zeroInf
42 -
Everything posted by zeroInf
@BSeigel , i really know that option , and is elegant & and useful . but i want to make it directly (without creation of Hanging position ) . I try to build a Python plugin for do this job . Thanks for your response.
Looking in OIP after System Select i found " Total Lenght " i tink was possible .
Hi there , I try to make with dataTag Total Lenght of Truss System . I used Dynamic Text " #TrussItem#.#TrussSystem#->#TotalLenght# " but not work. Anyone can helpme ? Screenshot of value Thanks.
Oh , Thank you @bbudzon , I'm going to settle around hoping to improve something . One more problem: I'm programming the show I've made available in the link above and, I notice that Robe Spiider (in Mode 3) don't work with GrandMA. I have the same project file (created with VW 2019) exported for 3 visualizers (Vision, Capture, Lightconverse *) in Other visualizer the fixture work in Vision no. The same patch the Same mode , The device on MA is one and it work with real Spiider Fixture * Is not my intention to publicize other software . But in this case i have all 3 software connected to MA and working with 3 Monitors UHD . My apologize fro my poor english
Hi friend, i buy it Vision dongle a year a go , but unfortunately never help me . any time is something go wrong . So i decided today to write a post with attached file. Questions : 1. Why do I have such a large light difference between a PixieBeam and a DTS Raptor? Why i don't see PixieBeams almost for nothing? The same is for DTS Katana. 2.Why Ayrton Magic panel are they so dull? (attached screenshot Magic Panel ) 3. How can i get the same quality ( see attached file "16_52_28" ) with Vision [The same project from Vectorworks] Link Vision File : https://newlight.cloud/index.php/s/yMfPaXwD7MSma8B
Check this settings ( see in image ) . I hope you don't have craked version https://prnt.sc/povabu
Hi there , Im trying to export a data from worksheet to Mysql database withowt results , When i try to make Recordformat Database connection , every time i recive follwoing error : [1064] Driver error: 37000 [MySQL][ODBC 8.0(a) Driver][mysqld-5.7.24]You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'name VARCHAR(50), manufacturer VARCHAR(50), length VARCHAR(50), width VARCHAR' at line 1 I set corectly the ODBC x64 and ODBC x86 , test conncetion was successful, read all table . Any one have expiriense with this ? Wath i do wrong or how can i make this ? Running Mysql Server version : 5.7.24-winx64 OS : Windows 10 VW version : 2019 SP5.2 Thanks .
Hi there ! , i checked VW 2020 for my request (Up) , but it seems that there is not yet present.It's true or i missing something . Thanks
Ooooh , Thanks , maybe this make life easier for our ING.
Hi , Lately our ingiere and I are comparing ourselves with the calculations of truss, hoist ... and one day he asked me to export them a DSTV file. which I did but he tells me that it is not valid, his Scia 2019 asks them to import a * .sc2 file and not * .stp as I exported from vectorworks. Is there a different way to do it? What should I say? Surely he will know how to use his software. Have you ever exported DSTV?
Instruments Schedule > Summarize by Instrument Type
zeroInf replied to zeroInf's topic in Entertainment
Hi , I tryit to generate a Instruments Schedule as you can see inside attached file , But i have question : How can i Summarize & count by Instrument Type . thank friends. InstrumentSchedule.vwx
I think you must use IFERROR please read documentation here > IFERROR
Oooh Yeah , Because will be very useful . Thank, Brandon SPP
Hi guys ! I have a simply question probably with a simply response : How can i get Number of Leg of bridle inside diagram ? Thank You
So guys. I finally succeeded, but he didn't ask me why I don't know. On my workstation I have mounted 3 network adapters for these things, I configured them like this: 1. in artnet 2.grandMA-net. 3 SANC and I don't know how but I succeeded. I must say that I also installed the gMA-ESPVisio driver from MA. Another question : Why light beams are seen in low resolution (pixelized). What settings should I touch? Screenshot_1 [My config: I9-7940X @3.10Ghz ; 128 GB Ram .RTX 2080Ti 12GB Vision Preference : All MAX] Connecting the grandMA to ESP Vision.pdf
- 10 replies
- 1
Thansk Gaspar , i try but with no results again . i go to learn everiting maybe i find solution
- 10 replies
I try it Artnet & sANC more time , I tink the problem is : C:\Program Files\Vision 2019\DmxProviders\grandMA.dll .
- 10 replies
Hi ! Today I loose 12 Hours to connect Grand Ma3 ( run grandMA2 Os) to vision , without results . My question is : Is there a guide to make this ? My configuration : MA3 (grand MA 2 OS ) conected al my workstation trought a Zyxtel Switch (1Gb/s) . Ip adress of my NetworkCard : 192.168.0.220 . ip on Ma > 192.168.0.25 I changed more times all ip's. I installed 3 Time Vision 2019 Sp1 . Note: grandMA on PC connect succesfull to grandMA3 , withowt problems . Any solution
- 10 replies
Instruments not attaching to/Following Hanging Position?
zeroInf replied to miguelZinfandel's topic in Entertainment
For me its a bug. My temporary solution : After moving any H.Position > Spotlight > Refresh Instruments. Just try -
For me is a bug . The same things . if i move a hanging position left to 100cm them i move back all fixture dont follow the hanging position . the solution for me is > Spotlight refresh instruments . and then all fixture go back to hanging position -
See immage attached , i can explain with my poor english . You can add a lot of function ,but not only . You can Create an Record Format then attach to your symbol and then create Report based on Record format ... In this case I/we used functions.
You can do this Job with Worksheet , createing a report . A example file attached (VW@2019) . http://prntscr.com/ne1wdh F@001.vwx
Hi people of Vision , i have some question Why the lens of all fixture are stacked out of body and not inside ? *Screenshot_1.png Why the light crosses the wall ? * Screenshot_2.png In my case i have only Martin Mac Aura , why floorprint is like a spot ? and don't have blurred border *Screenshot_3.png Bloom lens are like big Pixel . why? * Screenshot_4.png My Vision Settings * Screenshot_5 Why the Software Console it works only with ETC,Par ...... but not with Mouving Heads How can i use the tool: - Point - Line - Xfrom (In properties palette ) Can we have in the next vesions : - Control of Smoke machine ( Not ambient haze wich is present ) es: Number; Size & Volume of output smoke - Multiple camera (editable > Position,Rotation....) - Set size of left ToolBar My configuration: Cpu: Intel Core i9-7940X Gpu: RTX 2080 Ti Ram: 128 Gb
Hi there , When i try to import DWG file in to VW@ 2019 it crash , I imported succesfull in to VW@2018 but when i go back in to VW@2019 to open file created with VW@2018 It crash again . My configuration: Cpu: Intel Core i9-7940X Gpu: RTX 2080 Ti Ram: 128 Gb VW@2018 Sp5 with Braceworks VW@2019 Sp2 with Braceworks Attached files: @2018.vwx [file created with VW2018] DWG.dwg [the DWG for import ] Any suggestion ? Thanks ! @2018.vwx DWG.dwg
