879 -
Reputation
280 SpectacularPersonal Information
Occupation
Senior Solutions Specialist (Entertainment). Vectorworks user since 2001, Lighting Programmer, Designer since 2004
Homepage
https://www.instagram.com/tomwhitelight/
Hobbies
Lighting, Cycling, Cooking.
Location
United Kingdom
Recent Profile Visitors
4,623 profile views
That looks to all be correct. Last thing to check is that you are in a top/plan view not a top view. If so I would contact support.
" I found the problem. Schematic views are ceating this bug. To fix the bug you need to have the schematic view in a closed design layer." Hi @JF_P Sounds like this is working as designed, we won't list this is a bug because its not a workflow feature that we would ever support. The best workflow for sending to vision is to use a saved view that hides (closes) any objects that you do not want to send to vision.
Equipment Summary / Inventory Management filter
TomWhiteLight replied to Mickey's topic in Entertainment
"I just want to put a Key on my plot.." Of course but Vectorworks cannot guess how you want it to appear or how you want to filter it? "I don't want to edit or troubleshoot Vectorworks software anymore." I don't think anyone is asking you to do that. If you don't know how something works, just ask, we are all here to help. I don't know the ins and outs of the instrument summary tool, Personally I use the graphic legend tool to filter by class, it even filters by viewport. So this is possible In Graphic Legends, I am sorry that you don't know how to achieve this in the software, I am sure a brief call with us would get you up and running in no time. If you invest some time in learning these new tools you will really reap the benefits. "This key was a brand new one a mere minutes old, and when I edited it the program crashed." Ok so clearly there is a problem with your installation, the forum is not tech support, please reach out to them, the users on this forum cannot help you troubleshoot your installation. Tech support can then re-direct you to the training team who get you set up. -
You can apply filters, I will let Scott explain those. "Oh well. Vendor is not a parameter in Lighting Device-Parameters." If you want to you could easily add this parameter to the Lighting Devices if you so wished? "trying to edit a key I dropped on the plot." - Was this a key created with an earlier version of the software? Best to create a new one and save as symbol. -
MVR export : focus information
TomWhiteLight replied to Light-House's topic in Vision and Previsualization
I think focus information will go in the 'ESC' format. If you export lights with focus info as .ESC and the rest of the model as .MVR. -
Data visualisations in Equipment Summary Key
TomWhiteLight replied to Mike Wright's topic in Entertainment
@Wesley Burrows I wonder if you need two data visualisations with the same colours but one for light info record and one for lighting devices in schematic. -
Braceworks Calculation report PDF low quality
TomWhiteLight replied to Mathijs van Ommen's topic in Braceworks
Have you tried it in a different viewer?- 6 replies
- braceworks
- pdf export
(and 1 more)
Tagged with:
Can't paste cells from excel into report
TomWhiteLight replied to Daniel Dickman's topic in Entertainment
You will only be able to copy/paste into fields that are displaying Record.Field data. @Pat Stanford is correct. We have discussed the possibility of allowing users to edit this data from a worksheet, the functionality isn't there at present and whilst a powerful idea it may cause some unintended consequences. I have an existing enhancement request for this. -
Marionette Node?
Have you come across ConnectCAD? It's more suited towards AV workflows. You can create a signal flow diagram of your speakers and associate circuits with drawn cables on the audio speaker layer. The cable tools are really geared to power and mains distribution (for now at least).
Automatic Fixture Renumbering for Fixture Expansion
TomWhiteLight replied to Cristiano Alves's topic in Entertainment
The closest you get to selection order is specifying the direction 'manual'.
