439 -
Everything posted by Tobias Kern
Hello Tom, hmmmm? The error I reported has been fixed. The beta version I have access to is not affected by this behavior. I tested my own demo file from this thread. We are not getting an official update 2 in Germany. I expect it for end of November or beginning of December. In previous beta updates for update 2 I tested the file, and it worked for me. If possible, send a demo file from you. I will test it out Greetings Tobi
Can I make this hatch repeat perfectly?
Tobias Kern replied to line-weight's question in Troubleshooting
Hi, today I created a Jira request that the script we can use in the German version should also be made available for your version in the future. Maybe I'll also get permission to share the script directly, then you can test it to see if it works for you. It is possible that the script is already included and is not integrated into the menu of your installation. The script is called: Convertir en hachure.vsm and could be located in the Plug-Ins folder. Best regards Tobi -
Hi line-weight, if you want another hatch style, i can make you one. Draw the one you like, and i convert the drawing into the hatch for you. Greetings Tobi -
Hi, you can test this both hatches (one with gaps). Angle: 45° File = VW 2024 + VW 2023 Made in the German version, with the feature Tom mentioned above. Hope this helps. Greetings Tobi hatch v2023.vwx hatch v2024.vwx -
VW24 + Sonoma equals invisible mouse
Tobias Kern replied to MartinBlomberg's question in Troubleshooting
Hi, same for me here. I also noticed this behavior for 2023 SP7. I made a Bug-Report. Greetings from Germany Tobi -
3D dragger oversight is killing me
Tobias Kern replied to Kaare Baekgaard's question in Wishlist - Feature and Content Requests
Hi, for my opinion the snapping dots are to close to the mid-ball. I think it can happen to click to the wrong part (snapping dot or ball). I would prefer to have snapping always on as standard, and with ALT-key you can temporary turn it off. What do you think? Do you need more snapping on, than no snapping? The Dragger is great as tool and i would like to see it everywhere possible, e.g. moving a whole window in wall in 3d space. -
Hi Kaare, your Nurbs-Kurve is degree: 3 and the Nurbs-Surface is degree: 2, I don't know, but I think a mixture of degrees can't match perfect. But in the center of the Dragger is a "ball" you can also pick that ball to move the object/part of the object. Maybe this helps you? Greetings Tobi -
Hi, same for me here! I have also problems with the Cursor after my update to Sonoma and VW 2023 SP7 + VW 2024 (latest) Greetings Tobi
Hi, I noticed the same for me. After my accidental update to Sonoma (I only wanted to download it, but Sonoma installed it itself= my fault), I have problems by quitting Vectorworks, even with the new Sonoma update 14.1. Yesterday I installed VW 2024, (release day in Germany) and I also got crashes by quitting VW. So VW 2024 got installed after the migration to Sonoma. Vectorworks is the one and only software with crashes like this after my update to Sonoma! Things I tried: - permission reset via Terminal - Repair with Vectorworks Updater - rebuild of the user-folder Things that I think could still lead to problems for me (completely subjective) - my User in macOS (maybe I try to a new user) - my custom Workspace setting Best would be to by a new Mac! 🤣 Greetings from Germany Tobi
Hi, In one of my recent projects, I have an opacity setup with the combination of record entries and data visualization. In the record save a pop-up list with the following entries: -, 25%, 50%, ... Create different textures with the same amount of transparency, like you have in the pop-up list. Create a Datavisualization and overwrite the texture with it. This solution works relatively well. It is the most versatile solution that I have tested myself. Greeting from Germany Tobi
Thank you Senthil! Hope you can find, what's causing the problem! Greetings from Germany Tobi
Hi, okay, okay! I took my time and made a report: VB 199975. Greetings Tobi
Hi, did you use "Poly Smoothing" on the original Polyline of the Extrude? If i (re)set to "No Smoothing", I can bend the Extrude with the Deform Tool. If that's the problem with the Deform Tool, someone has to make a Bug-Report or a Enhancement Report, if it is not possible to bend smoothed Polylines/Polygons Greetings from Germany Tobi
Batch re-number sheet layers
Tobias Kern replied to Neves+Creative Inc.'s topic in General Discussion
Merci! ... maybe you are more familiar with prepositions than I am, even if I've been awake for a long time. 😎 Greetings Tobi -
Hi Michael, and thanks for the opportunity for our users here. ❤️ / / / I installed the plugin into my Plugin-Ins folder in the main application folder, and integrated the plugin into my menu with the workspace-editor. Is that the way you recommend? … or can it be done faster, maybe with the Plug-In-Manager? by-the-way: I always have to use Deepl to translate my weird English into a better format. Greetings and many thanks for your help Tobi -
@michaelk Hello Michael, Many greetings and a great plugin. I love it. I don't know why this is not a standard plugin in VW!!! May I introduce your plugin in the German forum? I think there are many overseas customers who need such a feature. I refer to you as the author. and will write a small how-to (installation, integration in menu, …) Greetings from Germany Tobi
