastic. This is one thing I liked about Revit Families.- 7 replies
- associative
- dimensions
(and 2 more)
Tagged with:
Sounds like a nice wishlist item @Rishie
- 1 reply
- 2
That works @Nikolay Zhelyazkov. Thanks a lot.
Hey Forum. I need some help. It seems I've done this before but have forgotten how to do it. I'd like to create a custom data configuration for a particular titleblock that we use for siteplans. I like using a master subdivision plan and insert (reference) house plans and then using sheet layers to create individual siteplans for the different lots. Using this method though creates a small problem while using and "Sheet Data.Sheet Number" as this references the Sheet Layers in the Navigation Panel. Meening I can't use Sheet Number "100" for each individual Sheet because you'll get the error "That Sheet Number is Already in Use by and Existing Layer" So I want to create a custom Data config rather than rely on the Sheet number in the Navigation panel. Get me? Also I want to add a config so that I can have a "project name" under sheet parameter rather than the project parameter so that this name doesn't override the other sheets in the file. I'd like a config Like "Sheet Data.Project Name" I find that this process is not very intuitive. So I need your help. Thanks!
I'm following this thread as I too have some questions on textures attached to imported objects as meshes. Once you open a mesh it looses the texture. How does one restore the original texture?
Hi @Sidney Lo a little curious with the confusion as I have 2017 still and all is where it should be. See pic attached. In the pic you will see I have the Wall Join Tool Selected (highlighted in blue) and in the tool mode you'll see I have "L" join mode and the "uncapped" mode selected (also highlighted in blue). Not sure how you can be missing the "T" join mode.
first nations and native american, ethnic people
Markvl replied to mchevalier's question in Wishlist - Feature and Content Requests
What "choice" are you referring too? -
@Inspectorjack I hear ya but when you're doing a 50+ unit multistorey apartment building, using the framing tool gets long and tedious.
- 9 replies
- worksheets
- slabs
(and 3 more)
Tagged with:
Hi @Wes Gardnerit would be quantity of 2x's not BF.
- 9 replies
- worksheets
- slabs
(and 3 more)
Tagged with:
Math is not a strong suite @CipesDesign How do I apply those board foot numbers to a slab for instance. We'll use a space that is 10ftx10ft using 2x10's
- 9 replies
- worksheets
- slabs
(and 3 more)
Tagged with:
As we all know when we draw walls, floors (slabs) and roofs the component portion of each object representing lumber is a monolithic object that in itself can only give area and volume. How does one determine board feet or the number of joists, studs or rafters required from the data we can retrieve from these objects. A formula of course. Would anyone care to share how that is done? I haven't figured it out yet. I'd like to get estimating materials worked out more for the company I work for using the models we create. More BIM! Thanks.
- 9 replies
- worksheets
- slabs
(and 3 more)
Tagged with:
I didn't realize I could make a property line using the "Create Object From Shapes Command..." SWEET! The Property Line tool is very cumbersome in trying to generate property lines.
Force Redraw Required for all actions - 2021 - multiple computers
Markvl replied to Tom Klaber's question in Troubleshooting
I get the same thing. You're not alone. -
Another great tutorial Andy. Precise and to the point. Very easy to understand.
I would simply say up your Dpi to 300. Do you feel like you've had sharper images at the same Dpi on other files?
@Thomas Wagensommerer I figured that is what you were getting at. I was hoping to be able to turn off the "elevation and diameter" by assigning a class but doing so also turns of all the other alphanumeric text. Wish list I guess.
@Thomas Wagensommerer are you referring to size and font? If so what I do is create a Slab-Notes class and when you select the Slab Drainage Tool you will see the settings button on the end. In the dialogue box you can apply all those text items to one or more classes.
@VWVSpass this thread may be of help to you.
Haha @zoomer beet me to it. Couple of things came to mind. 1. Considering how the door is sitting in relation to the wall. Perhaps your wall design (how you lade out the components) may have something to do with. or 2. See pic attached. @zoomer picked up on it. Perhaps your "Offset in Wall" needs to be filled in with the difference to push back the door system. Note: you can give that offset a negative distance to push it back or a positive distance to push it forward.
@MGilc I would suggest perhaps inserting 3 windows rather than trying to create 1 window using the window tool.
Thanks @Pat Stanford and @Matt Panzer. Removing the base cabinet tool and re-attaching it did the job. Working as intended.
@Matt PanzerI've even started a new blank file and inserted the original base cabinet from VW's default libraries and I still get the same problem. The other symbols from Cabinet Utility and Cabinet Wall do not have this problem.
