line-weight
    4,889
Posts posted by line-weight
  1. 33 minutes ago, Thomas Wagensommerer said:
    What AI has to say:
    WIthout knowing anything about what "AI" has based its analysis on, its conclusions don't have much value.
    It's not explained what "V" and "A" are but we assume they are Vectorworks and Affinity Publisher.
    That's comparing apples with oranges because what Vectorworks can do is a lot more complex and wide ranging than what Affinity Publisher can do.
    (I say this as someone more than happy to criticise VW's UI design)
    • Like 4
  2. Similarly when I duplicate a layer I'd like the new layer to be assigned to the same storey as the original one.
    At the moment objects in a duplicated layer lose all their boundings to storey levels, which is a pain.
    (By the way "story" is not the only North American terminology/spelling to exist in the UK localised version; should we have a round-up of what needs to be fixed?)
  3. Thanks for these further explanations @Nikolay Zhelyazkov
    1 hour ago, Nikolay Zhelyazkov said:
    - I think that there are 2 ways to match a subpart to a criteria
    a) The parent matches the criteria and include subparts automatically adds the subparts in - for example "Object is Wall + include subparts" - gives you all walls and their components
    - Are we agreed that something is not working as it should in the file I've attached to this post, though? Because for the datavis I've named "class contains materials" the parent objects *don't* match the criteria and yet their subparts are being found and acted on.
    - Note that also, in that "class contains materials" datavis, I have to turn on "search within groups" in order for the components to be found. But none of the objects in the design layer are within groups. So is something not working as it should here?
    - And another thing! It says it finds 8 objects (the extrude plus the 7 wall/slab components) but then under "values" it only lists one class. It should be listing 4 classes here, because the relevant objects are in 4 different classes.
    b) You make the criteria about subparts and then only the subparts that match it get included - for example "Subpart type is Component + include subparts" - gives you all Component subparts of walls, slabs and anything else that has these
    - I have tried this (datavis is called "subpart type is component" in attached file) - it correctly finds the 7 components under the criteria, but again, I seem to have to tick "search within groups" even though none of these objects are in groups.
    - This time under display criteria, when I choose "objects using function" "class", no values are listed at all. Again I think it should be offering me 4 values here, the 4 classes that the components are in. I had to manually add a dummy value in order for it to let me press OK and create the datavis.
    - The result is that this datavis doesn't work.
    DV_hatch C.vwx
  4. I'm interested in this too.
    My understanding is that the carbon footprint is pretty hard to pin down because it depends on the energy source for the relevant servers and data centres. And a lot of the ones being built at present are using "dirty" sources like gas power plants.
    And then there is the question of whether you only take into account the energy used by your specific query or a portion of the energy used to generate the model it uses.
    A reasonable round-up here
    https://www.technologyreview.com/2025/05/20/1116327/ai-energy-usage-climate-footprint-big-tech/
    Surprisingly it seems that image generation may be less bad than text generation.
    • Like 1
  5. @CollaborativeHomeDesign there are many problems with how notes and the notes manager works in Vectorworks. I can see you've started a couple of other threads too. I believe that all/most of the problems you are experiencing are ones that have been identified for several releases now.
    There is a thread here asking for the whole thing to be given some intention - please add your vote to it:
  6. Ok, I think following these steps in a blank file allows this issue can be replicated. I have just tested this in VW2026 update 3.
    1. Create a general notes object. This brings up the "general notes" dialogue
    2. Press "Add". This brings up the "add note" dialogue.
    3. Choose database and press "add note to database". This brings up "add note to database" dialogue
    4. Untick the "use the first 42 characters..." box and create a new note with "First note description" in the "description" field and "first note text" in the "note text" field. Press Ok
    5. Now in the "add note" dialogue choose the note you've just created and click OK (this is one of the points in the process where not doing the bit in bold can trip you up)
    6. This returns you to the "general Notes" dialogue. Press OK and so far thing seem as expected.
    7. Press "Edit notes" in the general notes object's OIP, and then repeat steps 2 to 5 but create a note with "Second note description" in the "description" field and "second note text" in the "note text" field.
    8. So far things still seem as expected
    9. Repeat steps 2 to 5 again but create a note with "Second note description" in the "description" field and "this is a duplicate" in the "note text" field.
    10. This creates a general notes object where the problem can be seen in the following screen recording:
    Note that the issue arises once there are two notes with the same "description". The "edit note" dialogue is unable to select the duplicate one correctly.
    @jblock did this ever actually get looked at, or was a bug ever created? If not then I will file one.
  7. 37 minutes ago, CollaborativeHomeDesign said:
    Did you ever figure this out? I'm having a similar issue (well, lots of issues actually) with the general notes object functionality.
    I think I sort of did (and had some kind of workaround) - but haven't used the object recently and now forget exactly. I think it might have been something to do with notes having the same title, as I mention in one of my posts above?
    Perhaps if I have time tomorrow I'll have a quick look and see if I can remember.
  8. On 1/31/2026 at 5:28 PM, Nikolay Zhelyazkov said:
    Thanks @Nikolay Zhelyazkov.
    I see that section does explain a bit. I think that I clicked through to that earlier, but was then confused because I am looking at a help page about Worksheets, and the dialogue box is slightly different (for example it has an "include parent objects" box whereas the Data Vis one doesn't).
    Unless I am missing something it still doesn't clearly define what "subparts" are.
    For example if I have a group within a symbol, is the group a "subpart" or are the objects within the group "subparts" or both?
    In my file example I don't understand why I have to tick the "include subparts" box in order for it to recognise the objects. The file contains a roof face, a wall and an extrude.
    The criteria are to find any object with a class name that inlcudes "material". That includes 7 components inside the wall and roof objects. To find those components I would expect to have to tick "search within plug-in objects" but just ticking that box has no effect.
    When I tick "include subparts" then the components are found. But this does not match the behaviour described on the help page. The parent objects of those components do not meet the criteria  - they are not in classes whose names include "material".
  9. 9 minutes ago, Sebastiaan said:
    yeah because those views are Perpendicular anyway ☺️
    Could be the same command. It’s just moving on x or y. Don’t understand why it needs a different command and why move x 100 woul have to have a a different result. Very counter intuitive
    I suppose you could inadvertently move something in the Z direction, in plan view, without realising it if you had left a value in the Z box from a previous operation.
  10. 35 minutes ago, Tom W. said:
    I thought the Camera did exist as an object, just within the edit space of the VP rather than on the Design Layer?
    I guess if the "edit space" of a VP is a thing, then that's where they exist.
    Like you say they are quite furtive and don't show up in the Visualisations palette. So I don't feel totally confident that they are a secure repository of location info, when it's critical. But there doesn't seem to be another option anyway.
    The VP OIP does actually let you know if a camera is present:
    Really the camera settings should be accessible from a button right there. But I am sure this has been discussed/requested many times before.
  11. 15 minutes ago, Tom W. said:
    Can you not copy the camera from the first VP then paste it in place in the second VP...?
    Ah... yes this does seem to work. Thanks.
    Feels a bit anti-intuitive as the "camera" doesn't really seem to exist as a physical object as such.
    It appears to be necessary to do "paste in place" rather than just "paste".
    Would really be a lot more useful if we could define one camera and then have it apply to multiple viewports, so that any change to the camera viewpoint would only need to be made once.
  12. In certain situations, once I have set up a perspective viewport view manually (I move around in the design layer until I find the position I want, and then create viewport) I want to know exactly what that viewpoint is.
    In other words, I want to know the exact X, Y and Z it is looking from (and ideally direction of view as well).
    It seems like the only way to do this is to go through the unintuitive and laborious process of creating a VW camera linked to the viewport. That then gives me a camera that doesn't actually "exist" in the model anywhere but at least clicking on "camera" on edit viewport gives me an OIP like this:
    That's ok - but what if I want to tell another viewport (with, say, different layer/class/datavis visibility settings) to look at exactly the same view?
    I think the answer is, I can't, is that right?
    The only way I can create another viewport with exactly the same viewpoint is by duplicating the first one, and then re-applying all the settings, I think. That was the case when I last looked at this some years ago but am checking that nothing has changed in the meantime.
  13. On 1/28/2026 at 7:24 PM, Christiaan said:
    I'm working with an architect who's mastered rendering in Nano Banana. His renderings are phenomenal. His main advice is clear wording, working through a number of prompts and then starting again with a combined prompt using the most effective ones. These are both generated from a Vectorworks model via Hidden Line Viewports.
    Are the lighting/shadows here produced/guessed by Nano Banana rather than calculated in VW? I'm guessing the answer must be yes if all that it's being given is a hidden line view?
  14. 22 minutes ago, shorter said:
    The 'benefit' of columns is the ability to style them, and choose the 'architectural' which is generally the 'finishes', versus structural,  which we tend to never use.
    We never use the base or capital.
    Some find the ability to control heights via storeys, etc, useful.
    That said, more often than not, we replace them with symbols.
    Have you investigated the pros & cons of "Column" vs "Structural Member" in column mode?
    I don't see the point of having both things - it's two separate things for users to try and understand, and two separate tools for VW to keep updated or develop.
    Sadly the Structural Member tool, which is potentially really useful but does have some frustrating limitations, currently seems to be parked with little active development.
    • Like 2
  15. On 1/29/2026 at 9:51 AM, Nikolay Zhelyazkov said:
    Hello all,
    I am not that familiar with data viz but it looks like it has troubles with subparts/components. Having this logged as a bug is the way to go so that the responsible team can look into it.
    Best Regards,
    Nikolay Zhelyazkov
    I am unclear what "subparts" actually means. I often just tick the box in the hope that it means nothing gets missed but don't really understand what effect it has.
    As far as I can see it's not explained in the data vis help page.
    Do I need to tick "include subparts" for any of the "search within" categories below to take effect?
    The only way I can get the dialogue to show "Objects that meet the criteria: 7" is by ticking "include subparts" and "groups".
    I find this very confusing.
  16. 18 hours ago, Christiaan said:
    With regard to plug-in objects, I would open source them and put somebody in charge of managing code input from users, especially for little tools like the Clothes Rod.
    An excellent idea.
    There are lots of users who want to improve tools and the software in general. VW already gets loads of unpaid labour from users who spend time testing stuff and suggesting improvements. It would be great to divert some of that enthusiasm into actually producing improvements instead of it being spent writing frustrated forum posts about tools that never get updated.
    • Like 1
  17. Pretty much this problem has been covered in a couple of other threads previously - the question is what the search terms are, that will bring them up...
    eg. this raises some similar questions
    • Like 1
