107 -
Everything posted by thinkingpencil
Since the Design Summit 21 I've been publishing to the cloud using Vectorworks Service Select. Brilliant! Thought I'd share an experience. Cloud publishing is not possible if your filename has the usual unsupported characters like "&" "-" etc. This also applies to folder names. The error message is "file must be saved to cloud"....so the unsupported characters prevent uploading even though you've saved the file (and folder) to your desktop mapped drive.
- 5 replies
- 2
- publishing
- cloud
(and 1 more)
Tagged with:
Extrude along path not working 'as expected'
thinkingpencil replied to hollister design Studio's topic in General Discussion
EAP works and doesn't work for me! I have edited the path but it has no effect on the 3D object...? I conclude it's usually faster to make a new EAP object rather than edit the first EAP object....or of course get it right first time!! -
Thank you all. Jonathan's video is so clear. I found this thread whilst trying to answer the following question. Can anyone answer it? Think I'm missing something simple!? Question :- I have a wall with bottom boundary set to a level in the storey below. I want to set its top boundary to the same level. Then figure a + offset to set wall height. When trying to set the top boundary in this way I can't see "(story below)"-choices in the drop-down menu. But at the top of the list is "Stories" ...so I think I could select that to add the "(story below)" choices? But if so I can't see how. ...Maybe I should just stay with the wall height set to the level called "New Ceiling Porch". VWX 2021 SP3.1 Incidentally levels are really helpful to me. I set them to reflect levels in the survey of the existing building. Most of my projects are on existing. I like to use Storeys so I am ready to design that multi-storey hotel in the Carribean....we don't have many of those here in the north of England. Thank you to all for your time and expertise which I value highly.
Extrude Along Path - Scale + Factor: Locked?
thinkingpencil replied to trashcan's topic in Solids Modeling
Same problem. I drew two 3D polygons for the inner and outer hand rails of a stairway. The first one worked first time as the path for my profile object. The second not. Even after I reversed the direction of the path object in the OIP. But when I re-drew the 3D polygon in the direction away from the profile object the tool operated perfectly. So the only thing I can think of is that I had drawn the 3DPoly towards the profile object which may have prevented the tool working. And reversing in OIP wasn't effective. So you have to draw the path in the right direction, away from the profile object, first time? -
@STR I'd like that work/browse facility too. My file 2 would be the one containing core Keynote Legends. These I may revise whilst referring to an Edit wall style window. Screen shooting doesn't seem right!! But it's 21 now so maybe this faciity is here now? .....and I may have a third referenced file open.
I used the Split tool to slice off the mitres om top plan.
Callout opacity settings not aligned by class and object.
thinkingpencil posted a question in Troubleshooting
I've set a callout class with opacities:- 50% fill and 100% pen ; opacities not linked, graphics attributes to be used at creation. But callouts have both fill and pen opacity 50%. Attribute check boxes for pen opacity are greyed out...anyone experienced similar? Am I missing a setting? -
Just sharing a work flow many will know. But less experienced colleagues maybe not. And there may be an easier way? And I could have used the stair stool to create a circular stair. But this stair is irregular and I wanted to try using new tools. (I don't like "spiral" stairs. Because they seem a design-cliche` to me. But a paying client wants one!) So I modelled something like it using the loft surface tool (LST). In birail sweep mode. Workflow :- Draw balustrade members. NURBS tool to draw a curve across their tops. Duplicate it. Lowered one by the depth of my handrail section. NURBS tool again to draw the handrail section. Then the LST. The online video via Help is useful. Fun!
Referenced Viewport Classes as Worksheet Criteria?
thinkingpencil replied to Pat Stanford's topic in General Discussion
Hi Patrick. My workaround is rough! I pasted the objects from the referenced file into the file containing the worksheet. Then added the record format to those objects. Both files are attached The referenced (source file) is "proposed". The worksheet file is "existing". Fortunately the worksheet is simple, and the objects reported in it are few. I hope this helps! Kind regards, Mark 201110 GA 100 Existing 17.39 v2021.vwx 201110 GA 101_2 GA Proposed 18.50 v2021.vwx -
Clip cube section viewport and sketch or hidden line
thinkingpencil replied to JMR's topic in Architecture
@isyme In my horizontal section viewport 2D objects can be rendered sketch by checking "sketch hidden line results" in "foreground render settings". 3D objects cannot. Which seems logical... -
Agreed...see this in wish list:-
Any Advice for Setting up Walls When 3D Modelling Renovations
thinkingpencil replied to MaltbyDesign's topic in Architecture
Respect. Thank you Kevin. Advice accepted! I agree that ideally we only ever create a 3D model. After many years of large scale practice I now choose small scale. So I am a designer again, not a team manager. But I am competing in a very competitive local marketplace. If I built a model of the existing building accurate enough for construction docs downstream I'd price myself out of the market place. However...on my next commission I will obtain a survey of the existing building consisting of a point cloud from laser technology. I am aiming to import these data into my VWX file. So, hopefully, making my 2D workaround unnecessary. I'll let you you know how it goes! Mark. -
I concluded the sill function in windows tool works only for single skin timber framed construction. So for what I understand as a traditional north american construction method. I use a sill symbol nested within a symbol which has all the other components needed. Meaning a drylining on the inside, sometimes a rendered or stone reveal on the outside, cill board etc. So the window is in-wall. And the "components" symbol makes its own wall-hole, using an object tailored to the components.
