4,966 -
Article Comments posted by line-weight
So... it looks like it's still the case that moving to Sonoma might be a bad idea?
Better to skip it altogether and go straight to Sequoia at some point?
Seeing the 3D dragger added to (some) operations is very welcome.
I hope we'll see it available for more commonplace actions too - like simple repositioning and rotating of objects using the selection tool.
2
I'm afraid that the answer (as far as I know) is that in practice there's not really a straightforward way to do it, or at least there's no one "official" way to do it.
Methods I have used include:
- Take your top/plan floor plan, make a viewport where it's greyed out, then in the annotation layer, manually draw in the ceiling details you want to show
- Take a horizontal section through the building at the appropriate level, turn off "objects beyond the cut plane" in that viewport, then manually draw in the ceiling details you want to show, again in the annotation layer
- Take a horizontal section through the building at the appropriate level, set it so that it is looking upwards. Then flip/mirror that viewport. If you have carefully 3d-modelled your ceiling, then the geometry ought to show up correctly. In that case for a purist approach you could draw everything in 3d (like light fittings etc) and they will appear in your section view. Or you might want only to model the basic geometry so that you can see where things like level changes and beams are, and then add in things like light fittings manually on the annotations layer.
Which approach is best will depend on how complex the design is, how much time you want to invest in 3d modelling, what you need/want to show on the drawing, and how important it is for the ceiling detail in viewports to update automatically when you make changes to the model.
2
Vectorworks Viewer Downloads
in Knowledgebase
Posted
I found it here by googling "Vectorworks 2026 viewer"
https://designexpress.eu/support/en/vectorworks/vw-en/download-vectorworks-viewer
