Sebastiaan
335 -
Posts posted by Sebastiaan
5 hours ago, Pat Stanford said:
Good luck.
Hi Pat,
Thank you. I must admit I was secretly hoping for you. But by not having the time you motivated me to do it myself ;-). I couldn't let it go and I now have it working for the second level with nested folders too! There are a couple of items in the import that could have been in a third folder but I am not going to bother with that. Very happy with the result and that I managed myself. See the code and example file below:
symid = vs.FInFolder( vs.GetObject( 'DXF_DWG' ) ) fldrlist = [] symlist = [] while vs.GetTypeN(symid)==16: symname = vs.GetName(symid) symsub = vs.SubString(symname,'_',2) if symsub not in fldrlist: fldrlist.append(symsub) symlist.append(symname) symid=vs.NextSymDef(symid) cntsym = (len(fldrlist)) cntsym2 = (len(symlist)) sym=symid scndlist = [] for i in range(len(fldrlist)): fldr1 = fldrlist[i] for j in range(len(symlist)): symname = symlist[j] scndfldr = vs.SubString(symname,'_',3) chkfldr = vs.SubString(symname,'_',2) if scndfldr not in scndlist and chkfldr == fldr1 and symname.count('_') >= 3: scndlist.append(scndfldr) vs.NameObject(fldr1) vs.BeginFolderN(16) for k in range(len(scndlist)): fldr2 = scndlist[k] vs.NameObject(fldr2) vs.BeginFolderN(16) vs.EndFolder() vs.EndFolder() scndlist.clear() for i in range(len(symlist)): symname = symlist[i] if symname.count('_') >= 3: fname = vs.SubString(symname,'_',3) else: fname = vs.SubString(symname,'_',2) insrtfldr = vs.GetObject(fname) insrtsym = vs.GetObject(symname) vs.InsertSymbolInFolder(insrtfldr, insrtsym)
- 1
update:
I managed to get a script working for creating folder based on a substring of the symbol names. And placing the symbols in their corresponding folders. This does not create nested folders yet, but I may leave it at this an enough of a satisfactory result. Maybe I could get it to work to create multiple nested folders if I make a list with a sublist of substrings or something like that.
symid = vs.FInFolder( vs.GetObject( 'DXF_DWG' ) ) fldrlist = [] symlist = [] while vs.GetTypeN(symid)==16: symname = vs.GetName(symid) symsub = vs.SubString(symname,'_',2) #vs.AlrtDialog(symsub) fldrlist.append(symsub) symlist.append(symname) symid=vs.NextSymDef(symid) cntsym = (len(fldrlist)) vs.AlrtDialog(cntsym) sym=symid if vs.GetTypeN(sym)!=16: vs.AlrtDialog('All symbols shown') i = 1 while i < len(fldrlist): fname = fldrlist[i] chkfldr = vs.GetObject(fname) if chkfldr == 0: #vs.AlrtDialog(fname, ' ', chkfldr) vs.NameObject(fname) vs.BeginFolder() vs.EndFolder() i = i + 1 i = 0 while i < len(symlist): symname = symlist[i] fname = vs.SubString(symname,'_',2) insrtfldr = vs.GetObject(fname) insrtsym = vs.GetObject(symname) #vs.AlrtDialog(insrtsym) vs.InsertSymbolInFolder(insrtfldr, insrtsym) i = i + 1 #vs.AlrtDialog(vs.SubString(Symname,'_',2))
Maybe this topic should be moved to the Python forum because I have been trying some different code snippets in Python.
I can create a folder in a folder or even two folders in one folder with the below code. It would only have to be made dynamic based on then delimited substrings of the symbols.
vs.NameObject('Audio') vs.BeginFolderN(16) vs.NameObject('AudioSubfolder') vs.BeginFolderN(16) vs.EndFolder() vs.NameObject('AudioSubfolderSCND') vs.BeginFolderN(16) vs.EndFolder() vs.EndFolder()
I can loop through a list of symbols in a folder and place a symbol in it's folder based on the last substring delimited by '_' However some how it only places one symbol in its folder I have to run the script again to get the next one in its folder?
symid = vs.FInFolder( vs.GetObject( 'DXF_DWG' ) ) while vs.GetTypeN(symid)==16: symname=vs.GetName(symid) symdepth = symname.count('_') fname = vs.SubString(symname,'_',symdepth) insrtfldr = vs.GetObject(fname) insrtsym = vs.GetObject(symname) vs.InsertSymbolInFolder(insrtfldr, insrtsym) #vs.AlrtDialog(symdepth,fname) symid=vs.NextSymDef(symid)
So making small steps, it has just been to long ago since I coded anything and these bit of code are copied from various topics. Would anyone be willing to give me a push?