Hi Tom, In this image I show the massing model (as well as the wireframe one, made of the 2D objects to compose elevations). Incidentally in the first image I used a template. So that shows misalignment between the section and the side elevation because there's two projects in there! In this second image I've corrected that so now you can see the section and side elavation mapping onto eachother. There's no fourth elevatoin because this existing building is semi-detached. The massing model is made from roof faces, solids, and a wall type. Using just a few "massing classes" (walls, roofs, glass etc). The wall type has just one component, class "walls". It's width is precisely the same as a wall type with various construction components. So later in the design process I can easily change the wall type to create a construction model. At this stage floor plans are simple 2D ones using filled coloured polygons to show spaces . You could use the space object for this. PS I have not been to Norfolk recently. But was in Cambridgshire. They have a local rendering/plastering technique...been trying to google its name, unsuccessfully... Regards, Mark Model WF and OGL.pdf -
The link posted by rDesign I also found helpful. Also... ...I create 2D plans, section and elevations from on-site survey measurements of existing. I draw the plans on separate layers arranged in storeys at specified levels. They are drawn on layer planes. Then I draw the section on its own layer and on its own working plane, WP, perpendicular to the layer plane. I draw the north and south elevations on separate layers but on the same working plane. That WP is also perpendicular to the layer plane. Similarly the east and west elevations are on two more layers, both on a second WP. That WP is also perpendicular to the plans. And perpendicular to the north-south WP. This leads to a sort of rapid reference model of existing viewable in 3D. Meaning you can see floor plans, elevations and section arranged in their correct planar orientations. With plans are real surveyed levels. But all objects are simple 2D lines. I can then build a 3D model related to the 2D objects easily. Without having to build a 3D model of the existing. Which is time-consuming. And hard to do so that it accurately reflects the survey. E.g. of a 17th century stone built house here in the English Peak District, where no walls are parallel and all vary in thickness and by level! In this example I've switched off two of the elevations. I actually drew the section on the same WP as the N/S elevations. By using the same WP for opposite elevations you can generate the second elevation very easily in outline by duplicating objects and changing their layer. So it makes sense to put the section on one of the elevation WP's to generate the elevation outlines in this way. As in the link above I use a "demolition layer" mirroring every "existing layer". Then for each pair there are any number of "proposed" layers. So this method does not rely on classes for differentiation between whats retained, demolished and new. Any and all comments welcome! Example of 2D Model.pdf -
Hi Jeff, no but I will now try "use symbol geometry" . Thank you so much for taking time to provide the example. So encouraging. I work solo these days here in Macclesfield, England. And miss the educational environment of a large design office. So interactions like this are especially valuable. Thank you again. They prompt deeper understanding of the awesome capability of VWX. By nudging out of the normal track. The comfort zone is not the learning zone! Best, Mark.
Worksheet not seeing Records in Reference Viewport objects
thinkingpencil replied to bcd's topic in General Discussion
I think I am experiencing the same issue, trying to pull information into a worksheet by a criterion which is part of a record format. The record format is attached to my target objects in a file referenced into the worksheet file through a design layer referenced viewport. But then, my worksheet can't see the objects when criteria are set by class, layer.... -
From another thread this seems to be a known issue. I am using a record format to pull the information into the worksheet. -
Hi Pat, I found your post whilst trying to solve a problem. That may be related to your question...I am trying to report values in a worksheet from objects in a referenced design layer viewport. I have set the database criteria to include design layer referenced viewports, by checking the right box. The DLRVP is up to date. I can see the objects. The worksheet shows identical objects in the worksheet file. But not from the referenced one...Ive also set criteria by layer, class etc. But the worksheet remains blind to the DLRVP. -
Curtainwall Wallarea_Net Values aren't returning Net Areas
thinkingpencil replied to Samuel Derenboim's topic in Architecture
Thank you Pat. For experimenting and providing this logical analysis. Makes perfect sense. Incidentally...My work-around was to create a new wall type, whose components are those of an insulated composite wooden door leaf. This wall is actually a fixed panel and large floor-pivoted door (door height =panel ht.=wall ht). The new wall with the curtain wall is an entrance screen. So Vectorworks shapes the architecture through the workaround. It is the logical performance of Vectorworks which enables this. Making it such an intuitive joy to work with. -
Hi Samuel, I got the same problem. I tried a "curtain wall" door type. And also a plug-in object from a manufacturer. Neither made any difference. I think there may be a separate worksheet function for the net area of curtain walls. But I can't find one! (Only one for net area of panels.) Pat Stanford , a veteran and moderator of this Board, is probably the go-to person for help on this. He has helped me with worksheet functions in the past. I'd be interested to hear more. Best, Mark -
Hello. Anyone finding it hard to change the colour of glazing bars , and glass, on the Wasco Skylight "Ext Pyramid 350PHYG 1212 Slab" ? I downloaded this symbol fromm VWX libraries. Great detail. As expected it's several nested groups. At the core of these the glazing bar is a Generic Solid. Which seems not editable (Edit/greyed). I've experimented with class attributes, changing classes, etc etc. But black is the only option is seems? Wasco actually ship in various colour options. Any insights welcome. Thank you. VWX 2020, latest SP.
Walls grey in resource manager and model 3D view
thinkingpencil replied to thinkingpencil's question in Troubleshooting
Thank you for your fast solution Pat. Indeed. And in fact I overlooked two settings . Now applied :- 1. Wall style must be set to Edit wall style/textures/Use component textures. 2. Wall object class fill must be set to solid. Best, Mark.- 2 replies
- walls
- resource manager
(and 2 more)
Tagged with:
