line-weight
    2,283
Posts posted by line-weight
  1. 8 hours ago, Jesse Cogswell said:
    @line-weight All right, give this a shot.  When you select a saved view, press the button at the bottom to set things like where the viewport should live, what its name should be, etc.  If you select the saved view without setting the options, it will default to the top sheet layer.  It will also do an error check on the viewport name, but if you leave it blank it will do the standard "Viewport-X" scheme that VW does automatically.  Also, pressing the button with the saved view selected will automatically put a check in the Selected column.
    This only looks at class and layer visibilities, and will rope in stuff set to "Ignore" if you're not careful (it loads the Saved View, pulls the current layer and class visibilities, then builds the viewport and applies them, if the class or layer is set to ignore in the saved view but is visible at the time you run this command, it will end up in the viewport).
    It also pulls the scale of the active layer to apply to the viewport, so it works best if you have the saved view Active Layer set to something other than "Don't Save", since then if you run the command while a sheet layer is active, your viewport will be at 1:1 scale, which probably isn't ideal.
    The plug-in was written in VW2019 but tested in both VW2021 and VW2022, so let me know if something doesn't work right for you.
    Thanks!
    I'm not managing to get it to work on the drawing that I want to use it on. It just doesn't seem to produce any viewports. Tell it to produce the vports on a certain sheet layer, but the layer is just empty. I've tried turning on all classes, etc, and doing "select all" in case the viewports are tiny or away from the origin. I can also use your other script to see if the viewports exist anywhere but this confirms they don't, because they don't appear in that dialogue box.
    However, I've tested it on a new very simple file, and it works there.
    I've also tested it on one of my other "real" projects, and it seems to work there too.
    So I am trying to think if there is anything special/unusual about the file where it isn't working. The only real difference I can think of is that it's quite a lot larger and more complex. I'll try and do a bit more detective work later today to see if I can work out what's happening. let me know if you have any suggestions for things to check.
  2. Yes please don't put loads of time into this unless there is some enjoyment in it for you @Jesse Cogswell! It is something that would be really handy for me in managing a particular project, and would save me some tedium but it's also a process that I can do manually without it being a big deal.
    @Pat Stanford no need for it to happen serially - choosing from a list and generating at once would be fine.
    To explain the purpose of this, it's really just a way of applying (very large) bunches of class visibilities that are saved as saved views, and applying these to already existing viewports. As I work on the model, a gradually add elements that get assigned to different classes and each of these classes is then made visible in one or more of my saved views. So the saved view setups can gradually evolve as I work on things, and I use them all the time to flip between different states of the model, but I also have viewports set up to produce renderworks images which are the final output of the process. Each of these viewports has a class visibility setup that matches one of those saved views, but there is no way of having them update themselves in parallel automatically. So, periodically, I have to update each of those viewports.
    At the moment the process to do this is to view the model in an arbitrary view, activate each of the relevant saved views, and for each of them create a viewport on a "master viewports" layer. It doesn't matter what these viewports look like, all that matters is that each of them contains the right combination of class visibilities to match each of my standard saved views.
    Then when I have all those master viewports generated, I use the script that @Jesse Cogswell kindly already provided, to copy the class visibilities from each of those master viewports, to a bunch of the final output viewports. Sometimes I am wanting to copy each master viewport to three 'final' viewports, and in other scenarios I want to copy them to ten or twenty. The script I already have makes this process hugely less tedious than it was previously (I had to go round with the eyedropper tool, and VW responds very sluggishly when you use it to copy class visibilities).
    So this other script would be about the generation of the master viewports each time I want to update them. It would streamline the current process of
    -go to design layer
    -activate saved view
    -wait for model to update
    -choose "create viewport"
    -deal with the settings dialogue (including typing in a name for the viewport)
    -wait for VW to produce the saved view on the sheet layer
    -navigate back to the design layer view
    -activate the next saved view ... and so on, eight or ten times over, each time I want to do this.
    • Like 2
  3. I'm seeing it on Big Sur / M1 / VW2021.
    And there are reports further up the thread seeing it on Intel Macs.
    So I don't think it's as straightforward as that.
    I seem to be OK doing multiple viewports up to a certain number, and then problems above that number. So maybe everyone will find a different threshold depending on all sorts of variables including hardware, software, and drawing size.
    • Like 1
  4. 27 minutes ago, Andrew Pollock said:
    I hit update all viewports and get coffee. When I return  I can look at my whole drawing set.
    yes this is my habit too.
    It looks a bit like this is related to the vectorworks version rather than the type of mac hardware though.