Ok different aproach.
I used an Automator finder quick action to batch rename the DWG's with a prefix based on the nested folders that the DWG's are in. Before the name was Product abc.dwg and below is the result. This is an anonymised example file and folder structure.
I can now import the DWG's as symbols into 1 file and this will at least sort the imported symbols in the recourse manager in the same order as the folder structure. With two example files this import wil look like this in the RM:
Now would it be possible with a script to loop through the symbols in the RM and create folders and subfolders based on the prefixes delimited by the '_' in the symbol? The desired result would look like this:
As far as I can see there won't be an issue with the 63 character limit looks like I am staying under that.
The actual data set has 1000's of dwg's to convert so manual operation is not really an option. The sorted import list is already sort of workable, but if the above script would be possible I would be forever grateful.
Hi,
I have a set of many tiny DWG's spread across dozens of folders that I would want to import in place into VW files.
When I use the import DWG/DXF command then I can import all DWG's into one folder or all DWG's into one file. But what I would really want is is to have a batch import where for each folder of DWG's the import is done into that folder either one VW file with all DWG's from that folder or if that's not possible for each folder containing DWG's the import is done into that folder with one VW file per DWG file.
Even more I would want the DWG geometry to be imported as symbols into the VW files.
Would something like this be possible or should I start thinking about apple script?
On 2/17/2024 at 7:24 PM, HANKY said:
Hello, wondering if anyone has figured this one out yet.
I am having similar issues:
Added fixtures to a plot given to me by client,
created a new Label in Label Legend Manager
ticked boxes for Unit number, universe/address and circuit name
started spotlight numbering
the fixtures turn red like normal but no data is entered into the fields
im baffled.
Make sure that the field you want to number has a ✅ in the column ont the left of the window.
also when you want to alter the setting of the field make sure that you click on the field name on the left and that it is highlited blue when you enter something in the field settings.
these two are the most common user errors to check.
20 hours ago, Aiden said:
No, I didn't use a saved set.
The field I want to use "Channel Number" is selected/highlighted when I did this.
Unsure how to fix this issue - only happens in certain drawings.
Are these older drawings? In my files there is no “Channel Number” field. Just “channel” without the number. -
54 minutes ago, Aiden said:
Hi,
I'm having an issue where I go to channel number lighting symbols using the Spotlight Numbering Tool. Far too often I go to channel number lights using this tool and it doesn't work. Some drawings its fine, others it doesnt work.
I tick the Channel Number box and insert all the correct information.
I click on each light which highlights red.
No channel number information is recorded/retained by the lighting symbol.
If I manually select each light and in the OIP put in a channel number it works.
Is there something wrong with this tool?
Are you using a saved set to recall your channel numbering setting? In this case there is a bug that sets the number of units per increment to zero.
also make duren that when adjusting the field you want to number. That this field is highlighted blue in de spotlight numbering window. Only the field that is highlighted will be adjusted.
Make sure the unified view is on. It is in the view menu
What helped for me in some cases, not al unfortunately.
was to go into the edit 3d components of the truss symbol. And to move the geometry there for instance 1mm in 3D. This would force the geometry to appear again in OpenGL. Then I edited 3D again and moved the geometry back 1mm again.
hopefully this helps a little bit as a temporary workaround.
13 minutes ago, Marco Erbert said:
That would be awesome!!! And it can't be a rocket science...
the function already exists in Data Tags. It’s called a dynamic text field and I would really want to be able to use a dynamic text field in Label Legends! -
9 minutes ago, EJ Berendsen said:
I'm trying to make a 6 bar as done in the video. I can give each par64 his own channel number and patch. But I can not give each par 64 his own focus point. When I attach an focus point to one of the par's i get a red line indicating the focus direction from the centre of my 6 bar..
I'm working in 2021 can this be a bug?
there is a new workflow for multicell fixtures in VW 2021. You can find explanation about the new function here.
Hi All,
I am trying to get my head around manipulating accessories through Python scripts. Ultimately I would like to be able to position an accessory by a criteria such as the accessory name. I wonder if that is even possible as the function reference only seems to give handles to accessory index and not the name, but that is for a later step.
As a novice on scripting I am getting stuck on getting the GetAccPos3D & SetAccPos3D to do anything at all at this moment.
