theatre4jc
    24
Everything posted by theatre4jc
  1. Now it gets really weird, I changed nothing but updated the viewport again and suddenly everything works...
  2. I have an odd one that I cannot figure out. I'm making Sheet Layers from Cameras and on one sheet the gobos from the lighting fixtures are visible and in the next layer, the gobos are gone. The render settings, layers on/off, and classes on/off are all identical. I cannot figure out why the textures would disappear. The really weird thing is in one version of the project they were there, and in the next rendering they disappeared. When I go to Edit the Camera, the gobo textures render properly, but they are gone on the Sheet Layer. Can't figure it out at all. Thoughts?
  3. Sorry for the multiple posts. Soft Shadows was freaking it all out. I turned off Soft Shadows for all fixtures with shutters and instantly everything rendered correctly.
  4. I did not make changes to the instrument texture before this problem started. I did, however make changes while trying to problem solve. I did import in a default directional light because I wanted ambient light off, but still needed some light to model the house lighting. I can see the light but it has black specks throughout it in the render now. I have soft shadows on. I cannot get gobos to render I have tried copying and pasting into a new file and still a no go. When I did this I did not include the directional light. One thing I learned and did in my problem solving was figure out how to see the shutters in OpenGL. I can get this to work, however that will not help in the end because I need to show a full render. What is really confusing to me is it worked one day and then day 2 it didn't. Maybe I should try this in VW2020 and see if the issue follows the version. EDIT: 2020 didn't add the shutters but the light no longer showed the black specks throughout the render.
  5. I am working on a design for a historical building where I have been asked to light some statues on the walls. They have asked to see a concept of this so I have taken a picture of the wall that was provided to me and placed it on the wall. Then fixture by fixture I used shutters frame the statues. I did not go through all the steps to make the shutters visible in Open GL. Instead I used Fast Renderworks and framed each statue out. Time intensive, yes, but it worked for my needs. I got every fixture framed as needed. That ended my work for the day. Saved and quit. Day 2, opened the file and selected every fixture, turned on (because I was doing this one at a time for render times the day before and they were off), selected Fast Renderworks to quickly check everything, and no shutter cuts were visible. Quite literally nothing changed except turning on all lights. Going back and doing one at a time and no shutter cuts are visible. The Object Info Pallet is showing the shutter cuts properly. I tried adding in my Renderworks background and style that I always use and doing my custom renderworks and still no shutters. What could cause this to suddenly disappear? Is there a specific way to render shutter cuts in a custom rendering that I may be missing? Unfortunately due to NDAs I am not allowed to share the file or screen shots which will not help in problem solving. Using VW2021.
  6. I've got an old file that I've been updating and cleaning up some. It had fixtures from many different years of VW and I wanted to update to the new GFDT fixtures. Did this and when I tried to do a MVR file none of the fixtures show up in Vision. No Patch, nothing. However, if I export ESC everything is there and working properly. I use my own Vision Mapping Data for addressing in VW19 and tried changing that back to the default to see if that was the issue, and still nothing. Class visibilities are correct and on, so is Layer visibilities. When I do the export to MVR I am getting a list of several custom lighting instruments that all correspond to the lights on the plot, however nothing comes through in Vision. What could I be missing?
  7. This is extremely frustrating right here. We are trying to make our industry safer and work easier and a major manufacturer is unwilling to work with others. Yeah I'm trying to find out the weight of a Tyler Truss 12x18x96" stick and that's frustrating.
  8. Thank you for your reply. Turns out I had updated Vectorworks, but failed to also update Vision and didn't realize that. However I did notice if I changed the units from Millimeters to Feet, or Inches, my lighting fixtures all disappear. I can leave in mm and they work just fine, just something I noticed on my file.
  9. It's my first time exporting to MVR, I have a truss on a rake and when I Export ESC everything works properly and looks correct. However when I import a MVR file the rake looks like this: You can also see that all my fixtures have rotated and nothing connects properly. All fixtures are rotated funky and this truss no longer rakes as it should. When I exported I selected all objects and opening in Vision on the pop up window, after the first failed attempt, I played with the settings and still had no luck. Is there something I am missing?
  10. I have a client that has made a request for custom set pieces lit with LEDs of some type. The set pieces will be simple to build using metal framing and plexiglass, but I'm not sure how to best draw this in VW. At first I was going to do a simple extrude and just make it the be a glowing color. But what I would like to do is draw the extrude with a LED fixture at the top and bottom to illuminate the extrude internally so that I can show it properly in my renderings. Issue I'm having is how to do a texture to mimic frosted plexiglass. The frosted glass textures that come with VW are to transparent and I couldn't find a texture that would pass the color, but not be able to see into the object. Any thoughts on how I could get this accomplished?
  11. Is it possible to create a ceiling tile grid inside Spotlight, or is the tool only available in Architect? I looked but couldn't find it and didn't know if I was just missing it and being stupid or if it is just not possible? I've been asked to speak into the can light placement for a space I'm doing production lighting for and didn't want to manually draft it out with lines, unless I have to.