    Either way I would agree it might be a reason to hesitate from upgrading if you are still on VW2018.
  5. Eurghh... as I suspected, no longer being able to reliably render multiple viewports in one go presents me with some headaches.
    There is something peculiar about the way VW does renders, that means that rendering the exact same viewport with the exact same settings, doesn't always produce a pixel-perfect identical result. One use case for me involves multiple views of the same scene, each with identical viewpoint, but with some changes to the model geometry in each. I need to be able to extract these images into a photo editing application where I can lay them exactly on top of each other. It all needs to line up at a pixel level. But infuriatingly, unless you render all these versions in one go, VW is liable to output a bunch of images all with slightly different pixel dimensions. So, updating all the viewports in one go is the only way I have of achieving this. And if VW can't update multiple viewports without crashing......
  6. Thanks, that's very good of you!
    It seems to work; the only thing is that it acted on all viewports rather than just the selected one like a previous iteration of your script (which I have) did. However, I could see that I just needed to change the line near the end to
    ForEachObject(RenameVP,(((T=VIEWPORT) & (SEL=TRUE))));
    and now it works on selected viewports only.
    I notice it takes quite a long time to run (about 15-20 seconds) even if I just have one viewport selected ... is that what you would expect? Is it because it has to check every viewport in the document to see if it's selected, something like that?
  7. 7 hours ago, zeno said:
    I did a Bug for the same reason
    Did you make a troubleshooting thread in the forum, or just file as a bug?
    And was this recently, or some time ago?
    I guess you have not had any response as to whether it's something we might see fixed?
  8. 14 hours ago, Jesse Cogswell said:
    Updated plug-in attached.  Let me know if this creates any bugs or issues that I might have missed in my (admittedly rather quick) testing.
    Thanks very much! Seems to work fine. Really appreciate you doing this.
    Not expecting anyone to write this for me, but here is another thing that would be really useful to automate:
    >Activate saved view A
    >Create viewport named "A" on sheet layer X
    >Activate saved view B
    >Create viewport named "B" on sheet layer X
    >Activate saved view C
    >Create viewport named "C" on sheet layer X
    etc etc
    Would that be complicated to do, in principle?
  9. I have a question about this script...
    It renames viewports in the format:
    Layer Name > Drawing no. > drawing title
    But I would like to name my viewports:
    Layer Name > Class of viewport > Drawing no.
    Is that something that could be done with a simple alteration to the script?
    (By the way, this is as part of a workaround to a slightly annoying behaviour in VW when I am naming viewports, which is that although viewports don't have to have a unique "Drawing Title" I am not able to batch-change the "Drawing Title" by selecting a number of viewports and then typing my desired drawing title into the relevant field. VW will let me type something in there, but it doesn't then apply it to all of the selected viewports. Unless I am missing something.)
  10. 6 hours ago, Tom W. said:
    I'm not sure if this is exactly the same topic being discussed here but I definitely have issues updating section VPs. I NEVER attempt to update more than one at a time. Even then I hit the button with trepidation. See:
    sections through site models have their own issues for me ... but in this case (ie what I'm doing at the moment which prompted my comment) there is no sectioning involved - just perspective views rendered in renderworks.
    They do all contain a site model though. I might try turning the site model off just to see if that makes any difference.
  11. 16 minutes ago, Will said:
    I get this on my intel MacBook as well. After updating lots of section viewports Vectorworks uses lots of memory and becomes very sluggish. It’s like there is a memory leak in the section generation process. I also have to quit and reopen to be able to continue working.
    Hm. i wonder if this deserves its own thread in the troubleshooting section then.
  12.
    3 hours ago, zoomer said:
    At first I thought VP Update may now be multi threaded and therefore
    needing more RAM when updating all VPs at a time according to how
    many cores/threads are available.
    But when I watch VW's Status Bar it looks like it does one VP after the
    other anyway.
    yes, that's how it looks to me too. So I don't really see why the RAM should be a problem.
    I don't get an error message ... it just crashes or freezes with beach ball.
    Right now it's freezed, but it only seems that 12GB of swap memory is being used, which doesn't seem that extreme...
  13. 5 hours ago, zoomer said:
    Yes, I also was used to "Update all Viewports" on Intel Macs.
    Same experience here, RAM went up until it needed more Swap Memory
    than what was free on my system SSD (240 GB or so).
    Not 100% sure if it finally crashed macOS, but at least I got a warning message
    and at that time macOS also started to close all my other Apps running.
    For now I only Update one by one.