First I tried GetAccCount which worked instantly:
crit = "((R IN ['Lighting Device']))" def callback(h): NumAcc = vs.LDevice_GetAccCount(h, 0) vs.AlrtDialog(NumAcc) vs.ForEachObject(callback, crit)
Then I tried GetAccPos3D, and the script seems to run but does not do anything. I tested the ForEachObject with a test string in an Alert dialog in the Callback, so I am sure that this does step through the lighting devices. Also I tried various combinations of the Accessory index and Cell index, but to no avail. My assumption is that a single cell lighting device would have cell index 0, and in the OIP I can see that the Accessory I am trying to manipulate has #2 as prefix before it's name in the dropdown. So I assumed that the accessory index is 2. Nonetheless I tried many other combinations as well.Also I am uncertain on how to handle the fact that this function returns multiple values.
crit = "((R IN ['Lighting Device']))" def callback(h): outRotation3D, outPosition3D = vs.LDevice_GetAccPos3D(h, 0, 2) vs.AlrtDialog(outRotation3D) vs.AlrtDialog(outPosition3D) vs.ForEachObject(callback, crit)
Would anyone be able to push me in the right direction?
11 hours ago, iswope said:
Any luck with this? I have a similar need.
For Universe and address field since VW 2020 there is the ‘Universe/Address’ Field that Automatically combines the two fields together with a separator. You can change the separator if you like in the spotlight preferences.
for other fields I recommend the AutoplotVW plugins. It has a menu command called ‘copy field to field’ that will do what you want.
- 1
I do agree with this! Please give the option back to us. This has saved many hours of work getting viewports from one file to another. You do not have to advertise it as a recommended function. Just let us use it as the workaround that it was please?
1 hour ago, mercury2768 said:
Hello,
New Spotlight 2021 user here. I’m trying to add a container to my Channel number in my label legend manager but there’s no dropdown when I click the container section. It’s just stuck at none. Do I have to build these myself or am I missing some default ones like circle and oval and such that I need to get somewhere?
There is no dropdown there. You need to click on the word none in the row of the field that you want to add the container to. Click until it reads the desired container name.
when you open the Label legend Manager for the first time 4 default containers are automatically added to your document ( circle, triangle, Rectangle and hexagon). They are placed as 2D symbols in a folder named Containers in the recourse manager.
if that is not the case in your file you could try to open a new file and open the LL manager and then import the created container folder with it’s contents to the file you are working in.
Also you can create containers yourself. If you crate a 2D symbol and place it in the folder named Containers, it will then become available to use in the label legend manager. The insertion point of the containers 2D symbol will be placed at the center point of the text field that you apply it to.
On 10/4/2020 at 10:58 PM, Pat Stanford said:
Update. I THINK there is a bug and I have submitted it as such.
Basically the idea behind DatabaseByScript is that you run a script and in that script you do whatever you want to determine what objects you want displayed in the database. You are not limited to the standard criteria. They can even be different types of objects. This functionality was originally added in VW2020 to allow Landmark users to generate a schedule that would display the Landscape Area name before the list of plants that are in that area.
In VW2020 a Vectorscript command WSScript_AddHandle was added. Your DatabaseByScript script would figure out what objects to include and what order to include them in and then you would pass the handle to each object to the WSScript_AddHandle(YourHandle) and the database was created. Recalculate the worksheet and the script would run again.
In VW2021, in addition to the AddHandle a new function WSScript_AddHandleId that lets you add an ID (that I don't know what it is used for) to the returned value also.
But in the initial release (and the Beta of SP2), if you use AddHandle, or AddHandleId with an incrementing ID, only about 1/2 the desired items are returned. The workaround is to use WSScript_AddHandleId with a fixed ID.
The script has been parameterized to let the user specify the Record name, the Field name, the minimum value to return and the maximum value to return. The Field should contain a string representation of an integer. The only error checking the script does it to make sure the Field for each object contains a valid number. If the field contains a valid number then it converts the string to an integer and checks if it is in the range of the min and max (inclusive). Any items that meet the range are returned in the database.
Once you get the database sub-items defined you can use all of the standard worksheet functions to display information about the objects, Record.Field combinations, SUMmarize item and Sum Values.
There appears to be another bug I have not had time to fully research yet, but it looks like the first item returned is not SUMmarizing even if the column you are SUMing on is the same as other rows.
I have attached a sample file showing both Lighting Devices and also 5 rectangles with a custom record/field combination of PTS.MKS that I was using for testing.