  12. I didn't realize there was a difference between your tools and the ones that got incorporated into VW. Just to make sure I understand perfectly (because it effects me wanting to buy them) The updates mentioned above to the Soft Goods 2 for specifying the weight of the drape is not possible in VW19? I've not updated to 19 just yet (waiting on IT who keeps the license) but if Soft Goods 2 estimates the weight I'm assuming that will allow the drapes to be incorporated into BraceWorks. Correct?
  13. 1. Mac Pro Late 2013 on 10.13.3 with 3.5 GHz 6-Core Intel Xeon E5 Processor, 32GB RAM, AMD FirePro D500 3GB Graphics Card. 2. 44.1MB File (originally from 2014) 3. This has the VW Truss Tool but hasn't been updated to the Truss Symbol that comes with Braceworks. Has 11 Soft Good items but it's mostly dress kits for screens and a backdrop on a truss. When I first started this file I was using a Mac mini for Vision which was horrible because of the video card. I constantly had a to complex geometry error. So I stripped the export file of most of the unnecessary items and upgraded machines. From doing that in 2016 I didn't have any issues until now. But I have also just added a few more lights to the room. I'm now updating the focus points for a few of the non-moving lights.
  14. I recently updated to SP3 for Vision and now whenever I'm in the app and make between 3-5 changes it crashes. Does anyone else suddenly experience frequent crashes or is it just me?
  15. Thanks guys. It was a Part issue. Didn't do it in the correct order.
  16. I'm trying to glow the lenses on some Chauvet Epix Strip IP fixtures. I went in to the Resource Manager and edited the 3D Component of the fixture and applied the proper texture to the glass to make it glow. I then re-grouped the lens with the rest of the fixture and now the lens appears in a different orientation than the fixture. The fixture is hanging on an angle, but this shouldn't cause the lens to suddenly shift. I've done this before with success and I've done this before with the same exact results. What am I doing wrong to cause this?
  17. In Vision 2017 I was able to connect from my Jands Vista on my Mac to Vision 2017 via sACN. I was able to do this on a network and even the same computer. Since changing to Vision 2018 I can no longer get sACN to work on my computer through a network, nor on the same device. ArtNet works just fine, but we prefer sACN for our network protocol. Has anyone else experienced an issue with sACN? I would very much prefer not having to change protocols just to program and then shift back for running my nodes.
  18. (See picture) Not quite sure how I have done this, but I have made a settings change that has altered how my lighting pipe and tick marks looks. If I turn off the tick marks and end markers this goes way but the lighting pipe looks like a standard line. I would like to use the ticks to show that it is a lighting pipe, especially since it is over the seam of some risers. I was making some adjustments to the class on a drum cage so that in the renderings it would be able to be seen through. After those changes my tick marks look like this. But I don't know what I changed. Anyone have any idea what class or other random setting I may have messed with that would cause the tick marks to be very large arrows?
  19. This may be something that is already there and I just haven't figured it out yet...Is there a way to do a Cyc or painted drop that is flat with no pleats? Currently I make the pleat size to .1" which is the smallest it allows. I still prefer using the Soft Goods tool over anything else for putting in these elements. If it is not possible to natively make it 100% flat without any pleats, I personally would love to see that implemented.
  20. Is there a specific way to do this within VW15? I have a show I'm building where the Director is having trouble seeing what projecting on the walls will look like. So I'm attempting to show him, however I can't figure out how to project an image from a projector and be able to still show the walls. Currently to do this I am just putting in a 90' wide screen, however I know this director well enough to know he will want to see the actual walls in the drawing. Is there a way to do this, without having to place an image onto each section of the wall and show the curves and angles?
  21. Thank you so much for the reply and tip. I've not done any coding yet but am trying to aggressively expand my knowledge and abilities so I will check it out and give it a shot. Thanks!
  22. So I've never created a device that is workable similar to the Stage Lifts that can be used in VW2015. I am wanting to create a ST-180 crank stand, that i can easily manipulate like the Stage Lifts, but I want it to look like the ST-180s so the client can see exactly what it will look like. Two quick questions, one of which would be a quick answer.... 1. Does anyone happen to have something already drawn that looks similar to this style crank stand? Global Truss 2. If no one has this, in brief, what steps do I need to take to make this a workable, configurable drawing/plugin? Obviously I need to draw all the parts, but how do I make it so I can configure it in the Object Info window? Still pretty new to VW so If this is a really dumb question I apologize.
  23. I am using Lighting Pipe, however the issue I am having is that I am rotating on multiple axis at once. So not only is it angling from one electric to the other (super easy), but it also hang from one height to another. That is the one that I am not able to get. Every time I try to change the height angle, I guess should say the Z angle, it either will not change, or changes the total height and not follow the vertical angle that I need it to set to.
  24. I'm trying to create some angled scheduled 40 hang positions. Basically trying to build a triangle out of schedule 40 pipe. But I cannot figure out how to get the pipe to show on the angle in 3D. I've actually already built this in the room, but am trying to do a drawing for use in ESP Vision. I need to have the angled lighting position go from my second electric to a vertical pipe hanging down from my first electric. This will connect the two electrics together with this angled pipe. I just can't figure out how to draw an angled hang position in VW14. I know it has to be something stupid easy that I am not seeing, but I can not figure it out and to be honest, it's making me extremely irritated.