    Hm, is this in VW2022 as well as VW2021?
  14. Something I have noticed running VW on my M1 mac mini.
    Previously I could update a large number of renderworks viewports on one sheet in one go. I'd simply select them all and press "update". It might take a long time but it would do it.
    On the M1 this often seems to provoke a crash. I can get away with doing maybe 10 at a time, but if I try it with, say, 25, I often get a crash.
    I can't exclude this being a VW2021 problem (because I switched to the M1 and VW2021 at around the same time). But wonder if it could be relate to RAM in some way - as noted elsewhere, VW seems to progressively eat up an increasing amount of RAM that can only be released by quitting & reopening. In activity monitor VW is often listed as using more than the installed 16gb.
    • Like 1
  15. 1 hour ago, arquitextonica said:
    Thanks A LOT!
    Out of curiosity... is there a reason for the change?
    Some of the issues are discussed in the thread linked below - although that's a bit out of date now.
    Horizontal sections are the "least worst" option for me at the moment, but the pros and cons will be different for each user depending on what kinds of projects they do.
    • Like 1
  16. I would look at the geometry contained inside the symbol, to see what class(es) it is assigned to, (NB this is not the same as the class the symbol itself is assigned to) and then check whether you have these classes visible. If that's the problem then you can choose between making those classes visible in any views you want to see the symbols in, or changing the classes within the symbol to match your existing classing system.
  17. Having just played around with settings, here is one thing I think can cause confusion.
    When an object is selected, the attributes palette shows the attributes of that object.
    But when no object is selected, what does it show? If you asked me that without letting me go and try it out, I think I'd say that it shows the attributes that will be applied to the next object drawn. But actually that's not the case. If I change the active class to one that has "use at creation" on, then that's what determines the attributes of the next-drawn object, not what is shown in the attributes palette. I would argue that this is counter-intuitive because if i don't have a "use at creation" class active, then the attributes palette *does* show what will be applied to the next-created object (assuming nothing is selected).
    So in other words, anyone who commonly draws with "none" active and without "none" being set to "use at creation", gets used to the idea that the attribute palette shows you what the next object is going to look like. But if you then switch to another class, with "use at creation" active, this behaviour changes. The attributes palette continues to show whatever you last chose there, instead of what's going to be applied to the next object. And of course, once the object is drawn, and remains selected, it shows those attributes.
    I think this confusion would be avoided if, when you selected a "use at creation" class, the attribute palette switched to show the attributes set for that class, because that's what's going to apply when you draw something. Go back to "none" class and it reverts to whatever you last selected manually.
    By the way VW is not the only application where I find some confusion between "attributes of selected object" and "attributes of next drawn object". There's a drawing application I use that treats this in a different way but can still be confusing.
    It makes me wonder if it would be best just to have two separate locations for this information: one that shows attributes of currently selected object, and one that shows the attributes chosen for the next-drawn object. In fact it often feels to me that it's inconsistent that certain attributes of a selected object are shown in the attributes palette while the rest are shown in its object information palette. Isn't there an argument that all attributes should be shown in the OIP? Then the attributes palette would have a clear purpose - to choose what will be applied to the next thing you draw.
    • Like 4
  18. 14 hours ago, P Retondo said:
    So, "use at creation" trumps the attributes palette default settings, but that potential conflict did not change the default attribute palette setting.
    I think this might be the reason I seem not to have "none" class set to "use at creation" whereas I do have it set for other classes.
    Because sometimes I want to be able to draw something with attributes different to the "none" defaults. I suppose I could still draw it as none, and then change its attributes after it's created, but that could be cumbersome when I want to draw a bunch of things with non-default attributes, which aren't all in the same place.
    Thinking about it, the attribute I most often want to change is whether something has solid fill or no fill. I want a polygon to have solid fill whenever I want to subsequently extrude it, for example, whereas in other situations I want to draw a polygon without fill so that it doesn't obscure stuff behind it.
    • Like 1
  19. 5 hours ago, Boh said:
    So it sounds like you all want your attribute palette to be set to use class attributes by default
    For me this is one of those things where VW seems to behave not in the way I expect - in that I go to draw a new object and the attributes are not what I feel they "should" be, according to what I had done previously. That might be that I am expecting them to be the defaults but they aren't - or I am expecting them to be something else but they are the defaults. I can't pin down exactly when/how this happens, all I know is that it does happen, and it's quite likely that VW is doing everything entirely consistently and logically while the fault in expectations comes from me. But somehow there is something about the way it behaves that constantly trips me up.
    • Like 2