Here is the script. Copy everything inside the Code block and paste into a new blank script in VW named
StringField_By_RangeTo enter the script convert a worksheet row to a database and accept whatever default criteria come up. Then right click on the database header row and choose Edit Database Formula. Enter the following to set a range of Lighting Device Channel numbers to display.
=DATABASEBYSCRIPT('StringField_By_Range', 'Lighting Device', 'Channel', 4, 105)
In the above, 4 is the Min channel to display and 105 is the Max channel. Change those two as you see fit. If you have other objects that have a numeric field stored as a string you can change the Record and Field names above to work with them.
Procedure StringField_By_Range; {October 3, 2020} {©2020 Patrick Stanford pat@coviana.com} {Licensed under the GNU Lesser General Public License} {No Warranty Expressed of Implied. Use at your own risk.} {A sample script to show how to use the DatabaseByScript} {functionality in a worksheet to create your own objects when} {the standard criteria are not enough.} {This was originally developed to allow the generation of a} {subset of objects (Lighting Device) which had a field that was} {formatted as a sting, but the user was using as numeric data.} {The desire was to get a subset of the channels using a Min and Max} {value. Since the data was a string, a simple Greater Than or} {Less Than would not work.} {This script is run from the Database Formula Bar using a syntax of:} {=DatabaseByScript('StringField_By_Range', 'Lighting Device', 'Channel',} { Min Channel Number, Max Channel Number)} {where Min Channel Number and Max Channel Number are Integers} {Procedure Execute does the heavy lifting. It converts the string} {representation of the number to an Integer. It then compares that} {Integer to the passed Min and Max Values. If the Integer is in} {the range then it adds the object to the database.} {The main body of the code only gets the parameters that are} {passed to the script and uses the passed Record & Field} {as Criteria in the ForEachObject procedure. ForEachObject} {gets a Handle for each object that matches the criteria} {and passes the handle to that object to the Execute procedure.} {As written, the only criteria is that the object has the} {passed Record (TheRecord) attached. The criteria in the } {ForEachObject line can be changed as necessary to return} {only the correct objects.} {The only error checking in this script is that the data in} {the field passes as TheField actually converts to a valid} {number.} {Do not operate heavy machinery or drive an automobile} {while using this script. If use causes excessive itching or } {unexplainable hair loss, discontinue use immediately and see} {a programmer immediately.} Var CMax, CMin, CInteger: Integer; TheRecord, TheField: String; B1: Boolean; Procedure Execute(Hd1:Handle); {Converts the value in TheRecord.TheField combination to a number} {If it is a valid number then it compares the data to CMin and CMax} {If the value is in the desired range, then add the object specified} {by Hd1 to the database} Begin B1:=ValidNumStr(GetRField(Hd1,TheRecord,TheField), CInteger); {AlrtDialog(Concat(Hd1,' ',CInteger, ' ', B1,' ',CMin,' ',CMax,' ',CInteger>=CMin,' ',CInteger<=CMax)); } If (B1 & (CInteger >= CMin) & (CInteger <= CMax)) Then Begin WSScript_AddHandleID(Hd1,1); {As of VW2021 SP2Beta1, AddHandle and AddHandleId used with} {a variable ID only return a portion of the expected results} {Using a fixed ID of 1 appears to return the correct items.} { AlrtDialog(Concat(CInteger));} {AlrtDialog added for debugging} End; End; Begin {Get the parameters passed top the script} TheRecord:=WSScript_GetPrmStr(0); TheField:=WSScript_GetPrmStr(1); {Record and Field are separate parameters because "escaping" the} {quotes properly to pass as a single Record.Field pair} {makes the script call almost unreadable} CMin:=WSScript_GetPrmInt(2); CMax:=WSScript_GetPrmInt(3); {Change the criteria in the next line to identify only the} {objects that any chance of being in the database. Additional} {criteria like, Layer, Class, In Symbol Definition, etc. would} {be typical. If you use the criteria builder, you probably} {want to edit the generated criteria string to use the variables} {TheRecord and TheField rather than hardcoded Record and Field} {names. This will provide additional flexibility for future use} {if you need to change the Record and field. They will only have} {to be changed in the DatabaseByScript call instead of editing} {the script.} ForEachObject(Execute, ((R IN [TheRecord]))); End; Run(Stringfield_By_Range);
Ask again where I have not been clear.
Really interesting Pat! Thank you!
I will now spend my time trying to actually understand what the code does.
5 minutes ago, Sam Jones said:
I just discovered it as a Worksheet function, not a VS function. In VW Help, search for "Databasebyscript". I am just investigating that documentation now. Good Luck to both of us.
