Hi Tom
Thanks for the quick response. I can certainly see this working both ways. It just seems a bit less than clear right now.
As a touring dance lighting designer for most of the work I have done the booms with sidearms are built as needed to spec as sidearms may need to change heights to design spec whether using the Altman sidearm or hardware (KeeClamp or cheeseborough and pipe) sidearm approach since they are not part of most rep lighting plots unless it is a dance house.
I have watched part of the video link you sent but was interrupted part way through.
Mark has provided really great information but I will need to watch it all again and create a simple point by point worksheet for myself to be able to remember the steps the first few times I try to recreate the process.
Glad work is ongoing to improving the sidearm library.
Either approach (lighting accessory or rigging element) could work (I think at least) once it is clear what the steps in the process are.
In my mind it is a bit cumbersome to have so many different versions of the lights with multiple lenses, overhung, underhung, single tee and double tee sidearms in the resource browser library to simply draw a boom. As well as doing the light maintenance to make the counting work correctly. That is my main argument for the sidearm not being a lighting accessory but part of the rigging system.
The original question above about how to modify the relationship between the sidearm insert point, rigging position and the fixture is still not clear to me however. Perhaps the video link will make this clearer to me. Sadly, I was distracted almost immediately after I began to watch it earlier and have not been back to it since.
Thanks again for your response.
Be Well!
KAJ
