quote:
Originally posted by Katie:
You can toggle the control line of which the wall is drawn from only when using the Wall Tool.
(L shaped wall icon in the walls palette.)
Toggling the control point iwth this tool uses the U key. THe I key will bring up the preferences dialog for the wall tool.
When using the Wall Type tool, this control point is set by the wall type definition under AEC>Select Wall Type
SElect the wall type you want to use or create your own and click on edit.
The control Offset value determines where the wall be drawn relative to the line drawn on the screen.
