Has anyone got some dimensions of a DHA/Rosco animation disc with motor or "KK Wheel". Happy to make the symbol myself but google is failing me for the dimensions.
Thanks in advance.
Just wondering how people go about making a symbol for something like this, I would class it as an accessory and want to draft it as such but obviously it is something at affects the pan and tilt of a fixture in this case a cantata PC.
Would it be best to make a symbol for the whole set up rather than an accessory symbol to add to my current lantern symbol?
It would be great to hear thoughts on this or see some examples.
Thanks Mark,
Doesn't seem to of done much, my work around for the moment that seems to work is to add each symbol one at a time to the summary. Slightly dull when drafting a musical with a lot of different fixtures.
Thanks again,
Will
I am currently working on a file that i started in 2017 and have moved over to 2017.
The instrument summary isn't allowing me to build a list it just come up with a box with a cross in and when i repeat this i can only add a couple of symbols to it at a time, i have tried a new file with the same symbols and they go in properly.
Is there a way to reset the Instrument summary tool so it behaves the same as when you first use it in a document?
Thanks in advance
You need to attach a parts record to the 3d components and position them in the correct way the fixture in edit 3d component make sure you place a 3d locus in the middle of the head and include it in the body part of the record.
Watch from about 5.15 same process applies with a moving light
I have just had this issue resolved with the help of tech support. It was indeed the run time cache folder did you make sure to empty trash after deleting the file?