Interesting! Although as I’ve only just plunged into the the world of scripting in VW, I might need some more practice until I attempt that! -
1 hour ago, Sam Jones said:
Database by script function? Where?
I’m curious what Pat meant with that too! -
11 hours ago, Pat Stanford said:
Yep, it looks like you can't use a Value command in a database formula.
What might make your work around easier is to use Question Marks (?) as wildcards for a single character.
=DATABASE((('Lighting Device'.'Channel'<='1?')) will return all of the object that have only two characters and start with the number 1.
1?? will return all of the channels with three characters that start with the number 1.
So instead of having to do ORs for 1 to 99 you could just do ORs for 1?, 2?, .... 9?.
At least a little easier.
VW2020 also added a new function called Database By Script that could be useful here. Let me see if I can make that work and I will post it.
Good idea to use the wildcards. That might make it shorter indeed. I will look into that. I do want 100 to belong to the 1 -> 100 range, but that shouldn't be too hard to fit in.
I was trying to find some information on the database by script function and did not see much information about in. But I am curious what it is.
2 hours ago, MullinRJ said:
Hi @Sebastiaan ,
I'm seeing that. After too much trial and error, I've come to the same conclusion.
Oddly, this works to show all 40 of the LDs'.
=DATABASE((NOTINREFDLVP & NOTINDLVP & (PON='Lighting Device') & ('Lighting Device'.'Channel'>'0')))
BUT, this does not work as expected:
=DATABASE((NOTINREFDLVP & NOTINDLVP & (PON='Lighting Device') & ('Lighting Device'.'Channel'>'1')))
It only shows LD's with channels 3-9, and 20. What I've noticed is that the DATABASE() engine is comparing strings, and not numerical values (as you'd like).
Strings starting with "2xxx" through "9xxx" satisfy the equation, but strings "10" to "19" and "101" to "120" don't satisfy it because the first character in each string is a "1".
You really need a VALUE() function, and that only appears to work in a worksheet cell, and not in a Database row.
Sorry, I'm stumped.
Raymond
Yes I was guessing that too. It also kinda makes sense when you think of it. There is no cell to represent as value. The function does not change the original database and would have to create a new list of the fields as number values which obviously it doesn’t.
I already have the workaround so it is what it is. At least I now know it’s not just me.
thank you!
3 minutes ago, MullinRJ said:
Like Pat, I don't have a file to test this, but if a LD does not yet have a channel then this might work.
=DATABASE( (NOTINREFDLVP & NOTINDLVP & (PON='Lighting Device') & ('Lighting Device'.'Channel'<>'') & (VALUE('Lighting Device'.'Channel')>=1) & (VALUE('Lighting Device'.'Channel')<=100)) )
This expression checks for an empty channel string before it tests the values in the channel
HTH,
Raymond
Hi Raymond,
The issue is that I think that the value function does not work as expected when used in a DB formula. So your proposed formula does not do the trick either.
Thanks!
8 hours ago, Pat Stanford said:
Can you post a file with a few lights in it. I don't really have time to create a plot to play with, but I would be happy to play with the database criteria and see if we can make something work.
Hi Pat,
Of course, attached is a file with 40 lighting devices. 20 of them have the channel field filled with numbers from 1 to 20. the other 20 have numbers in the channel field from 101 to 121.
Very curious if this will work in a DB formula.
5 minutes ago, Pat Stanford said:
What happens if you edit your original formula to use just 100 without the quote marks around it? The Value statement should give you a number and you have to compare a number to a number.
Also, does Lighting Device.Channel ONLY contain the "number"? If there is anything other than characters 0-9 in the field, then the Value statement won't work. I THINK that even an extra space at the beginning or end will cause the Value to fail.
I tried the formula below and this does not work either:
=DATABASE((NOTINREFDLVP & NOTINDLVP & (PON='Lighting Device') & (VALUE('Lighting Device'.'Channel')>=1) & (VALUE('Lighting Device'.'Channel')<=100)))
When lighting devices do not yet have a channel number assigned then the field will be an empty string (''). Would that cause a value function to fail too? That would be the only exception to a number in the text field.
I was already able to use the lengthy version in a script (with a variable in each of the 100 criteria and about 600 backslashes to escape the apostrophes ;-). So it works, but was curious if it could be shorter.
All Possible Things I Can Be Doing To Keep File Sizes Down
in General Discussion
Posted
There is a Coffee Break seminar on the VW university about exactly this subject. It might be worth it to watch that one.
some tips may be unexpected like images used in a title block can increase file size.
