Brandon Wardell
56 -
Everything posted by Brandon Wardell
Sorry, I read your 10,000 as 1,000.
Sometimes I have to pump my line lights up to an outrageous output for them to read. Stupid question, but your "lights" class is on in the sheet layer you're rendering in, right? When you reply you should get a box at the bottom of the window where you can drag files to upload them
Instruments not attaching to/Following Hanging Position?
Brandon Wardell replied to miguelZinfandel's topic in Entertainment
I've been having the same problem lately, with instruments not recognizing the hanging position they're on top of. It's very frustrating. -
Limited Fixture # that can be rendered.
Brandon Wardell replied to Andy Lasseter's topic in Entertainment
The limit for OpenGL rendering is 8 lights. Use Fast Renderworks instead. "OpenGL renders up to eight lights in a drawing; additional ambient light, directional, point, or spot lights have no effect. Custom, area, and linear lights can be added." -
It really depends on what stage I'm at in the design process (presuming lighting design as opposed to scenic). If I'm in the initial phases I might use a glow texture, but I really prefer the ability to control light output from the Visualization Palette. The one place I almost always use glow is for a back-lit cyc, and even that's problematic. If there's room I'll fudge the distance and front light it.
The option I mentioned also uses a render light, but this is a good summary. I personally find glow textures less helpful for renderings that utilize stage lighting.
Try modifying one of the stock frosted glass textures. Here’s how that has worked for me. https://www.dropbox.com/s/w88qbs4e88njasp/5 Astronaut.jpg?dl=0
Selectively visible Focus Points
Brandon Wardell posted a question in Wishlist - Feature and Content Requests
A button to toggle focus point visibility when not in wireframe view (like light objects). Would be so incredibly helpful. -
Global Lighting with All Fixtures Off
Brandon Wardell replied to Haydenovative's topic in Entertainment
Yeah there is that problem. I generally turn on "draw edges" when I'm rendering in OpenGL to help differentiate the faces. I've also found some success with adding a large single source with no falloff up and to the side of my drawing to emphasize facets. Good luck! -
You should just be able to increase the ambient lighting to achieve what you're looking for. View>Lighting>Lighting Options -
I just replaced my light info record on an old file to update the instruments, and suddenly my Source Four 50° isn't an option in Find and Modify. Any way to rebuild that list?
Jim beat me to it. I was just about to say the same thing!
I'm still using 2016, which is less helpful (I'm a teacher, our lab has 2016) but I'll take a look if you export to 2016
This is not normal behavior. You're using Fast Renderworks?
OK I'm working in 2016, shuttering lights to keep them off the scenery, and they only sometimes work. They'll render on the Design Layer but not on the Sheet Layer. It's sucked away hours of my time, and I really need to sort it out. I'm including somephotos of the same setup with shutters working and not working, also a screen shot of the shutters working on the design layer. Any help would be greatly appreciated.
Where are people getting high quality human figure models from? I've been using Renderpeople models for the last little while, and while I like them, they tend to have a light side and a dark side--not terribly useful for lighting design.
I think it was in fact co-planar geometry. thanks guys
I've been working on rendering a show, and all has been going fine except for this one. Sometimes the floor shows up glossy white as intended, and sometimes I get these orange and red stripes. When the stripes appear I also lose all shutter information for my lights. I've tried restarting VW, restarting the computer, changing out the instrument, focusing at another point, all to no avail. It's completely unpredictable. Is there something I can reset? Some cache that can be purged? thanks EQL Plot 2016 render.pdf
Why oh why do I have to zoom out and find the perspective view when activating a camera? Is there a way to lock them to the visible screen? This drives me absolutely nuts!
Beam Angle 2 and Field Angle 2 not saving
Brandon Wardell replied to dwdavedw's topic in Entertainment
Did you migrate your plot template from an earlier version? You need to repopulate your plot with the default instruments provided with 2016. Really annoying. -
Draw Beam keyboard shortcut?
Brandon Wardell replied to Brandon Wardell's question in Wishlist - Feature and Content Requests
MichaelK I couldn't open your file... -
Will do. Thanks for the help!
Nope. I've removed all locked cat positions. That may have ultimately been the problem, I'll keep an eye out for that in the future. Yet another example of how differently some people draft.
Still no option to change the name in the OIP. Baffled.
Inexplicably, it finally allowed me to name them properly, but if I alter them in any way they revert to a Cat 2B-1 kind of scenario. I don't know, it often seems like there is some corruption sneaking in every time an older file gets migrated to the most recent version...
