Alex G.
    4
Everything posted by Alex G.
  1. Wow. Thanks Peter. I suppose on the bright side the labels are there to trace over as annotations.
  2. Greetings, I am attempting to label a grading plan. Problem: In trying to show existing and proposed contours I have overlapping contour labels. I can modify existing or proposed contours separately, however, when I update the site model the labels revert back to an overlapping mess. Any suggestions would be greatly appreciated. Thanks!
  3. Thanks for your reply and example Steve. Could you please explain in a bit more detail the process you used. I was able to create a texture from a jpeg. From there did you use the 3D power pack drape tool or create a texture bed site modifier? Thanks!
  4. Greetings Vectorworks Folks, What is the best process to drape an image over a site model? (Similar to Sketchup) I am using Landmark 2014 and have created a site model. I would like to drape a conceptual jpeg site plan on top of the model. I have tried to convert to a texture bed and send to surface without any luck. I am fairly new to vectorworks so thank you!
